posted 01-15-2015 11:45 AM ET (US)
Evinrude introduced their System Check instrument series in 1996. At the same time the engine wiring harness was changed to the Modular Wiring System (MWS), creating a very simple installation process: a dedicated connector on the wiring harness could be plugged into the connector on the System Check gauge housing, and wiring of individual conductors was reduced or eliminated.SYSTEM CHECK WARNING LAMPS
The System Check instruments contain four warning lamps or status annuciators. The four lamps are marked:
--NO OIL
--WATER TEMP
--CHECK ENGINE
--LOW OIL
OLDER ENGINES
In the c.1996 engines, the various sensors in the engine that monitored the conditions and signaled alarms were wired directly to the system check harness. There were four sensors:
--a oil pulse sensor in the Oil Mixing System (OMS) pump (NO OIL); if the pulse sensor did not detect a pulsed flow of oil that was occurring at a rate proportional to the engine speed, it signaled an alarm;
--a temperature sensor with preset switch closure threshold on the cylinder head (WATER TEMP); if the engine temperature exceeded the fixed threshold, it signaled an alarm;
--a vacuum sensor with a preset switch closure threshold in the fuel supply line (CHECK ENGINE); if the vacuum in the fuel line exceed the threshold, it signaled an alarm;
--a float level sensor in the oil reservoir (LOW OIL); if the oil level fell below the float switch fixed level, it signaled an alarm.
When any of these sensors detected an alarm condition, their electrical circuit closed to ground, and this electrical signal triggered various actions. The signals caused the associated lamp on the System Check gauge to illuminate to warn the operator. The signals activated an aural alert sounder to warn the operator. And, in the case of the temperature sensor, the signal was also able to activate the S.L.0.W. protection circuit in the engine to limit engine speed to about 1,500-RPM.
E-TEC ENGINES
When Evinrude introduced the E-TEC engine in c.2003 they maintained compatibility with their System Check Tachometer and System Check gauges. The E-TEC engine continued use of the MWS wiring, and a connector was provided for connecting a System Check gauge.
While the E-TEC engine maintained compatibility with this system, the manner in which the various signals in the MWS harness for the System Check gauge was changed. The signals no longer originate directly from the various sensors. Instead the sensors are connected to the engine mangement module (EMM). The EMM interprets the sensor status, and the EMM generates the warning signals on the four lamp circuits. The condition in the E-TEC engine which will generate one of the four warning signals are notably different, and many more sensors are employed. As a result, interpretation of the four warning lamps is different with the E-TEC than with older engines.
Also, the EMM of the E-TEC can stop the engine from running and prevent it from being restarted. This is a notable change from System Check. In the prior system, the operator was responsible for evaluating the warning indicators and deciding to stop the engine, and the only alarm condition that affected engine operation was the S.L.O.W. engine speed limit invoked when the temperature was overheating. Now the EMM can force the E-TEC to shut off if the alarm condition warrants.
The EMM Operator's Guide explains the meaning of the System Check instrument's four alarm indicator lamps, but it is useful to review it:
NO OIL indicates an oil delivery problem. The sensor is part of the Oil Injector pump. When this alarm occurs, the engine enters Speed Adjusting Failsafe Electronics or S.A.F.E. mode. In S.A.F.E. mode the engine speed is limited to 1,200-RPM. The engine can be run for as long as five hours in this mode without oil. This is intended to provide a get-home feature.
WATER TEMP (sometimes shown as HOT) indicates an overheat condition in either the engine or in the EMM itself. This is a notable change from the previous system. In addition, this indicator can be shown in two modes: flashing or continuous. If the indicator is flashing, the condition is dangerous for the engine to continue running. The EMM shuts down the engine completely. If the indicator is continuously illuminated, the engine enters Speed Adjusting Failsafe Electronics or S.A.F.E. mode. In S.A.F.E. mode the engine speed is limited to 1,200-RPM, but the engine can continue to run.
CHECK ENGINE (sometimes shown as FAULT or CHK ENG) indicates a variety of other fault condition in the engine. There are three modes. A flashing light indicates a problem related to the fuel system. The E-TEC will be shut off by the EMM and cannot be restarted. A continuous light with S.A.F.E mode indicates an engine problem, but the engine can continue to run at reduced speed while returning to shore. A continuous light with no S.A.F.E. mode indicates a problem has been detected which will require further investigation by a dealer to resolve as soon as possible.
LOW OIL indicates the oil level in the reservoir has fallen below about one-quarter-full.
MORE DETAILS
The relationship between various engine fault conditions and which System Check annunciator lamp will illuminate is given in the SERVICE MANUAL for the E-TEC engine in a detailed chart that maps approximately 150 fault codes identifications to illumination of a System Check lamp.
Further insight into engine faults can be gained by interpretation of the EMM LED indicator lamps. The functions of these lamps in also explained in the SERVICE MANUAL.
SUMMARY
The operation of the System Check instruments has changed with the E-TEC. The warning lamps are no longer directly operated by their sensors. The LOW OIL or NO OIL lamps function in a manner similar to the previous engines. The WATER TEMP or HOT lamp will now indicate either an engine or an EMM overheat. The CHECK ENGINE lamp now can indicate a vary wide range of problems. Also new with the E-TEC is the ability for the EMM to shut off the engine and prevent restarting; this is signaled by a flashing indicator light.
