SantaMonicaWhaler |
posted 05-24-2011 05:32 PM ET (US)
I have a 2007 240 Outrage with twin 150-HP Verado engines. While docked (and presumably while not docked) the boat lists somewhat to the port side. The botton paint, however, was evenly done on both sides, with the result being that the paint is about one to two inches above the water line on the starboard side, but right at the waterline on the port side. Looking throught [some] diagrams, there does not appear to be any tank on one side or the other (fresh water or waste), and both batteries are immediately below the center console. The gas tank is about 3/4-FULL. I haven't owned the boat long enough to compare to prior years and with empty full tank.[Do readers have] any thoughts on a potential problem that may be lurking underneath, or should I simply ignore the [list]? Thanks in advance, Mark
