Topic: anchor light/ new Montauk
Offset |
posted 07-11-2005 11:59 PM ET (US)
Should you be able to use the anchor light with the canvas top opened using the hole with flap for an exit for the pole? I believe my top was installed to far towards the bow placing the hole about 10 inches off. Would like to get some firepower before I call the dealer. Thanks!!
bigjohn1
posted 07-12-2005 05:03 AM ET (US)
I have a 2005 170 MONATUK with the Great Lakes brand bimini and use my anchor light all the time during those 0400 launches to the fishing grounds. By all means you should be able to use your light with the Bimini canvas "up". That is the whole reason for the slit/flap towards the front of it. |
royaloakwhaler
posted 07-12-2005 01:52 PM ET (US)
Does your top slide in stainless rails? If so, you might need to adjust the poles fore/aft to center the canvas hole over the light pole. |
Offset
posted 07-12-2005 06:36 PM ET (US)
This weekend I will try adjusting the rails. I'll give it a shot. I wanted to be sure about the flap.Thanks for your help!!! |
