| Author | Topic: Aqua Signal Bracket |
| kend |
Where can an Aqua Signal plastic navigation lamp bracket or the whole assembly, lamp with the bracket (part number is 25900-5), be found? The item is discontinued and I cannot find one at any marine store or online. The part number is 25900-5. I need the top snap-on part of the bracket but will buy part or all of what is available new or used. Thanks for any help! |
Searching on GOOGLE with the terms aqua signal 25900-5 I found several other posts from you on this topic on other websites, often answered by advice to search on GOOGLE. I think the usefulness of a GOOGLE search has been reduced as a result, as GOOGLE finds mostly your own posts. If the manufacturer no longer makes the part, and has no inventory of the part, and all dealers and distributors have no inventory for the part, the chances of finding a new replacement are diminished considerably. You may have to consider an alternative navigation lamp to replace the one you have that has failed. |
| saumon |
Have you tried contacting the manufacturer? That part being listed as discontinued everywhere, maybe there's a substitute... http://www.aquasignal.com.au/navigation-lights/ |
| kend |
Thanks for the replys, I was hoping to find someone that had seen one left on the shelf. All the major marine parts dealers have discontinued them, but every once in a while a older item is kicking around waiting for a buyer. |
