posted 08-09-2015 02:00 PM ET (US)
Hi All....I have a 205 Conquest with SmartCraft Gauges. The sea water temperature reading is at about 163 degrees F. when in 88 degree sea water.
As part of troubleshooting, I've turn the function on and off in the tachometer and observed the reading go to "off" on the tachometer and speedometer. When re-established to on, the faulty 163 degree reading was still present.
It is a single motor installation with a Smartcraft Tachometer and Speedometer and (I presume) sensor in the paddle wheel. The speed indicator from the paddle wheel is working fine. The sea temp adjustment calibration is at 0 and can adjust 10 degrees up or down. There is no SmartCraft depth transducer.
Any ideas if this is a calibration issue or faulty sensor? Can the sensor be replaced/repaired without replacing the whole paddle wheel assembly?
Any help would be much appreciated.
Thanks.
Jim.
