Topic: 2000 18' Outrage
Mussels |
posted 04-04-2004 10:05 PM ET (US)
I am considering buying one of these and I believe that 2000 was the only year Boston Whaler made this particular model.(I know they made 18 ft outrages in the past but they are not the same as this) I also notice that there seems to be alot of these for sale. It looks beautiful and appears to meet my needs (fishing in Barnegat Bay and outside within 15 miles of the inlet).Does anyone know why Whaler only made this model for one year ? and; Does anyone one have any experiences/info/recommendations regarding this boat? Thanks
Ventura16
posted 04-05-2004 09:21 AM ET (US)
My neighbor has a 2000 Outrage 18...great boat. We've spent lots of hours on it in all kinds of conditions. It is a very beamy boat (for it's length) and rides beautifully. I don't know why they only made them for a couple of years...rumor has it that they cost almost as much to make as the Outrage 21 and had to sell for quite a bit less...probably wasn't all that profitable. His boat has the Optimax 135...it maybe a tiny bit underpowered, but not much. There are a couple of 2000 Outrage 18 owners on here...hopefully they'll chime in.Tom |
Sal A
posted 04-05-2004 09:37 AM ET (US)
This boat has been for sale for a while. And i was very tempted before I bought my new boat. New Providence is around the corner from me, and if you wanted me to check it out for you I would be happy to. http://www.yachtworld.com/core/listing/pl_boat_detail.jsp?&units=Feet&checked_boats=1130081&slim=broker&&hosturl=gkys&&ywo=gkys& |
prxmid
posted 04-05-2004 03:39 PM ET (US)
The 1999 is the same boat. It is the biggest 18ft boat you will find. It does better with a 150hp, better still with 175.It was expensive for BW to build and they wanted to make the OUtrage line more of a true offshore line at 21ft and up. I believe I could sell minw for more than I paid for it 3 years ago |
roofer
posted 04-06-2004 09:20 AM ET (US)
I own a 2000 18ft outrage. It is a great boat. I have a 135 optimax on it. I have had some trouble with the motor, but that is a mercury issue not a hull issue, meaning almost all of the newer whalers are going to have a Merc and that is something you will have to deal with most likely. I use the boat to fish on lake Michigan and to water ski on inland lakes it does both well. It handles rough water especially nice with I have appreciated that on more occasions than I care to mention. I think it is a great boat that can do many different things well especially given it size of only 18ft. I hope this helps. |
RonB
posted 04-06-2004 11:38 AM ET (US)
I also own a 2000 18 Outrage, I have it in the water already on the Hudson River (March 30th). I have the 135 Opti as well and so far no problems. I love the boat for what I use it for (fishing with my friends, and early evening cruises with my wife and kids). The boat is over 18 ft at 18'4" and it has a huge beam at 8' 3". It rides like a bigger boat and has a 90 gallon tank. The boat is heavy so consider this if you want to tow it. I have a dual axle LoadRite trailer and guess I am close to pulling my max rating of 5000lbs when the boat is loaded with gas (Boat ~ 2500lb, Engine ~ 550lb, Trailer ~ 1200lb, plus 90 gallons of gas). I only pull a short distance but what need to upgrade my tow vehicle if considering longer trips. As far as options, I have a bimini and I had a lounge platform installed in the bow along with a cushion for cruising. Dual batteries, leaning post, raw water washdown, 94 qt cooler, fish boxes, and eight rod holders (2 on each gunwale, 2 on the leaning post, and another 2 on the bait table mounted midships in the stern (along with another four in front of the console while underway)) make up some of the amenities in the boat that make this such a great fishing machine. What would I add if I could? Well, I think the boat could use a pair of Bennett Trim Tabs to assist in keeping the boat on plane at lower speed. Being in TG_190's Nantucket and seeing the difference his Lenco tabs made in the ride of that great BW convinced me that tabs would help most center consoles in that size range. Other than that, a factory T-Top is available which would be great with canvas for an enclosure for cold weather fishing. Other than those two biggies, there's not much more the boat needs. When it comes time to repower I will look for a larger Opti/other Merc. The boat is rated for 200HP so I will consider maxing it out at that point. WOT at 5200 RPM last year with a SS Vengeance 17P prop was 41.7MPH on GPS. While heading to fishing grounds I cruise at a respectable 30MPH at around 4000RPM. This year I switched to a Black Max 19P Aluminum and haven't had a chance to read new performance numbers. I switched to an aluminum prop to help save the lower end of the Opti in case I hit any debris in the river which is notorious for driftwood in the spring and after heavy rains. Shifting is also much smoother. If you and a buddy like to fish, in the size range you mention, in the waters you mention, you will not find a more solidly built boat. I saw one in the New Jersey edition of "The Fisherman" recently. Hope this helps a bit. Ron |
Mussels
posted 04-07-2004 08:30 PM ET (US)
Thanks to all who replied. Sounds like this is the boat I've been looking for. |
Moose
posted 04-11-2004 08:22 PM ET (US)
I'm an owner of a 2000 Outrage 18 with a 150 Mercury Opitmax XL. Great fun, I've trailered it to Hatteras, N. C. and the Les Cheneaux Islands many times. Generally I've towed it with a Expedition, but last summer a Explorer with the 4.6L V-8 did very well. Love everything about the boat, except that motor. Found the boat new in 2001 at a dealer here in Michigan, the first use in April 2001 set off the temp alarm. The dealer looked at this problem many times over that summer and did some type of retro-fitting of either additional water intake lines or larger ones, under warranty. The problem has popped up a couple of other times during the two following summers while at idle speed. The feed back from the dealer is that Mercury has reported other like problems with the same motors. During 2002 and 2003 a fuel starvation issue came up. Any thing less than 2000 rpm's would occasionaly cause a stalling problem that required the primer bulb to be squeezed several times to get some gas to the motor. The dealer has looked at this problem numerous times and replaced various items in the gas line, but, has not been able to tell me it's something that I'm doing wrong, or something with the gas, oil, etc., as of last fall the problem is still there. Not fun while in a no wake zone situation. Great boat! See about checking the repair history, if any, on that motor, if's it a Mercury. Good luck, |
prxmid
posted 04-11-2004 08:59 PM ET (US)
Like Mooose, I have had annual TPI problems, occasional temp gauge issues and rarely, it stalls at idle.Never left me stranded though. Get a good computer check of the Optimax. |
RonB
posted 04-12-2004 12:47 AM ET (US)
Yes, prxmid brings up a good point, that diagnostic computer. It can tell you a lot, if your mechanic is going to hook that device to the motor, ask him if you can hang out and get a tutorial on the computer or glance over his shoulder. I bought my 135 Opti with 50 hours on it and the hours checked out when the tests were run which I was invited to watch. In the 50 hours I've since put on the motor I've had no heat problems (I do a lot of trolling in New York harbor as well) but I had it stall once when going from full reverse to neutral. It started right up though,so no complaints. I find it interesting that the same block is used for the 115, 135, 150, and 175 Merc. Does that mean the lower hp motors are over engineered? They have a slightly lower WOT as well ~5500RPM as opposed to ~5750RPM. I'll be fishing on a 2003 18 Dauntless later this week. First time I'll have been on a Dauntless. Given it is the same size as my Outrage and I'll be fishing both inshore and near shore off the coast of Florida, I'll try to give a comparison when I return. Tight Lines. Ron |
Ventura16
posted 04-12-2004 09:22 PM ET (US)
I'm happy to report that I have just joined the ranks of the 1999-2000 18 Outrage club! I just made a deal to buy "HugeHugo's" Outrage. It is a terrific boat in amazing condition...like many of our Michigan Whalers. The short season combined with that nice fresh water means very little deterioration. As you may remember, Hugo had so many problems with his 135 Optimax that he repowered with a shiny new Honda 200 4-stroke. He decided to put the 200 on his new Scout 222 Dorado...a dual-console to make his wife and daughter happy. He ordered the Scout with a Honda pre-rig, so he left all the Honda rigging, cables, gauges, etc. behind for me. After much discussion with him about the performance and weight of the 200, I've decided to get a brand-new Honda 150 4-stroke for the boat. The all-new design of the 150 is 115 lbs. lighter than the 200 and features Honda's VTEC Variable Valve Timing technology. He felt that if the 150 had been available when he repowered that he would have gone that route...but since his only choice at the time was the much heavier 200, that's what he got. He didn't feel that the 200 was too much weight for the 18 Outrage, but didn't feel that the boat was underpowered even with the 135 Opti. As he said, he didn't repower because the boat was underpowered...he did it for reliability. The boat is well equipped with the fishing package, livewell, coaming bolsters, bimini, a tandem Shoreland'r trailer and a full complement of Raymarine electronics. I am one happy camper! Tom |
Moose
posted 04-12-2004 09:47 PM ET (US)
Congrats Tom,A tandem trailer. I'm hearing and reading alot of that lately. Am I the only Outrage owner out here with a 18 footer on a single axle trailer? Any opinions about pulling a 2,500 pound boat and a 450+ pound motor without tandem axles? |
Ventura16
posted 04-12-2004 10:01 PM ET (US)
Thanks, Moose! I am so excited...I can't wait until the boat is rigged and in the water...but it will be a few weeks yet.My neighbor also has a 2000 18 Outrage. His has a 135 Opti and sits on a single axle Shoreland'r trailer. He has towed it from Detroit to Miami and back a few times with no problems. I don't think it's a big deal, but tandem axle trailers do tow a little easier. And, if you should have a flat, it's not as big a problem. I wouldn't worry about it if I were you. Tom |
RonB
posted 04-18-2004 10:29 PM ET (US)
Tom,Congratulations on the purchase of Hugo's Outrage! He had (and now you have) a unique setup with the Honda as the choice for power. I will be extremely interested in hearing how you like the performance of the 150 Honda 4 stroke. When reliability becomes an issue for me (hopefully many years down the road) I will be faced with a decision of either staying with Mercury or going to another vendor. Knowing that you are out there with that 150 Honda will be helpful. Does your Outrage have trim tabs on it? I've been kicking around the idea for the last 6 months or so and am wondering if any of our members have tabs on this model Outrage? Best of luck with it and welcome to our "smaller" club! Oh, BTW, I just got back from Florida where small craft advisories kept me from fishing in a 2003 18 Dauntless, but I did spend a day fishing in the Port St. Lucie River on the cutest little 1995 13 ft Dauntless (40HP Johnson). She may wind up becoming the little sister to my Outrage as I'd love to introduce my kids to boating with that sturdy little craft. Ron |
Ventura16
posted 04-19-2004 09:58 AM ET (US)
Thanks, Ron! I'm really getting pumped up about this boat. I don't actually get it until 5/1, so I'm spending my time arranging the repowering logistics...and plotting the purchase of additions and accessories.The boat does not currently have trim tabs, but I will probably add them at some point. I am a big believer in them...we have them on our Grady. They really help to control the attitude of the boat, especially in heavy seas. Since the 18 is so beamy, I think it should be pretty stable (side to side), but tabs are great for getting the bow down. I am most familiar with Bennett tabs, but am thinking about Lenco's for the Outrage because of the ease of installation. I know that John Flook (kingfish) has had great luck with Lencos on his 22 Outrage. I'm also really excited about the prospect of Honda power. I love Honda products and have had numerous Honda cars, motorcycles, ATVs, generators, lawn stuff....they've all been first rate. The only bummer is the $$$...they are expensive! I guess all new outboards are pricey, but the Hondas are really up there. But I'm sure I'll get over the cost once it's on the boat and purring along. I wish you good luck with your Optimax! My neighbor has had the identical boat/motor combo that you have since 2000 and has had very little problem with the Opti. I think the key is how you use it. From what I've read, they need to be run hard regularly. As a salmon fisherman, I spend all day trolling at 2.5-3 mph...so I think the 4 stroke will be much better for that application. I'll post more info as I soon as I get the boat in the water and get some real performance numbers. Tom |
Ventura16
posted 04-20-2004 09:01 PM ET (US)
I also posted this in the Nantucket thread, but thought I'd put it here too:Ron, I just called Mills today about a forward shelter for my new 18 Outrage...they don't make one and none of their existing ones will fit. :-( But maybe if both of us want to order one, they will re-consider. And if anyone else wants in on the deal, so much the better. Tom |
