Topic: dauntless 16 garage height
holmestk |
posted 06-02-2001 11:48 PM ET (US)
Could anybody with a new dauntless 16 tell me how high the boat is on the trailer? I am contemplating buying but need to know if I can coax it into my 7'2" high garage. Let me know which make trailer and what capacity (2300lbs?). Thanks!
triblet
posted 06-03-2001 03:11 AM ET (US)
It would also be helpful if the posters would include the distance from the bottom of the transom to the ground with the boat level. The same trailer can be set up with the boat at different heights.Also, watch out for stuff mounted to the console rail like GPS antennas. Chuck |
Barnett Childress
posted 06-03-2001 04:33 PM ET (US)
I checked height of mine when I had it to see if it would fit in garage. It measured around 6' 9" from ground to top of console rail. Don't know exact distance from bottom of transom to ground but boat was on a newer style Calkins roller/bunk trailer that caried her low between the wheels. Barnett |
blackdog
posted 06-03-2001 08:24 PM ET (US)
Just measured my 16 Dauntless. 7'4" from the ground to the top of the console rail. The trailer is level but I think the boat sits with the bow slightly elevated. I have a 2001 Load Rite bunk / keel roller trailer with 13’ tires. The keel is 18’ of the ground at the aft most point. The trailer is rated for 2200lbs. It will not fit in my garage but that is because the trailer is too long and I may install a removable tongue. You could crank the jack down and gain a few inches but the boat is very heavy and hard to move on the jack.Blackdog
B Bear
posted 06-03-2001 10:46 PM ET (US)
I am prety sure my 16 won't fit into my garage, I will check. I beleive the trailer is the key in being able to garage the 16. I would have to let the air out of my tires to get mine in. I'll check the height and report back. Bear |
DCPeters
posted 08-20-2001 06:58 PM ET (US)
how wide would the trailer be...isnt' that also a problem? I think it'd be too wide for a single door garage... |
Ventura16
posted 08-20-2001 08:06 PM ET (US)
I've been wondering whether my Ventura 16 (with the same hull as a Dauntless 16) would fit in the garage. I just went out and measured the trailer (the boat is currently residing on a lift). My Shorland'r trailer (single axle with bunks only) is about 90" across the widest portion of the fenders. My single garage doors have a 95" opening. So far, so good...guess I won't know about the height clearance until the next time I have the boat on the trailer.Tom |
B Bear
posted 08-20-2001 09:13 PM ET (US)
V16, I don't think you would have any problem with the dual console sit down configuration on the Ventura. The height is much lower than on the Dauntless with the center console. With is another matter, depending on the garage door opening. Bear
Ventura16
posted 08-20-2001 09:40 PM ET (US)
I hope you're right, Bear. I would love to get it into the garage for safe winter storage. Even though I had it securely covered last winter, the constant ice and snow buildup almost collapsed my cover. I ended up going out at least once a week and cleaning it off. I guess I shouldn't be worried about it in August, though! Tom |
blackdog
posted 08-21-2001 09:17 AM ET (US)
I think the other problem guys is the length. Most garages on newer homes are 20 x 20 (2 car). You really need a few more feet to back her in with the engine. The tongue of the trailer may get in the way. I was thinking of getting my tongue cut / made into a removable tongue but the height is another issue. L Bear is correct in the height. I think you will be OK. The center console rail sticks up on the Dauntless. There is a post on garages somewhere on this site. I wish we had a search option. Look for it some time this last year.
Ventura16
posted 08-21-2001 09:43 AM ET (US)
I went to the Shoreland'r site and discovered that my trailer is 18'6" long...with the extra length of the engine added, it will fit in the garage, but at a slight angle. I also checked the Load-Rite site...Blackdog, your trailer is only 18'3" long, but is 96" wide...that could pose a problem. I know that Shoreland'r makes a "swing-tongue" kit for their trailers. I don't know about Load-Rite or other manufacturers. I guess that each trailer/boat combination is going to vary somewhat. Time to get out your tape measures!Tom |
blackdog
posted 08-21-2001 02:14 PM ET (US)
Thanks Tom, I wasn’t able to find my trailer on the site – Bunk / Keel Roller. When I measured her it was close but I didn’t check the width! I came up with just over 20 feet. I can ‘t angle as the rest of my garage would be unusable.One more thing you reminded me about. You really need 9ft or wider garage doors. I have standard 8-foot door and lets just say you need to be a good driver. No room for error when pulling in your car. Forget about an SUV or pickup! Blackdog
holmestk
posted 08-26-2001 02:58 PM ET (US)
I picked up my dauntless 16 on Friday, and did manage to get it into the garage. With the tongue down low on the wheel jack, The top grabrail was just about 6'11" (a full three inches to spare!!) |
