ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers Bimini Top Stowage - 2006 170 Montauk
Author | Topic: Bimini Top Stowage - 2006 170 Montauk |
Mel Wallace |
posted 09-14-2006 08:46 AM ET (US)
I have a new 2006 170 Montauk and I'm looking for a way to stow the Bimini top in the down position for trailering without it laying against the gelcoat. Have tried bungy's around the rails, but looking for a more elegant solution. Got any? Thanks. |
Speedo66 |
posted 09-14-2006 12:00 PM ET (US)
I have a similar situation when my bimini is in the down position. I have installed a piece of ribbed plastic wire loom tubing over the bimini tube where it touches the gelcoat. So far I have no marks after a few weeks in use. I also considered a piece of foam pipe insulation. Steve |
Marsh |
posted 09-15-2006 10:08 PM ET (US)
Two nylon dog collars from Dollar General @ $5.00 each hold bimini to top of side rails: one port, one starboard. Had mine for over a year. I did have one failure while in rough water in Barataria Bay, LA. The pipe insultors saved the day for the gelcoat then. Marsh |
Marsh |
posted 09-15-2006 10:09 PM ET (US)
That should have been: pipe insulators, not insultors, LOL. Marsh |
bigjohn1 |
posted 09-15-2006 10:23 PM ET (US)
Yep - the dog collars are the best way to go. Cheap, easy, and their work great. |
Mel Wallace |
posted 01-03-2007 07:45 PM ET (US)
Liked all of your suggestions(especially the dog collars), but decided to take things one step further and make my own. I tow 4 hours each way up north in Michigan, so I made two supports from 3" PVC, toilet basin bases and saddle elbows. I then set them on a couple of rubber baseball bases. It allows me to lower the bimini top below the side rails and cover the boat with my mooring cover for towing. Take a look if the photo upload works: http://www1.snapfish.com/thumbnailshare/AlbumID=147374243/a=44544814_44544814/t_=44544814 |
Mel Wallace |
posted 01-03-2007 07:53 PM ET (US)
Let's try the photo upload again: http://www1.snapfish.com/thumbnailshare/AlbumID=147374 |
Mel Wallace |
posted 01-03-2007 08:12 PM ET (US)
OK, let's try photobucket: http://i125.photobucket.com/albums/p67/mwallac1/IMG_0346.jpg http://i125.photobucket.com/albums/p67/mwallac1/IMG_0345.jpg http://i125.photobucket.com/albums/p67/mwallac1/IMG_0342.jpg http://i125.photobucket.com/albums/p67/mwallac1/IMG_0341.jpg |
Mel Wallace |
posted 01-03-2007 08:20 PM ET (US)
Photo uploads worked that time. Sorry - rookie mistake. The bimini top can then be bungied to the saddle tees. Provides a solid support - everything available at Lowes(baseball bases at sporting goods store). See ya. |
