1981 Outrage V-22 Sterndrive
HappyHour
Postby HappyHour » Fri May 07, 2021 5:41 pm
I am looking for a bigger Outrage, preferably with Whaler Drive. I now came across a 1981 Outrage V-22 with Sterndrve.
Q1: Has any reader experience with an c.1981 OUTRAGE V-22 Sternrdive?
A 1981 boat is now 40-years-old. This particular boat seems to be well looked after.
Any comments on this particular model are very welcome.
--Jan
Re: 1981 Outrage V-22 Sterndrive
Postby jimh » Fri May 07, 2021 5:45 pm
The sterndrive option puts a very big hole in the transom. To convert to outboard engine power will required substantial modification.
Q2: Are you anticipating remaining with a 40-year-old sterndrive?
Another name for a sterndrive: "a mechanic's annuity."
HappyHour
Postby HappyHour » Fri May 07, 2021 5:58 pm
The sterndrive is from the early 1990's, but that is still old. If anything I would probably put in another sterndrive and not switch to an outboard configuration. This is the way the boat was set up--I suppose--and I would stick with that.
Q3: Why would you consider the sterndrive to be a money pit?
Postby Phil T » Fri May 07, 2021 7:30 pm
Many owners dislike the inboards.
While they take up a bit more interior room, the closed transom is nice.
Given the scarcity of loose outboards, I would say its a good thing you have a sterndrive.
HappyHour
Postby HappyHour » Sat May 08, 2021 7:34 am
I don't mind the inboard, there are pro's and con's for both inboard and outboards, I like the closed transom (just like with the Whaler Drive configuration). Is the V-22 the first in the new hull shape that Boston Whaler introduced in the early 80's ? Is this the same throughout the Outrage series from that era ?
Postby Jefecinco » Sat May 08, 2021 10:08 am
Sterndrive propelled boats are less desirable if used in salt water. Use in salt water is particularly aggravated if the boat is to remain in a wet slip or on a mooring. Current sterndrive offerings are more salt water tolerant and replacement of the one on the V-22 would probably be a long range money saver.
Seawater cooled inboard engines are also prone to failure and the exhaust manifolds are particularly prone to failure which often leads to further engine damage. An inboard engine with full freshwater cooling is far more desirable.
Given the age of the engine/drive on the V-22 it may be a good candidate for a full repower with modern system.
I believe a sterndrive system would be less expensive to replace than the installation of a new outboard engine and would avoid the cost of the fiberglass work required.
Postby jimh » Sat May 08, 2021 11:46 am
The durability and thus the longevity of a sterndrive engine is related to the water it will be used in.
In northern, colder, freshwater, a sterndrive engine could last 50-years. My favorite story is from a fellow I met who was cruising around in a small fiberglass runabout powered by a four-cylinder sterndrive. It was a c.1960's boat with original engine. He bought it for $300--but the boat was on the bottom of a freshwater lake in extreme northern Michigan. He raised the boat, soaked the engine in oil, and got it running again.
In tropical saltwater, sterndrive power is not very popular, particularly if raw-water cooled. Hot exhausts and saltwater make for corrosion of steel.
The other significant problem with a sterndrive is the rubber seal at the transom. A leak there will sink most boats. But, of course, not a Boston Whaler.
Most engines in sterndrives are converted automobile engines with iron blocks. At one time they were very inexpensive and very plentiful. The latest versions from MerCruiser are now using their own engine blocks, made by Mercury. The automakers don't make that many old V8 iron block replacement engines these days.
The transmission of engine drive shaft power through the complex two-90-degree bends and rotating drive gears of the sterndrive propulsion mechanism are also areas for concern.
There are still very high-horsepower stern drives being using on go-fast boats and big cruisers. Whether a c.1981 sterndrive engine and drive mechanism will prove reliable is probably hard to predict.
HappyHour
Postby HappyHour » Tue May 11, 2021 11:41 am
Thanks for your insights, I have just agreed to buy the V-22 and we will see how she performs. In a couple of years we may replace the engine for a new MerCruiser but for now we will give it a try. I am really glad to be a Boston Whaler owner again, all we need to do is ship her from the US to Europe, a 16 day trip but well on time for the summer holidays ;-)
Might be picking your brains a little more when we start using her.
Postby Phil T » Tue May 11, 2021 12:37 pm
Congrats J!
rcapriola
Postby rcapriola » Thu May 13, 2021 11:15 am
I own a 1980 REVENGE V-22 with a rebuilt Mercruiser [engine] and the original outdrive.
If you have always run outboard engine [then running an inboard engine with sterndrive will] put you onto a learning curve.
[On the 1980 REVENGE V-22 with Sterndrive] I have replaced the trim pump motor, the reverse lockout, and fuel tank.
[The propulsion engine] is starting to overheat at cruising speed. I replaced the [water pump] impeller in 2020, one year ago.
I am now considering a complete re-power with a new V8 engine, a new Mercruiser Bravo outdrive, and all new associated steering and shift cables. These new components are going to cost about $25,000, and their installation will cost another $5,000.
1980 Revenge V-22 Sterndrive
HappyHour
Postby HappyHour » Thu May 13, 2021 4:13 pm
PHIL--I am very excited.
I wanted to travel to the U.S.A to pick up [the 1981 OUTRAGE V-22 Sterndrive boat] before [the boat was[ shipped out, but Covid travel restrictions prevented that from happening. Now we have to wait for arrival here in Europe in early June 2021.
I am not too worried about engine trouble. An outboard engine that age would also be a risk.
I have been looking [at re-power options]. A new MerCruiser V6 with Alpha One outdrive would be around $20,000 and an addition $2,000 for installation.
We intend to keep this [1981 OUTRAGE V-22] boat in the family for a long time. The family loves the classic Outrage model. We don't mind spending money in the right places. The [1981 OUTRAGE V-22] is a 40-year-old boat, and she will need some love. The engine will need some love.
But I have no worries. I can't wait to get my hands on her.
Postby jimh » Thu May 13, 2021 4:51 pm
HAPPY--I am sure you will have plenty of fun running the 1981 OUTRAGE V-22 Sterndrive, and also plenty of enjoyment in refurbishment of the boat and the propulsion engine.
Here where I live--southeast Michigan--there are a hundred thousands boats with sterndrives, as the use of automotive four-stroke-power-cycle engines was quite attractive to people around Detroit. Everyone understood the very simple iron block, four-barrel carburetor automobile engines that were converted for marine propulsion engines.
I don't know what sort of sterndrive you will be getting: MerCruiser, OMC, or Volvo-Penta. Today the Mercruiser sterndrives seem to dominate. Back in the 1980's there was more competition.
There is some interesting history of sterndrives in my lengthy two-part article on a major lawsuit filed against Brunswick many years ago related to market share and price discounting for sterndrives. See
https://continuouswave.com/whaler/reference/history/brunswickPart1.html
https://continuouswave.com/whaler/reference/history/brunswickPart2.html
HappyHour
Postby HappyHour » Thu May 13, 2021 5:15 pm
Thank you Jim, I will read the articles with interest !
I am looking at 250 HP MerCruiser V-6 engine with MerCruiser outdrive. It is pretty much proven technology, no cutting edge innovations here and should be reliable.
It is going to be interesting also to see how the current V8 305 Chevy block with four-barrel carburetors is performing. It is 30 years old but seems to run fine at the moment. Will keep you guys updated on progress and setbacks (which we will have for sure)
HappyHour
Postby HappyHour » Thu May 13, 2021 5:39 pm
Jim, I just read the two articles. I draw two general conclusions :
1. being better than others at what you do is not a crime (and should not be)
2. reaching decisions on these extremely complicated legal matters is in no way something that a jury could deliver. Way too much expertise required.
It makes very interesting reading, thanks for the articles. I am convinced my choice for MerCruiser will be the right one to make when the time comes
rcapriola
Postby rcapriola » Sun May 16, 2021 11:45 am
Q4: [What was the] stock engine and outdrive combination for a c.1981 REVENGE 22 with sterndrive power?
Q5: Was a Chevrolet 305 engine that is mention {above] the original engine [on the 1981 OUTRAGE V-22 Sterndrive boat that is the topic of this discussion]?
HappyHour
Postby HappyHour » Sun May 16, 2021 6:18 pm
The Outrage V-22 I bought last week has a Yamaha engine with MerCruiser parts with a 305 block with a four-barrel carburetor. That is, however, not the original engine, I was told. This engine is early 1990's and the boat is 1981. I could not tell you what that original engine was.
mike
Postby mike » Tue May 18, 2021 1:12 pm
I have a 1981 22 Outrage originally with stern drive. Love the closed transom.
Bought her in a closed bid auction when Chicago Marine closed down and liquidated the owner's collection.
The plan was to find a diesel stern drive setup and re-power (actually just power, mine came only as a bare hull, no rigging or engine).
Budget at the time kept us out of the diesel world, so we had a bracket made and mounted a Yamaha Ox-66. She has been a great boat.
Still hoping to find a diesel setup, there just haven't been enough Hurricanes.
Postby biggiefl » Wed May 19, 2021 10:27 am
I know when you look up the cost for a new Mercruiser repower it is in the $20k range. That is not the reality. Most can get the same package for around half of that. Most repowers do not require all new parts. Transom assemblies rarely go bad as do outdrives. You most likely can get a new small block long block and swap carb and wiring harnesses for under $5k.
HappyHour
Postby HappyHour » Thu Jun 03, 2021 1:23 pm
Yesterday our 40-year-old Outrage V-22 arrived in The Netherlands in the Port of IJmuiden after traveling from Newport, Rhode Island. I will upload some photos (once I have figured out how to do it- [Moderator see the INTRODUCTION FORUM for an article on how to add images to posts].
The hull, console,and T-Top are stunning, the outer shell and inner shell are great--all looks in good shape.
The engine and the sterndrive are however in terrible condition. The inboard engine was half under water and a lot had found its way into the engine, too. The sterndrive was so lose you can swing it around by hand, left to right for about 10 inches, hydraulic steering useless in this case. Just not good and I am annoyed with the seller about this
Also the sterndrive does not match the engine (different ratios 1.3 vs 1.7) so it is a botch job and basically a write off.
Of course this is the gamble you take when you buy a boat overseas without the chance to go check it out (thanks Covid-19)
Re-powering remains at the top of our list and despite all the engine headaches, the boat is lovely. I am very happy to be a Boston Whaler owner again.
The OUTRAGE V-22 is quite different with the sterndrive, and it has a beautiful wooden swimming platform on the transom.
Postby jimh » Thu Jun 03, 2021 4:03 pm
That you were defrauded about the engine and sterndrive is most unfortunate, but if there is a good side to this deal, the hull and topsides sound like they are in really nice condition. Re-fitting a sterndrive and engine will be possible, and probably easier than repairing the hull were the hull in bad shape.
What has happened by chance is now you have an opportunity to close off the transom and put on an outboard engine bracket.
Thanks very much for the follow-up.
The INTRODUCTION forum has instructions on how to add images to posts. See
https://continuouswave.com/forum/viewto ... f=1&t=2569
HappyHour
Postby HappyHour » Thu Jun 03, 2021 5:02 pm
Thank you Jim, we will probably stick with the sterndrive set up and replace the engine and outdrive. We can easily source a new engine and the transom with beautiful wooden swimming platform is pretty unique. I am very glad that the hull and everything on deck seems to be in very good shape. Re-powering was expected at some point so I guess we just have to speed up the agenda a bit
Postby Phil T » Mon Jun 07, 2021 8:52 pm
Fig. 1.
Fig. 2.
Fig. 3.
Fig. 4
Fig. 5.
Fig. 6.
Here are some photos from Jan showing the arrival.
HappyHour
Postby HappyHour » Tue Jun 08, 2021 3:20 am
Thanks for your help Phil, I appreciate it a lot.
Amazing experience with these shipping people at Sevenstar Yacht Transport. They have arranged it all, from dropping the boat in the water in Newport, towing her to to ship (anchored out) loading her, strapping her to the deck and at the port of destination lifting her off the deck onto a flatbed trailer.
All very professional solutions and quick too. Also the administrative side was handled by Sevenstar including insurance and import duties (which by the way are OUTRAGEOUS, due to the US/Europe trading disputes we had to pay a ...tatata ..."anti dumping charge" of 25% !!!).
That however, is not the shipping line's fault, I could not be happier with their service and would recommend them to anyone shipping a boat across big splashes of salt water.
Now it is up to us, repowering and doing some catch up with the maintenance and general appearance of Harpoon. She is a nice little 1981 Whaler, certainly worth our efforts. Not sure if we can use her this season, the engine trouble may keep her ashore for some time.
HappyHour
Postby HappyHour » Tue Jul 13, 2021 6:15 pm
Harpoon has been in Holland for a little while now and I have decided to repower, the old Yamaha small block V-8 sterndrive is 30 years old and needs to retire. I am looking at Volvo Penta Aquamatic 240 or 280 HP with a 6 cylinder block and a sterndrive with duoprop. Does anybody have any experience with the brand in sterndrive configuration ? Maybe even in IPS configuration (forward facing props on the sterndrive)
Postby Jefecinco » Wed Jul 14, 2021 9:33 am
In the US Volvo stern drives are not universally admired. Repair parts often require long waits and are higher priced than those of competitors. Things may be very different in Holland due to the proximity to Sweden and different tax structures.
Dual propeller stern drives are popular here.
Maneuvering a 22 foot boat with power steering is very easy. I owned a 24 foot SeaRay Sundancer with a 260 HP single propeller stern drive with power steering and had no difficulty maneuvering around tight quarters and backing into our slip at the marina. When we took delivery of the boat I spent a couple of hours driving it around the marina before I became confident in my driving skills. I don't believe IPS is needed on you boat. Forward facing propellers are more exposed to debris strikes and I believe they offer little value on a small boat.
HappyHour
Postby HappyHour » Wed Jul 14, 2021 10:57 am
Thanks for your insights, I agree about the forward facing props, seems very exposed and probably not adding much benefits. Also I wonder how that would sit on a roadtrailer with the props facing downward when the sterndrive is tilted upward.
Volvo Penta have an extensive service network throughout Europe and are well respected for their diesel engines, I am not sure about the petrol engines. Parts should be available widely but then again only 1 in 10 of their sold engines is a petrol engine.
The alternative is the new Mercruiser 6 cylinder 250 HP with the Bravo 3 sterndrive, also a duoprop. I have requested a quote for both so should know if there is a big price gap between them. Mercruiser has been "the boss" in this market for a long time and certainly a safe bet.
Postby jimh » Fri Jul 16, 2021 8:46 am
Here is a random sample of sterndrive brands in use on six boats that are near me, on Lake Michigan in northern Michigan. I was surprised by the outcome.
Mercruiser = 1 boat
OMC = 1 boat
Volvo-Penta = 4 boats
Among the four Volvo-Penta boats, there was a very new boat with a forward-facing duo-prop outdrive (called a Forward-Drive), an older boat with a standard duo-prop, and two boats with single propeller outdrive. The boats were all non-Brunswick brands--of course--and the brands were FourWinns (2), Azure, and Regal. The FourWinns boats are made in Cadillac, Michigan, which is about 60-miles south of my location.
The OMC boat was an older Cobalt boat with a HIN indicating a 1986 model. I think OMC drives were actually Volvo-Penta drives at that time.
The above five boats were all larger boats, at least 21-feet long up to about 24-foot long.
The lone Mercruiser was on a 17-foot bowrlder, a Stingray--a much smaller boat than the other five.
One influence on the popularity of the Volvo-Penta sterndrives is the non-Brunswick boat builders are free to choose the sterndrive they prefer, rather than forced to use the Brunswick Mercruiser brand. Choosing a non-Brunswick sterndrive may also be done with the notion of not buying the sterndrive from their direct competitor in the boatbuilding business.
Mercruiser may have a big market share in sterndrive boats in the USA, but I think much of that is due to being used by Brunswick boat builders and on smaller boats.
One oddity: the Volvo-Penta sterndrive with the forward facing duo-prop looked like it could not tilt up out of the water. The boat had a large swim platform above the Forward-Drive that would prevent full tilt-up. The propellers looked like they were actually under the boat hull.
Postby Jefecinco » Fri Jul 16, 2021 10:29 am
Regardless of the stern drive manufacturer you choose if your boating will be in saltwater or brackish water, adding the full fresh water cooling option could improve the longevity of the engine.
Postby jimh » Sat Jul 17, 2021 10:02 am
A bit more on the advantage of the Volvo-Penta Forward-Drive with forward-facing duo-prop: these drives seem to be especially popular on the newer water sport boats which have large stern swim platforms. These boats are designed for passengers to easily get into the water or out of the water using the stern platform. Because the propellers of the Forward-Drive are tucked under the transom, the propellers are far away from the stern swim platform and generally will not be a hazard to anyone in the water astern of the boat. A conventional sterndrive with aft-facing propellers would represent a hazard to people in the water trying to board the boat via the stern platform.
Of course, the engine should be in neutral or shut off when anyone is in the water near the boat, no matter where the propellers are located.
Postby Jefecinco » Sat Jul 17, 2021 10:33 am
Jim, good points. Those boats primarily aimed at water sports enthusiasts would probably be a good market for forward facing propellers. Some boats sold as "ski boats" are inboard engine driven. I've never understood the reasoning other than inboard boat propellers are forward of the transom.
HappyHour
Postby HappyHour » Tue Jul 20, 2021 4:28 pm
The forward facing duo-prop outdrives [Forward Drive] look a bit odd, but they do seem to do the business, especially when installed on pods under the boat. I think we will go for the more classic set-up but in the duo-prop configuration. A 240-HP engine with duo-prop should provide sufficient umpf I think for a fast ride and water sports.
I received the quote for the equivalent from Mercruiser ( a V6 250-HP with Bravo3 outdrive and also duo-prop), and it is a shocking amount of money. Even excluding the installation, the cost for the engine, outdrive, propeller, instruments, and throttle remote controls (all analog stuff and not DTS) amounts to 30,000-Euro, which means roughly $35,000 US. Then the installation cost, probably another 2,500.
I expect the Volvo Penta to be at least 20-percent lower including the duo-prop and the freshwater cooling system (which eliminates salt of brackish water coming in at any moment).
My fingers are crossed.
Postby Jefecinco » Wed Jul 21, 2021 9:56 am
Your experience demonstrates the value of Europeans buying European products versus North American products. Given the difference of the quotes in your post it is surprising Mercury and Mercruiser maintain a presence in Europe. Someone has to be buying their products.
HappyHour
Postby HappyHour » Wed Jul 21, 2021 11:02 am
Well one of the problems is that the European Union, in all its wisdom, has decided to put a 25% import tariff on just about all products from the US as a counter measure for Trump putting high tariffs on European products for the American market. I even had to pay this ridiculous charge on the import of our 40 year old boat.
The name of the tariff is "anti dumping rate" as if a 40 year old boat could be part of an economic dumping scheme between the US and Europe.
Unfortunately this does impact the popularity of products originating in the US, a 25% tariff means a lot of money for this type of product.
Also, there is a massive shortage (globally I think) of marine engines, and that does not help either.
HappyHour
Postby HappyHour » Thu Jan 13, 2022 2:14 pm
We have started the restoration of the Outrage V-22. Taking out the old engine and picking up the center deck revealed a massive amount of dirt, old spark plugs, oil, cable ties, acorns and lots more. Wel, the job is on, and I am very happy with what I find so far. The boat is in a remarkably good state after 40-years of who knows what. A happy Whaler owner here!
Postby Phil T » Thu Jan 13, 2022 2:24 pm
Good news Jan!
Let us know if you need technical support during the work.
Keep up the good work.
HappyHour
Postby HappyHour » Fri Jan 14, 2022 6:34 am
Thanks Phil, may need some help along the way.
It is great to work on this boat, taking her apart shows the clever simplicity of how these boats are put together and how much progress can be made by doing relatively easy jobs and without specialist knowledge. Putting it all back together may present a question or two, will see.
Now I am struggling to find a solution for the flush mounting of my 7" Raymarine chartplotter. We have the width but not really the height. Trying to avoid using the brackets and squeeze it into the "dash" next to the switches and gauges.
I am amazed by the quality of the woodwork as well, With some tlc it will be as new. Our boat (1981) has the teak gunwales and they are still in good condition, needs sanding and varnishing, that is all. great stuff !
Postby Phil T » Fri Jan 14, 2022 10:50 am
It is a bit of a challenge to flush mount large screens on the classic consoles.
Many owners build a large riser on top of the console with angled face to mount the large screens, radio and gauges. With the added height they raise the windshield to improve protection from the wind and water.
A photo or two of your progress would be great.
Postby Jefecinco » Sat Jan 15, 2022 10:21 am
Flush mounting a GPS display is not always the most effective way to enjoy it. In differing conditions the view of the display can be imperfect due to sun angle, boat trim and speed. A gimbal mounted display can be adjusted side to side to provide the most direct view for the operator and can be adjusted up and down to compensate for more or less boat trim or a taller or shorter operator. Adjustments for sun angle can also improve the display image quality.
Postby Phil T » Sat Jan 15, 2022 10:45 am
Expanding on Butch's keen observation.
I have seen owners of classic center consoles (Montauk, Outrage) install large multifunction displays (MFD) using a RAM mount secured on either the console top or the wrap around rail.
HappyHour
Postby HappyHour » Sat Jan 15, 2022 1:48 pm
yeah we need to figure out what the optimum will be, I love the flush mount installation but there are arguments to stay away from that. When we have figured it out I shall report back. Will also provide some pics of our progress shortly
Postby Phil T » Mon Jan 17, 2022 1:43 pm
Jan was nice and sent me some photos to show recent activities.
Fig. 7.
1_Stern Drive.jpg (237.18 KiB) Viewed 578365 times
Fig. 8.
Fig. 9.
2b_ EngineCavity.jpg (195.29 KiB) Viewed 578365 times
Fig. 10.
Fig. 11.
Fig. 12.
Postby Jefecinco » Tue Jan 18, 2022 10:21 am
Ram Mounts are a nice alternative. They offer more flexibility than gimbal mounts and installation is easier. I use on for the multi-function display (MFD) on our Sport 13 due to the very limited console size. On our recently sold 190 Montauk the MFD was flush mounted and on our other previously owned boat, a Dauntless 16, the MFD was gimbal mounted. Of the three mounting types we have used we find the Ram Mount to be the best overall.
HappyHour
Postby HappyHour » Wed Jan 19, 2022 5:04 am
Jefecinco, could you post an image of the ram mount set up or maybe a link so i can have a look, thanks
HappyHour
Postby HappyHour » Wed Jan 19, 2022 5:06 am
No need, just found it, was not familiar with the brand, thanks
HappyHour
Update - Re: 1981 Outrage V-22 Sterndrive
Postby HappyHour » Thu Apr 21, 2022 8:51 am
Below you find some pictures of the Boston Whaler Outrage V-22 Harpoon upgrades. We had a new tank fabricated in 5mm aluminum, the new Volvo Penta engine is in with a new drive unit, we are working hard on the wooden parts, and have installed all new instruments for engine and safety equipment including a 7-inch Raymarine plotter. There is still plenty to do, but we are going fast.
Water inside the hull seems to be very limited, and all looks good.
Fig. 13. Sanding, Sanding, Sanding
sanding sanding sanding.jpeg (66.16 KiB) Viewed 574680 times
Fig. 14. New Console set-up
new console set up.jpeg (22.48 KiB) Viewed 574680 times
Fig. 15. Transom view with outdrive
new drive unit.jpeg (62.51 KiB) Viewed 574680 times
Fig. 16. Installing new aluminum tank
newly fabricated fuel tank.jpeg (62.81 KiB) Viewed 574680 times
Fig. 17. Varnishing Wood
varnishing wood.jpeg (45.55 KiB) Viewed 574680 times
Fig. 18. Volvo Penta 250-HP
new Volvo Penta 250 HP.jpeg (50.93 KiB) Viewed 574680 times
[Relayed via email by PHIL T]
[Moderator's note, with now 18 images in this thread, I have edited all the posts to include figure numbers so that readers can make reference to the images if they want to ask a question or make a comment about the details shown in the photographs.]
Postby jimh » Thu Apr 21, 2022 10:30 am
I am really enjoying see the progress of the restoration of this 1981 OUTRAGE V22 Sterndrive boat.
I notice in Figure 18 that the engine for the stern drive sits very nicely in the compartment molded into the hull liner that would, for an outboard-powered model, have been a below-deck aft storage well [or fish well or live well or wet well or whatever one likes to call it]. I would like to see another photograph that shows how the engine mounting was accomplished, and if any lumber or boards were employed. Perhaps Jan (AKA HappyHour) can update that for us.
Also seen in Figure 18: that aft molded section connecting the gunwales looks very much like the molded component used on my REVENGE 22 W-T Whaler Drive boat that creates the aft deck with three hatch openings.
HappyHour
Postby HappyHour » Thu Apr 21, 2022 1:32 pm
We had the engine bay re-glassed, it was in seriously bad condition. The engine rests on the higher stringers to port and starboard and sits nicely inside the engine bay. We had to make some adjustments to the cross bar in order for it to clear the engine.
Fig. 19.
Harpoon engine front.jpg (232 KiB) Viewed 574645 times
Fig. 20.
Harpoon starboard engine foot.jpg (184.02 KiB) Viewed 574645 times
Fig. 21
Harpoon engine feet.jpg (159.86 KiB) Viewed 574645 times
The aft deck is the three hatch version which, I believe, is also used for the WhalerDrive boats.
Engine cover box fits exactly with about an inch clearance at the top. This Volvo Penta engine is a little bigger than the previous MerCruiser block but it all fits.
We have to fabricate little aft deck floor sections, one missing and one so bad that I don't want to put it back.
Upholstery being redone over the next few weeks.
Almost ready to put the swimming platform back on.
HappyHour
Postby HappyHour » Thu Apr 21, 2022 1:37 pm
Fig. 22.
Harpoon engine bilge pump.jpg (152.77 KiB) Viewed 574644 times
Fig. 23.
Harpoon Racor filter.jpg (138.74 KiB) Viewed 574644 times
Fig. 24.
Harpoon aft hatches & engine box in progress.jpg (198.29 KiB) Viewed 574644 times
Postby Jefecinco » Fri Apr 22, 2022 9:16 am
All the work appears to be excellent. Congratulations on a successful effort.
I didn't see the engine oil filter unless it is the white filter seen in figure 18 which, I believe, is the Racor fuel filter. If the oil filter is engine mounted and inconvenient to service consider installing a remote filter in a more convenient location. When we had a Mercruiser 260 HP engine with an Alpha Stern Drive changing the engine mounted oil filter was an onerous chore.
HappyHour
Postby HappyHour » Fri Apr 22, 2022 2:17 pm
The oi lfilter is the white one in Figure 18, as you assumed.
Access to the fiter is easy. We have a separate Racor fuel-water separating filter in the forward side of the engine bay.
I believe Volvo Penta made a conscious effort to position the parts which need to be serviced high up on the engine and in accessible areas.
The work continues this weekend. We hope to get the T-Top back on.
