I have estimated the propeller pitch as follows:
Using the Crouch's Calculator, I got a top speed of 42.4MPH using these inputs:
- HP = 150
LBS = 2700
Hull Factor = 180
The weight is estimated as 1700-lbs hull, 500-lbs engine, and 500-lbs for the kicker, trolling motor, fuel, fuel tanks, batteries, people. This might be too low.
Using the Prop Calculator, I got a 16.6-pitch using these inputs
- RPM = 6000
Gar Ratio = 2.00
Slip = 10
MPH = 42.4
Based on these calculations I think a 16-pitch or 17-pitch propeller would be appropriate. Please comment
ASIDE:
I also tried a few other combinations of input variables.
[Moderator's note: a survey question seeking to discover how often this boat has been re-powered with this particular engine or a similar engine has been removed. I am certain that if there are readers who have first-hand experience with re-powering this boat in this manner, they will join the discussion and indicate that status, and that information will be more useful than discovering the number of readers that have the qualifications imposed.]
