Source for blue hose
JS NJ
Postby JS NJ » Sat Jun 20, 2026 11:28 pm
Q1: where can blue hose as used for a sump pump on a 1969 NAUSET [16] be purchased?
BACKSTORY
The original blue hose for the sump pump on my 1969 NAUSET 16 needs replacement.
Re: Source for blue hose
Postby jimh » Sun Jun 21, 2026 7:41 am
That blue hose original to a 1969 NAUSET 16 had a 57-year service life. If you can find that same brand you’ll be set through 2083, and the NAUSET will be 114-years-old.
Q2: is having the replacement hose use the color blue an important element in the search?
JS NJ
Postby JS NJ » Wed Aug 26, 2026 3:26 pm
Well, the original hose lasted 57 years (with some taped repairs), but sadly I think that is the end.
Good news (and posting in case it is helpful to others), I found an option on Amazon that is a bit darker, but close enough: https://www.amazon.com/dp/B0B5RGQJ8V?re ... in_title_1
I also found electrical conduit that is almost exactly the right color, but joining it to the pump seems challenging (I might still try): https://www.homedepot.com/p/Carlon-3-4- ... /100534812
