Q1: how will a single-engine 2000 CONQUEST 23 with optional hard top run offshore in the ocean in a following sea, and in big swells, and in "slop"?
Q2: will a single engine 2000 CONQUEST 23 tend to broach in following seas?
BACKSTORY
I have purchased a 2000 CONQUEST 23 powered with twin Mercury two-stroke-power-cycle 150-HP engines with the intention to re-power it with a single Yamaha 300-HP four-stroke-power-cycle engine. However, I have read [somewhere unspecified] that a 2000 CONQUEST 23 can run "bow-heavy". and that if powered by a single outboard engine may even require addition of ballast in the stern to balance [the static trim].
Most of the information [about a 2000 CONQUEST 23 ride or handling characteristics] I have found have been in regard to the boat's handling in "chop."
I am in southern California. I frequently go out to the Channel Islands. My concern is about the ride home.
2000 CONQUEST 23 Will Run Bow Heavy
Re: 2000 CONQUEST 23 Will Run Bow Heavy
A 2000 CONQUEST 23 will have the Accutrack hull. Boston Whaler 2000 catalogue literature describes the running characteristics of the Accutrack hull as follows:
That sounds like someone in an advertising agency wrote the copy, particularly the "precision engineering" used in the strakes.
The Accutrack hulls were something new. Boston Whaler had pushed out Bob Dougherty in c.1990, and wanted something new in their hulls instead of sticking with the classic moderate V-hull designs they had been using.
There is a 2004 prior discussion in the archives of the old forum that has remarks about a CONQUEST 23. See
CONQUEST 23 Suitability
https://continuouswave.com/ubb/Forum8/HTML/001877.html
Regarding the need for adding ballast if using a single engine, you might want to compare the total engine weight with the single 300-HP four-stroke-power-cycle engine compared to twin 150-HP two-stroke-power-cycle engines. The difference in weight may not be as much as you think if the 150-HP engine were the classic Mercury EFI two-strokes. If the 150-HP engines were Opti-Max, they would probably have been heavier. However, the notion that Boston Whaler offered an optional "ballast kit" for use with single engine powering does seem to speak to a trim problem with single-engine rigging.
Any hull that boasts of a "deep-V bow entry" is probably prone to bow steering when running down the face of a following sea's large wave. The older classic OUTRAGE style hull with its very moderal hull V-shape at the bow will track beautifully when accelerating down the face of a large wave. I can't offer any experience with an Accutrack hull.
Another problem mentioned with single-engine rigging is the minimum boat speed to maintain plane is in the 25 to 27-MPH range. This is typical of many Boston Whaler hulls. If running twin engines you might be able to maintain plane at a lower boat speed. Actually, in those situations a bit of "bow-heavy" tendency might help to allow the hull to maintain plane at lower speeds. Also, older two-stroke-power-cycle engine often did not like to run at all in certain engine speed ranges, maybe from 1500 to 2500-RPM, but modern computer controlled four-stroke-power-cycle engines with large displacement seem to be happy to run at any speed you want, as long as they are producing enough torque to be able to turn the propeller without decelerating. Also, if you want to be sure to be able to run on plane at lower boat speeds, just select a propeller pitch that is smaller. You might give up 2 or 3-MPH of maximum boat speed, but you will probably acquire better ability to maintain on-plane operation at lower boat speeds.
As for getting home running East from the Channel Islands in a following sea, you are in a 23-footer and if the seas are really large you will need careful attention to the helm and boat speed in any 23-foot boat you might find.
I think the problem comes down to this: what other 23-foot boat would you rather be in than a Boston Whaler if caught offshore in big seas?
The Accutrack hull's deep-V entry slices through rough water like a steel blade. Traditional Whaler reversed chines keep you riding high and dry. And precision engineered running strakes keep you tracking straight and true.
