posted 07-30-2003 01:54 PM ET (US)
I have an '00 sport 13 and am really glad I added a "bottom machine." I mounted it on the flat surface on the right side of the console, and I am very happy with the mount. I love being able to see what the depth is.The brand I ended up going with, after a little research, was Lorrance [which I know I have spelled wrong]. I already had a handheld GPS with mapping, so I just have what you are talking about: depth and "fish finder," in black and white. I did not get speed measurement capability because I can get that off my GPS too.
I am happy with the machine except for one thing, and it is an installation error I think [even though I had it "professionally" installed].
I bought the machine from the local West Marine store, I think. They recommended a free lance installer who did a real nice job and knew what he was doing: it looks good and worked great, for a while.
But he didn't read the installation instructions first and neither did I. The instructions said to put a switch between the battery and the machine, so you can cut power to the plug. Otherwise, it corrodes even if it is disconnected from the machine: if the plug has electricty going to it, even if not connected to the machine [or maybe only if not connected to the machine] it will corrode.
My machine, which I have had maybe a year and a half, now intermittently looses its signal or goes blank. I think it might be corrosion in that plug or wire, which I can see. I have helped it, I think, by cleaning down into the pin-holes with naval jelly; but it still goes out, and I am curious that it goes out when I am pounding through some surf at high speed.
If I get a new one, I may change companies. I will definately have a cut off switch on all power running from my battery, which is a good thing to have anyway.
I guess I will look to get a new cable, now, and add a cutoff switch.
Good Luck!
