1964 NAUSET 16 Re-power Tohatsu 60-HP Tiller-steering
Ringo
Postby Ringo » Fri Jul 11, 2025 11:09 pm
I plan to repower a [1964 NAUSET 16] with a Tohatsu 60-HP four-stroke-power-cycle engine with tiller steering.
Q1: what propeller pitch will produce a trolling speed of 2-MPH or less at engine idle speed?
My plan is to select a propeller that will "meet" the engine RPM limit, but not less.
BACKSTORY
I bought this 1964 NAUSET 16 whose interior was in rough shape, but the hull condition was "decent." I plan to completely gut [the interior], then have only a fuel tank, a battery, and two seats. This boat will be used for angling, and mostly for the species Salmon. Occasionally I will use the boat on a lake. I do not care about the maximum boat speed.
For readers who have experience in re-powering [a stripped out 16-foot Boston Whaler hull] with a 60-HP [Tohatsu four-stroke-power-cycle engine with tiller steering], [please comment].
[Moderator's note: this thread is moved to the PERFORMANCE forum for discussion from the REPAIRS and MODIFICATIONS forum. Predictions of boat speed following a re-powering with a different engine are always discussed in the PERFORMANCE forum.]
Re: 1964 NAUSET 16 Re-power Tohatsu 60-HP Tiller-steering
Postby jimh » Sat Jul 12, 2025 9:06 am
Ringo wrote:Q1: what propeller pitch will produce a trolling speed of 2-MPH or less at engine idle speed?
To answer your question regarding a prediction of boat speed produced by a propeller, the GEAR RATIO and engine IDLE SPEED RPM must be specified. Please provide that information.
Once that information is available, the BOAT SPEED in MPH can be calculated with the PROPELLER CALCULATOR available on this website at
https://continuouswave.com/calculators/propCalc.php
Generally the performance of a propeller operating at very slow boat speed will exhibit a characteristic of SLIP in the range of 30 or possibly higher. Because of the uncertainty of the value for SLIP, predicting the exact boat speed will be difficult.
You should proceed to the calculator, enter the RPM and RATIO data, and set the boat speed (MPH) to the desired value (2-MPH). Set the SLIP to be 30, and the calculator will deduce the propeller PITCH.
Postby jimh » Sat Jul 12, 2025 9:10 am
Ringo wrote:My plan is to select a propeller that will "meet" the engine RPM limit, but not less.
This comment is somewhat unclear. My interpretation is you will choose the propeller so that at full-throttle setting the engine will accelerate to the maximum allowed engine speed. This method of propeller selection may not allow you to achieve your other criterion of reaching a boat speed of 2-MPH or less at engine idle speed.
To achieve a particular boat speed needed for angling using the trolling method, two techniques are often employed:
  • a mechanical device is used to spoil the propeller thrust, sometimes in the form of a hinged plate that attaches to the engine leg at the anti-ventilation plate and is lowed into position aft of the propeller to disrupt the stream of accelerated water coming off the propeller; or
  • the engine is operated in reverse and the boat is navigated transom-first instead of bow-first.
Ringo
Postby Ringo » Sat Jul 12, 2025 9:52 am
Thank you for that. All very good information!
Postby jimh » Sat Jul 12, 2025 10:59 am
Regarding a Tohatsu 60-HP engine, there are three distinct models available:
  • the model MFS60A, manufactured by Tohatsu; and
  • models BFT60A and BFW60A, made by HONDA and re-badged as Tohatsu.
The specifics of gear ratio and engine speed ranges are probably not identical between all models of 60-HP Tohatsu engines.
This information was just recently educed in a concurrent discussion.
Cf.: https://continuouswave.com/forum/viewtopic.php?f=7&t=8746#p50442
Postby jimh » Sat Jul 12, 2025 12:35 pm
Assuming the following inputs to the PROPELLER CALCULATOR
RPM = 500
RATIO = 2.08
PITCH = (to be calculated)
SLIP = 30 (a reasonable value for propeller SLIP at really low speed operation)
MPH = 2
The calculated propeller pitch needed would be 12.6-inches.
Now using a 12-pitch propeller we can estimate the maximum boat speed
RPM = 5500 (assumed value for the engine)
RATIO = 2.08
PITCH = 12 (about as calculated above)
SLIP = 10 (typical at speed
MPH = (to be calculated)
The calculated boat speed is 27-MPH.
Cf.: https://continuouswave.com/calculators/propCalc.php
Ringo
Postby Ringo » Fri Sep 26, 2025 1:47 pm
[The calculated boat speeds mentioned above by jimh are] spot on. Top boat speed is about 27-MPH with a 12-pitch propeller. At engine idle speed the boat speed is a trolling speed of around 2.2-MPH.
This Tohatsu 60-HP engine has a troll speed control they say works like this:
  • a one-second push of the key switch will increase or decrease engine RPM;
  • starting at 850-RPM (the standard idle speed) one-push decreases engine idle to 750-RPM;
  • the next push decreases to 650-RPM;
  • then you hear one BEEP, and the next push increases idle by 100-RPM;
  • this continues in 100-RPM steps, working up to 950-RPM;
  • then you hear two BEEPs, and each push reduces engine speed 100-RPM.
These speed changes are all sequential, so you cannot miss a step. I you do, you have to go all the way down then back up to get to 950-RPM. This feature might be handy if it worked--but it does not. Tohatsu says they are working on that. I like the engine, but I am severely disappointed in the dealer and Tohatsu regarding this feature.
