ContinuousWave Whaler Moderated Discussion Areas ContinuousWave: Post-Classic Whalers Adding a windlass to a Conquest 275 - what type?
Author | Topic: Adding a windlass to a Conquest 275 - what type? |
scottwaldrum |
posted 11-04-2010 04:38 PM ET (US)
Hi Guys, The new boat doesn't have a windlass so I need to add one. The only thing I know about them is that I want one. So, the questions would be: 1) What windlass does the conquest have from the factory and for anyone with that boat, does it work well? 2) Anyone adding one aftermarket? What did you choose. Any other feedback welcome, trying to not do this twice... scott |
SJUAE |
posted 11-05-2010 01:43 AM ET (US)
Scott According to whalerparts a 2002 Conquest it was a Lemar Horizon 600 http://www.whalerparts.com/Diagrams/2002/275%20Conquest/PB275CQ22.pdf http://www.whalerparts.com/Diagrams/2002/275%20Conquest/PB275CQ24.pdf [urlhttp://www.lewmar.com/cms/assets/1/literature/horizon600-900.pdf[/url] You may need some other deck hardware and also check the wiring diagrame etc on whalerparts and the exact year of your Conquest Regards |
RevengeFamily |
posted 11-05-2010 06:19 AM ET (US)
My 1999 280 Conquest came with as Steve stated a Lemar Horizon 600. The windlass has not given me any trouble and has never failed to pull my hook. I normally have the engines idiling and bump one or the other in and out of forward to assist the windlass in getting directly over the top of the hook. Then it's all windlass, I slowly increase the strain on the anchor rode until the hook pops loose. Like I said, the 600 has never not function well. Norm |
27 Black Dog |
posted 11-05-2010 09:06 AM ET (US)
Scott, I have a 1991 27 Walkaround thatI just put a Lewmar Pro-Fish 1000 on and love it!!!. I know that this windlass is probably a little too much for this boat but I was at the Anapolis boat show last year and just could not pass up the deal, 60% off. One thing that you have to know when purchaseing a Lewmar windlass is that it will only accept a specific type of chain, otherwise it will jam up on you. |
scottwaldrum |
posted 11-09-2010 12:04 AM ET (US)
Thanks guys. Steve, thanks for those links, hadn't seen whalerparts before. That should give me what I need. Norm, looks like you'll be a good resource for me. Already answered two of my questions.... Will let you know how it goes... |
scottwaldrum |
posted 11-09-2010 12:39 AM ET (US)
OK, did a little checking: In 2004 the conquest 275 spec'd a "RP/CHN Marlini Lo-Pro 12v 700w" which I assume is the Lofran Marlin model: http://www.lofrans.it/english/intro.html Previously (2002) the Lewmar Horizon 600 was used.
So, 1) vertical vs horizontal on the conquest 275?
Scott |
SJUAE |
posted 11-09-2010 03:50 PM ET (US)
Scott I looked at whaler parts for your 2004 Conquest 275 http://www.whalerparts.com/Diagrams/2004/275%20Conquest/ PB275CQ22%20Model%20(1).pdf It shows a mid year change 2003/2004 on the anchor locker. The newer smaller chain/rope locker you can only use a vertical drive as the horizontal drive sat below deck in the larger locker. The new smaller locker the windlass motor I assume is below deck and access from the cabin with just the plate above deck feeding through a chute to the smaller locker You need to be sure what type of locker you have Regards |
scottwaldrum |
posted 11-10-2010 02:11 PM ET (US)
Thanks Steve, That explains why they switched windlass types. It didn't make any sense to me. Off to figure out which locker I have. Appreciate the help. scott |
number9 |
posted 11-11-2010 01:00 AM ET (US)
Scott, If your Whaler was designed to allow a horizontal you should consider one with a rope chain gypsy and a capstan/drum. Kind of like two tools in one with small additional cost. Bill |
