Palomino wrote:If the trailer starts to drift at highway speeds you've got it loaded too far forward and it can be a real safety factor.
Towing a boat trailer is quite different from towing other types of loads on other types of trailers. Generally a boat on a trailer will have a rather low center of gravity, and the wind area will be much less than many other types of trailer with much higher profiles and much greater surface area for the wind to work on.
The usual advice for distribution of the weight load onto the tongue and axles for a boat trailer is to have about 5-percent to 10-percent of the total towed weight of the trailer bearing onto the hitch.
In order to determine the weight distribution, the best method is to weight the load on all the axles, which means:
--the front axle of the towing vehicle
--the rear axle of the towing vehicle
--the combined axles of the trailer
The process is to weight the towing vehicle and trailer simultaneously on three scales, recording the three measured weights. Then drop off the trailer, and return to the same scale and weight the two axle weights of the towing vehicle. This produces five measured weights. From these five measured weights all sorts of information can be derived.
For advice on how to deduce the tongue weight from the measurement process described above, see the article on that subject which illustrates the relationship between those five weights in detail in the archives of the website at the URL:
Boat Weight from Certified Scalehttps://continuouswave.com/ubb/Forum1/HTML/016667.htmland a similar discussion at
Boat Weight; Using CAT Truck Scaleshttps://continuouswave.com/ubb/Forum8/HTML/001476.htmlThere is absolutely no point in worrying about tongue weight until you actually measure the tongue weight and the total weight of the trailer and boat as being towed. Without real weights there is no way to assess if the tongue weight is in the appropriate range other than to just make a guess at the weight of the trailer and the weight of the boat. Guess are just that--a guess. Another thread in the archives discusses methods for deducing towed weight. See
Estimating Towed Weighthttps://continuouswave.com/forum/viewto ... 986#p14986One problem for this particular boat trailer: the VIN sticker does not list the trailer's weight. Also, the dual language French-English seems to suggest it was made in Canada.
