I finally bit the bullet and ordered a Standard Horizon 2410 fixed mount radio. I've been dragging my feet for several years as the existing radio was working fine. I discovered a few weeks ago that the LCD display had gone mostly black. Still functional but try to change channels.... I've been interested in 2410 as it has modern DSC, internal GPS, AIS reciever, and NMEA200 connectivity plus the old NMEA [0183] protocol.
I look forward forward to hooking it up in a static way to test functions before going out on the Gulf of Whatever. (My grandson still calls it the Gulf of Forty Mexicans). The offer still stands to JimH to do some testing before I install it.
Standard Horizon 2410 radio
Re: Standard Horizon 2410 radio
Hi Frank.
For "static" testing (which I assume means ashore) you're going to need a good 12-Volt DC power source, and a VHF Marine Band antenna. To receive any AIS signals you will need to be close enough to some water that has commercial shipping or a lot of larger recreational boats. To test the NMEA-2000 you need to build a little network. And to see the output of the radio for DSC or AIS, you'll need a chart plotter.
I have a "shore" station set up at the cabin up north. I use OpenCPN as the chart plotter, and I have a USB-to-serial convertor to get the NMEA-0183 data from the radio. And a good antenna up in the attic. And a Standard-Horizon radio with integral AIS receiver. The longest unobstructed path is at a very narrow arc from North to the Northeast, where I can receive AIS signals from about 28-miles away. To the West I am completely shaded by much higher terrain, and to the East there is 14-miles of water, but not that many boats with AIS passing by.
This Summer I noticed that more recreational boats of about 30-feet or larger now will have CLASS-B AIS devices. I think the highest number of AIS targets received at once was about nine vessels. There are two boats in the local marina that leave their AIS running even with their boat moored and unattended. They are my "radio check" signals for AIS.
But we've moved back to "winter" quarters now, and we're too far from the Detroit River or other big water to reliably receive AIS, no antenna here, and now no 12-Volt power supply here. I moved all that gear up to the cabin.
I won't get back up north until June 2027.
Following up on my earlier remark about my winter location not being very good for reception of AIS signals from ships navigating the Detroit River, I set up an AIS receiver and tested for reception: nothing received from ships. Only AIS AtoN signals received, which all actually are transmitted from a central radio tower, and are probably sent with more power and much greater antenna height that any ship could have. But even with that advantage, I was only able to get very sporadic reception. Literally about the only time signals were being received would be short bursts on a few minutes, usually very late at night.
The problem could be in the antenna I was using. It is a very old 8-foot marine antenna that someone gave me. I am suspecting that perhaps the antenna is not working very well, and perhaps has a broken connection. I cannot really test the antenna because I don't have my directional wattmeter and a big 12-Volt power supply to generate a signal to test for the VSWR.
I tried two other antennas, and neither of them produced any signals. One was a short log-periodic yagi antenna that is actually my main TV off-air receiving antenna. It covers the Hi-VHF range of TV, which start at 174-MHz. It should be useful at the 162-MHz AIS frequency. The second alternate antenna was just a quarter-wavelength mag-mount antenna stuck onto a filing cabinet next to the window. It was tuned for 156-MHz, so it should be useful for receiving at 162-MHz.
The alternate hypothesis is maybe some local radio noise is getting generated nearby. I do hear a lot of radio noise on my Aircraft Band radios, which are listing down around 135-MHz.
If I had a working laptop--I have a couple of dead MacBook Pro laptops sitting around--I could go mobile and drive down to the river, where I am certain to get extremely strong signals from the AIS base station that transmits from a 200-foot tower about a mile up stream on the Rouge River from the Detroit River.
