Topic: Noisy hatch doors
Swellmonster |
posted 01-29-2003 11:49 AM ET (US)
I just got done reading a shoot out of 4 different Walkarounds, one being the BW 255 conquest. All the boats had issues of when hatch doors were dropped, noisy hatch doors that would spook fish for miles around, except for the grady, which had hyraulic assist. "I replaced mine twice in a year then I got rid of em" They also complained about whalers lack of freshwater washdown pressure/volume with only 800 psi, gradys was 1100.... The boat was horrible underpowered, either a single 225 or 250 opti, not getting on plane or staying till over 3200 rpms. But they did marvel at the solid quiet and dry punch when hitting a 3 foot chop. The Whalers test price was at $72Kish, and the Grady was 12K more, and they chose that one.
tully_mars
posted 01-29-2003 09:23 PM ET (US)
Not very big thinkers those writers. All you need is $5.00 of foam tape to quiet the doors, and $12k added to the Whaler will give you twin power which performs great and gives you the reliability you need for long trips offshore.Then, when you are at the same price as the GW it won't sink on you either. The water pump? not noticed how 800 psi on my Conquest was a problem. Maybe they are using the wrong nozzle. Tully Mars |
kglinz
posted 01-30-2003 12:25 AM ET (US)
I would expect most owners would install twins. The BW cataloge says a 225 is "Minimum HP to plane satisfactorily with a light load" Max HP is 450. |
triblet
posted 02-02-2003 09:13 PM ET (US)
EIGHT HUNDRED PSI!!!! That's gotta be wrong. Typical home water pressure is about 50 PSI. I know one ramp where the static pressure is about 125PSI, till somebody flushes in the bathroom, then it drops way down. (long pipe to tank on hill top, no pressure regulator).25 PSI would be adequate for washdown. Chuck
TheSkipper
posted 02-03-2003 02:04 PM ET (US)
The article in Boating magazine states that the 800 gph pump on the Whaler was not strong enough. It also praised the 1,100 gph pump on the Grady. |
Swellmonster
posted 02-08-2003 11:19 AM ET (US)
Triblet, Sorry for the typo, gph is the right term. |
