posted 04-05-2004 06:24 PM ET (US)
Eddie,
What engine are you looking at? 2-stroke or 4?
I have the 90 2-stroke without a jackplate and right now I don't see the need for one. If I were to purchase one I would go with the hydraulic over the manual. I am assuming that you want to raise the engine to run in shallow water. If not, then the position of the engine seems to be in the optimal hole for the performance I am looking for. Running across flats at high speeds has always bothered me for some odd reason. I would hate to hit a submerged hard object that would damage the hull or engine, not saying that I haven’t run across them before and I probably will do it again. A jackplate would just encourage me more.
My experience is that once you are in the flats a good trolling motor or push pole would be money well spent. For the extra money that would be spent on the jackplate I would consider an investment in a power pole.
Don
