I don’t have any experience using polyester laminating resins to make repairs. I use epoxy resin from WEST System.
leftyCK wrote:Q1: is there any concern with vinyl-ester resin eating the Whaler closed cell foam?
I don't know if vinyl-ester resin will eat foam. I do know that epoxy will bond very well to foam.
The element in most polyester resins that causes harm to foam is the styrene components. Epoxy does not produce styrenes.
Epoxy is a better adhesive for bonding to other cured materials than the polyester laminating resins used in molding fiberglass boats. In fiberglass boat building the polyester resins are all laid-up in at one time, and they cure together forming strong primary bonds. When you use polyester resins to make a repair on top of totally cured polyester resin laminates, you get a weaker secondary bond.
Epoxy will provide a stronger bond. Epoxy is easier to mix in small batches. Epoxy cures to a hard surface when exposed to air. Polyester resins will not cure to a hard surface if exposed to air, unless you use wax additives or over spray with poly-vinyl alcohol. Epoxy will not dissolve cured foam in the hull.
The best way to produce future stress cracks in gel coat resin is to build up the thickness to more than appropriate, which would usually one coat of about 20-mills thick.
Listen to my interview with Jim Watson from WEST System in the WHALER RADIO section:
https://continuouswave.com/whaler/radio ... tPart1.mp3https://continuouswave.com/whaler/radio ... tPart2.mp3As explained by Jim Watson, gel coat resin will form a proper (secondary) bond to fully cured epoxy resin that has been properly prepared by removal of any amine blush layer.
A recent youTube presentation from WEST System demonstrates the extremely strong bond that occurs with applying polyester gel coat resin on top of fully cured and properly prepared epoxy resin. See
Can You GELCOAT OVER EPOXY? | We Tested It!https://www.youtube.com/watch?v=UUxzWEAZ8Vs
