posted 02-19-2008 09:18 AM ET (US)
Masbama,IMO, any transom mounted xtucer will cause some degree of "rooster tailing". The Lowrance Skimmer xducer on my Dauntless throws some spray but not to a degree that I find objectionable and it does not throw water all over the transom and motor.
The installation manual for a Skimmer is available for download from the Lowrance site. The instructions are pretty decent but not all inclusive.
I recommend mounting a piece of Starboard lumber to the transome and them mounting the xducer to that. That way you can make changes to the mounting without drilling several holes in your transom. Although the manual tells you to mount the xducer level I've had perfect sounder performance with the xducer mounted a little bit off level. This allows a little less of the xducer to be in the water while on plane and, IMO, reduces xducer rooster tailing.
I've observed boats with the xducer mounted so that it is completely below the surface while on plane. This just creates unecessary drag, degrades sounder performance, and causes a spectacular rooster tail.
The great majority of boats use transom mounted xducers with great success. You can do the same but it requires a little bit of adjusting to get it right.
