1998 OUTRAGE Leak
mpmegginson
1998 OUTRAGE Leak
Postby mpmegginson » Sat Jun 18, 2022 10:02 pm
I have a 1998 Outrage [of unspecified length--the full model name including length designator was never provided but the c.1998 OUTRAGE 21 was mentioned as an example of boats that have deck access plates in the engine splashwell].
[When] water comes over the transom, the transom hatch leaks [later clarified somewhat to mean an access hatch in the engine splashwell that has a seal and is anticipated to be water-tight].
Of course, the [sump] pump takes care of [the water].
There must be a way to keep [the access plate or opening hatch on a 1998 OUTRAGE of unspecified length] from leaking.
I do not want to replace [the transom hatch] if replacement is not necessary.
I have replaced the gasket; [the new gasket] made no difference [in the leaking of the transom hatch].
[Give me a remedy for the leak in the transom hatch of a 1990 OUTRAGE of unspecified length.]
Re: 1998 OUTRAGE Leak
Postby jimh » Sun Jun 19, 2022 7:12 am
Your description of "transom hatch" makes no sense. The transom is a vertical structural part of the hull. To have a hatch in the transom would be very unusual. Perhaps you are talking about some sort of small opening in the engine splash well area, a deck access plate or something similar.
Please describe the component you are seeking advice for using terms other than "transom hatch."
Also, please give the full model name of the boat including the length designator.
Postby Phil T » Sun Jun 19, 2022 11:47 am
Many Outrage and Conquest models in the 1990's through today have an inspection hatch and access ports in the floor of the splashwell. Over many years of exposure to salt water and the elements, the gasket can wear and not maintain a seal.
The 1998 Outrage 21 has three hatches in the splashwell as do the Outrage 23, Outrage 24 and Outrage 26. Their Conquest cousins did as well.
Fig. 1. View of deck layout of an OUTRAGE 21.
I worked with several Outrage/Conquest owners from Australia recently to find a solution to their leaking hatches. After much searching and contacting vendors, it was decided to replace the large inspection hatches with locally available ones. Shipping from the US was too time consuming, and expensive.
O-rings for the round hatches can be made up using rubber O-ring material.
Replacing the entire hatch is not terribly difficult and can be done DIY at a slip.
mpmegginson
Postby mpmegginson » Sun Jun 19, 2022 9:18 pm
Sorry for the poor description, but [what was trying to be described was] the hatch in the floor of the splash well, right in front of the transom. Thanks Phil T.
