Topic: Scuppers for Conquest
tesija |
posted 09-20-2009 08:08 PM ET (US)
Who supplied the scuppers for the 1999 Conquest 21 foot. The dealer is telling me that I need to replace the whole system-tube and all, when all I need are the rubber flaps and the ring that holds them on. Any info will be appreciated.
David Pendleton
posted 09-21-2009 06:56 PM ET (US)
I replaced mine long ago with stainless, but I believe they were originally Perko.I have three Perko #0365DP, new-in-box. Check them out via google. If they'll work for you send me an email. |
tom976
posted 09-29-2009 01:02 PM ET (US)
You can just go to your local boating store and match up replacements from the originals. Thats what i did with my 1997 23 conquest |
tesija
posted 09-30-2009 08:54 PM ET (US)
The boat is overseas, so I was hoping to get a part number from a forum member. |
jollyrog305
posted 09-30-2009 09:05 PM ET (US)
Thru-Hull, Plas 2" Scup w. Flap - #0628081, http://www.whalerparts.com/Diagrams/1999/210%20Conquest/pb210cq2.pdf. Looks like it is the whole unit though - http://www.whalerparts.com/Diagrams/1999/210%20Conquest/pb210cq1.pdf |
HawaiianWhaler
posted 10-01-2009 08:18 AM ET (US)
tesija - If you just want the "valve" this may be it:[url=http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/50156/377%20710/0/scupper/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=scupper&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=scupper&isLTokenURL=true&storeNum=11&subdeptNum=70&classNum=77]Scupper Valve[/url] That "valve" goes with the below, which was an exact replacement for one on my 1999 Conquest 21 so it should fit on your boat too. Stainless or bronze would, of course, be 'better' but I didn't want to have to replace all scuppers when only one needed it. [url=http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&keyword=593442&jspStoreDir=wm51&productId=50153&resultCt=1&catalogId=10001&ddkey=SiteSearch]Thru-Transom Acetal Scupper[/url] If you decide to replace the whole scupper, suggest you also have a couple new stainless hose clamps on hand. Good luck, aloha. |
David Pendleton
posted 10-01-2009 06:57 PM ET (US)
Go with stainless, you'll be glad you did. I did all three of mine and the bilge pump outlet.http://home.comcast.net/~davepen/images/other/transom.jpg
David Pendleton
posted 10-01-2009 06:58 PM ET (US)
Oof. http://home.comcast.net/~davepen/images/other/transom.jpg
SJUAE
posted 10-01-2009 10:28 PM ET (US)
tesija I just had one of the flappers go on my 2006 210 The whole head sheared off leaving just the tube, looks like brittle fracture. The flapper was screwed into the flange on the scupper I looked at Perko and Attwood but it seems quite hard to find the replacement as BW seem to use ones with a smaller shank than the ones typicaly shown online My fishbox pump-out has a threaded elbow directly attached to complicate it further I would also suggest going to S/S Regards Steve |
26Out99
posted 10-03-2009 04:46 PM ET (US)
I changed every thru hull with Orcas Stainless. Great products. I think Southco recently acquired Orcas. |
