Identify Older 13-foot Hull, Possibly non-Boston Whaler
olegreg
Postby olegreg » Sun Nov 15, 2026 1:06 pm
Give me some help identifying an unusual 13-footer:
I have a 13-foot 4-inch hull that has no smirk. The engine splash well is the full width of the boat. The hull has a concave deck.
This hull has an identification number, but the Manufactuerer Identication Code (MIC) is "WAZ" which indicates a Washington (state) home-built or unknown manufacturer.
BACKSTORY
[As already mentioned in a prior post] I am the Fleet Manager for a Youth Sailing Program on the Puget Sound. We run seven older Boston Whaler boats as our coach's boats. We configure them with center consoles and bass boat type single chairs for the coaches.
[Moderator's Note: THE GAM is a boating forum. Help with using the forum software cannot be discussed in a boating forum. Please visit the forum INTRODUCTION TO THE FORUM SOFTWARE and read the thread "Adding Image to Post". If you need more help, post a reply in that thread to get more help.
Re: Identify Older 13-foot Hull, Possibly non-Boston Whaler
Postby jimh » Sun Nov 15, 2026 9:10 pm
olegreg wrote:I have a 13-foot 4-inch hull that has no smirk. The engine splash well is the full width of the boat. The hull a concave cockpit floor.
So far in your brief description the boat sounds like just an early 13-footer. See the REFERENCE section article on the 13-foot hull for more details and model changes:
https://continuouswave.com/whaler/reference/13/
Q1: what is the transom height of your unknown hull?
Q2: what is the gel coat color of the cockpit deck and interior?
Q: what color is (was) the rub railing?
olegreg wrote:This hull has an identification number, but the Manufacturer Identification Code (MIC) is "WAZ" which indicates a Washington (state) home-built or unknown manufacturer.
That is not any sort of definitive indication that the hull is not a Boston Whaler. Some prior owner may have tried to register the boat and did not have any paperwork or physical evidence that the hull was a Boston Whaler, so he just got a "home-made" HIN from the state.
olegreg
Postby olegreg » Mon Nov 23, 2026 11:17 am
[Figures 1, 2, and 3 below show differences in the older 13-hull that I do not see on other Boston Whaler hosts of this era:
Fig. 1. View of the bow showing lack of a "smirk" shape.
Fig. 2. View of aft cockpit showing full-width and deep engine splash well.
Fig. 3. View of the forward cockpit deck with concave surface.
[Moderator's note: some images have been re-oriented so that the camera position is horizontal in all images.]
Postby jimh » Mon Nov 23, 2026 11:52 am
olegreg wrote:[Figures 1, 2, and 3 below show differences in the older 13-hull that I do not see on other Boston Whaler hosts of this era...
I don't understand your date reference to this older 13-footer as from "this era." Please explain what era you think the hull comes from.
Figure 1 shows the hull at the bow does not have the line of the runners carried up and over to meet below the bow lip, also knows as the "smirk." This configuration was seen in all 13-foot hulls made before c.1971
Figure 2 shows the standard engine splash well configuration for 13-foot Boston Whaler boats made prior to c.1971. This is nothing unusual about this engine splash well that I can see from your illustration. Please point out something I must have missed that would make this hull different in regard to the engine splash well from any other 13-footer made before c.1971.
Figure 3 shows the foredeck surface is concave. I can't really say if this is somewhat a departure from the normal design of the hull liner seen in other pre-1971 boats.
There are several other features shown in the illustrations you provided that are completely congruent with features of 13-foot hulls made prior to c.1971.
In Figure 1 the one-piece white rub railing is seen. This was standard prior prior to c.1972.
In Figure 2 the notched transom designed for engines with 15-inch-shaft length ("short" shafts) is seen. This was standard prior to 1972.
One unusual aspect seen in Figures 2 and 3 is the odd pattern of the blue cockpit deck, the molded liner part of the hull. This hull seems to have both white and blue elements in the interior molded part. However, the appearance looks like the original gel coat for the liner was white and the blue top color has chipped off, suggesting that someone had applied blue paint in portions of the interior of the hull.
In short, the hull you are asking about exhibits many of the standard features of a 13-foot Boston Whaler hull made before 1971.
