posted 10-03-2003 07:57 PM ET (US)
dvanken -I have also seen (in the Les Cheneaux Islands - Northern Michigan) how they store their wooden Chris-Crafts this way.
For your whaler - I'd use a third 6x6 across the middle...don't cut a notch out of the 6x6 - use chocks from the ends to make the "V" on top.
I would then use two flat boards to lay across the three 6x6's in the "V"...this will allow for keel support along the length of the keel. These need not be screwed in, so long as the chocks are secured to the 6x6 - the weight of the boat should hold them in place.
As Whaler131 suggested, I'd also leave the hoist cables attached all winter long for added security.
In the Les Cheneaux, they simply put all these timbers in the rafters of the boathouse above the boat for the summer - but depending on construction, this may not be feasible for you. I have also seen these materials stored under the "deck" of the dock on the way up to shore...(these are permanent dock systems...they just built hangers underneath and hang the timbers there - have also seen this as a cool place to store an un-used canoe during the summer...)
Good luck.
Dave
