posted 06-20-2003 12:15 PM ET (US) Looking at one of these with a 115 Johnson on it. Anyone have any expereince with this boat? Thanks for any help.
Richard Quinlivan
posted 06-20-2003 03:27 PM ET (US)
I have a '95 Dauntless with a 125 Merc that I bought new. Great boat! I had a Montauk for 19 years previous. The Dauntless has reasonable room and of course has seats. It still fishes well and has all the normal Whaler advantages.
djahncke
posted 06-24-2003 04:51 PM ET (US)
I have a '95 17' Dauntless with a 115 Evinrude. It's a great boat and motor combination for the family. We use it for skiing, tubing and just plain boat rides. Most of the time it's on an inland lake but once in a while I'll take it out onto Lake Huron.
Maine whaler
posted 06-25-2003 07:35 AM ET (US)
Well I did it. I bought the boat. Pick up just before a week of vacation. I am planning to run it in coastal waters for island hopping with an occasional trip to one of the lakes around here. Anything I should watch for or any add ons you made that improved the boat?
Jarhead
posted 06-25-2003 08:52 AM ET (US)
Congratulations Main whaler..
Hope you have a great vacation with your new Whaler. :)
Maine whaler
posted 07-07-2003 11:46 AM ET (US)
What a great little boat. Launched like a charm and worked great taking trips to the islands. It came with a ski pylon which really helped when towing the kids tubing. Only question is that at slow speeds the boat seems to track back and forth 5 to 10 degrees. Anyone else have this problem or a solution?
JohnJ80
posted 07-07-2003 04:12 PM ET (US)
I had the same problem with my D15 with a 2003 Evinrude FICHT motor on it. I think it is related to weight aft.
You can move weight forward. I think this puts more hull in the water making it more likely to track. I also solved the problem by adding a Grand Island Marine Turbo Lift fin. I don't know if they make one for your motor - give them a call.
The Turbo Lift has turned down wing tips which seem to make the boat steer much straighter especially at low speed.
You might also want to make sure the motor is trimmed all the way in at slow speed.
j
dgp
posted 07-07-2003 09:12 PM ET (US)
My former boat was a '97 Dauntless 17 and it tracked at slow speeds as you describe. I believe this is a common trait to all deep vee hulls and is normal with the Dauntless 17. I don't have this condition with the classic Montauk.
andymanning
posted 07-12-2003 12:30 PM ET (US)
I have a 1996 dauntless with Johnson 115, bought late fall of last year. Moved up from a 13 ft. 1968 whaler. Spent a week on Maine lake for vacation with family. Very happy with performance as family boat and for fishing. I would check out the posts on the cockpit scupper valves. Mine are letting in a lot of water on ladder side. It is filling bilge. As a result I discovered cracked fiberglass and faulty plug leading to gas tank. I think water was stuck in there over the winter and expanded since I did not even know about the potential problem. I want to take inshore rides, Portsmouth Harbor, later in the year. Good luck with your boat.
