posted 03-21-2002 11:30 AM ET (US)
Brian -Wow, great trip! What boat are you taking?
I doubt if there will be a lot of traffic in late April, early May. Water should be clear, mornings cool, warming in the afternoon. Many marinas may not be open yet.
If you go through the the Peconic Bays, you're going through some great areas (I've only got 47 years of boating experience in the Bays). You can get there through Shinnecock Inlet (or Moriches), then through Shinnecock Canal. The Peconic Bay charts are good - buoys positions accurately mark hazards, distances are fairly short, and you can usually see the next buoy from where you are. Depths are good.
Shinnecock Inlet is tough on the ebb with weather coming in - watch locals and watch before you cross.
Shinnecock Bay is shallow - follow the charts and bigger boats! Narrow by the CG station.
The Canal is fun... When the tide is higher in Great Peconic Bay, the locks stay open and flow into Shinnecock Bay. If Shinnecock Bay has a higher tide, you have to lock through - very easy, follow the traffic lights on the right side of the channel. The Canal also has many gas pumps and marinas.
Many marinas - look in cruising guides, etc. Many marinas have transient slips & showers. Not sure of availability of motels & marinas together. Greenport may be your best bet, or Shinnecock Canal.
We did East Rockaway to Great Peconic Bay in 1963... can't tell you much about it, I was only 10. But its doable and sheltered. Likely speed restrictions in busy areas.
Great South Bay is shallow - stay in the channel (I don't have a lot of experience there).
Another option is to run through New York and down Long Island Sound - its longer.
Jim
