1995 OUTRAGE 24: Dimension of Fuel Tank
Rdrfn85
Postby Rdrfn85 » Fri Oct 31, 2025 4:51 pm
[Moderator's note: moved from another topic. Changed inquiry from only one person to all readers.]
Q1: what are the dimensions of the OEM fuel tank in a 1995 OUTRAGE 24?
Re: 1995 OUTRAGE 24: Dimension of Fuel Tank
Postby jimh » Tue Nov 04, 2025 2:32 pm
Perhaps you can clarify the "dimensions" you are seeking.
Because the OUTRAGE series boats are definitely V-hull designs, I would expect that the below-deck internal fuel tank shape will incorporate a V-shaped bottom. This suggests that the overall shape of the fuel tank will not be a rectangular solid, but something more complex. Giving just the "dimensions" of the fuel tank will be rather awkward. More likely a to-scale mechanical drawing of the tank will be necessary in order to convey its "dimensions" accurately.
What in particular has caused this need to get the "dimensions?
Knowing that you are really after may help readers reply with better information.
Also:
From what material is the fuel tank in a 1995 OUTRAGE 24 constructed?
I ask because if the tank were made from welded aluminum plate, the constructor would very likely have been Florida Marine Tanks. Florida Marine Tanks can typically duplicate an fuel tank they originally made as an OEM for Boston Whaler for a private individual. But here I am assuming you are such an individual, that is, you need to replace the existing fuel tank.
