1991 Outrage 19 Navigation Lamp Restoration
Will
Source for OEM Replacement Combined Sidelight Navigation Lamp
Postby Will » Mon Jun 12, 2023 10:36 am
Q1: what is a source for an OEM combined sidelights navigation lamp mounted at the bow of my 1991 19 Outrage?
Q2: is the PERKO lamp seen below an exact fit or close-to-exact fit?
Source: https://www.perko.com/catalog/navigatio ... lor_light/
BACKSTORY
While trying to repair the wiring, a copper conduit (likely not what it is called) fell down into the hull.
Q3: is there a source for just replacement parts for the OEM lamp?
I want to keep the boat as original as possible so parts are my first choice.
Q4: where can I get a picture of the part I lost?
The part I lost is a small copper rectangle that connects the lamp to the wiring—clearly I am not an electrician. I could attempt to make a replacement for the part I lost.
—Will
Re: Source for OEM Replacement Combined Sidelight Navigation Lamp
Postby jimh » Tue Jun 13, 2023 8:15 am
Will wrote:Q2: is the PERKO lamp seen at the URL below an exact fit or close-to-exact fit?
The PERKO lamp might be useful. Not seeing exactly what you have now makes judging what will work as a replacement difficult.
Will
Postby Will » Tue Jul 18, 2023 8:05 am
[Started a second thread on same topic. The two threads have been merged.]
On my 1991 OUTRAGE 19 the [sidelights lamp (or lamps) and white all-round lamp] are not illuminating. The cause of this problem appears to be with the internal lightbulb housing [socket] and the way the [lightbulb] is held in place, and also due to corrosion and age.
[Implied question]
Q1: are the original parts for the navigation lamps on a 1991 OUTRAGE 19 available?
Q2: is there a person or company that can restore these lamps if I send them to them?
Re: 1991 Outrage 19 Navigation Lamp Restoration
Postby jimh » Tue Jul 18, 2023 8:14 am
In order to know exactly which type of navigation lamps you need to get replacement parts for, please show readers a photograph of each lamp. SECOND REQUEST TO YOU TO SHOW WHAT LAMPS YOU ARE ASKING ABOUT.
Will
Postby Will » Wed Jul 19, 2023 10:22 am
Fig. 2. The combined sidelight lamp that is the topic of this discussion is revealed now in this photograph.
Postby Phil T » Wed Jul 19, 2023 7:03 pm
The [combined sidelight lamp seen in Figure 2] is available from Nauset Marine.
https://www.nausetmarine.com/boston-whaler-parts/lighting-and-electrical/light-assemblies/1035203-bow-light/
Will
Postby Will » Fri Jul 21, 2023 2:00 pm
Thank you Phil!
