Here is my plan:
- I will use the Minn Kota RTA-17 quick release bracket that requires 6 x4-inch base plate to be attached to the bow using four 1/4 x 20 bolts, and to locate the base plate so that the shaft of the troller motor clears the hull by 1.5-inches;
- because of the curvature of the bow, I do not believe the embedded reinforcement in the hull extends to the edge [of the hull at the bow], and therefore I think it is not possible to attach the base plate directly to the boat;
- a different mount, a side mount is available and is an option;
- I will make a simple extension platform out of 1-inch thick KING StarBoard to gain the extra three or four inches needed;
- the KING StarBoard extension platform will be fastened to the hull by machine screw fasteners that will be threaded into tapped holes in the embedded phenolic board reinforcement in the hull;
- I have information that phenolic board thickness is 3/8-inch, it should be drilled and tapped for the 1/4-20 machine screws;
- the Minn Kota base plate will then be attached to the KING StarBoard extension;
- I expect to be able one of the fasteners for the Minn Kota base will be able to align with one of the fasteners for the extension, so at that location I could use a longer machine screw and attached the Minn Kota base to the embedded phenolic material in the Unibond hull.
Please give me answers to these questions:
Q1: is my plan sound?
Q2: should I drill and tap all the way thru the phenolic and into the foam?
Q3: if I drill into the foam, what sealant should be used to seal off the foam?
Q4: is there a way to drill beyond the phenolic board and fill the hole with epoxy or caulking?
Q5: for the one-inch thick KING StarBoard extension, what width should the board be to distribute the force of the trolling motor hanging off the edge?
Q6: how many screw fasteners will be needed to fasten the KING StarBoard extension to the hull in order for me to feel safe?
Q7: is use of 3M4200 Adhesive (as recommended by some unidentified source) to bed the KING StarBoard material to the gel coat of the Unibond hull (in order to add strength to the attachment of the extension to the hull) a good idea?
ASIDE:
Other than one 2003 thread, I could not find any prior discussion about mounting a trolling motor on the bow of a 2007 200 DAUNTLESS. If there are prior discussions on this topic, please point me to them.
For some reason, the limited information I was able to get from Boston Whaler was not accessible directly from them but was only accessible by being relayed through a dealer.
Mounting a trolling motor to bow of Dauntless 200
by Redfish12 » Sun Sep 29, 2024 6:24 pm
I grew-up using a Boston Whaler. I I just bought a 2007 200 DAUNTLESS. So far, the 200 DAUNTLESS seems like an admirable boat so far. I plan to use the 200 DAUNTLESS mostly for inshore angling. The installation of a bow mounted Minn Kota Riptide Terrova trolling motor with a feature called SPOT LOCK will be the first major upgrade.
