1984 MONTAUK 17: Adding Bow Platform
cinegamma
Postby cinegamma » Fri Apr 21, 2017 11:03 pm
On my 1984 Montauk I have a wooden platform directly in front of the console that rests on the lip inside below the gunwale. I'm currently using strips of a non-slip material (originally intended to go under rugs on hardwood floors) on each side to protect the gel coat, however this is proving difficult to stay in place and is not the best solution. Does anyone have a recommendation or suggestion of what I could place on each side to protect the gel coat? Ideally it would be something that would adhere and still be removed later without damaging the boat. Here are some photos of what I'm referring to. In the second photo I've added blue painters tape to the area in question that needs to be "protected".
https://goo.gl/photos/huWSnNdJXsHWijYK7
https://goo.gl/photos/m4LZn7XktoBKzuTK7
Re:1984 MONTAUK 17: Adding Bow Platform
Postby jimh » Sat Apr 22, 2017 9:12 am
Thin neoprene rubber with an adhesive backing could be used. See
https://www.amazon.com/Neoprene-Rubber- ... ve+backing
Re: 1984 MONTAUK 17: Adding Bow Platform
Postby Phil T » Sat Apr 22, 2017 11:16 am
A narrow strip of starboard would work as well. I would attach to the deck, countersinking the screws.
Postby jimh » Mon Apr 24, 2017 8:03 am
I like Phil's approach: modify the modification (the new deck) rather than the boat.
Steel Workin
Postby Steel Workin » Mon Aug 14, 2017 8:59 pm
This is what we did. Not for the bow but it works well.
Postby jimh » Tue Aug 15, 2017 9:55 am
Nicely done.
