| Author | Topic: Trailer: Bunk vs. Keel Roller |
| will |
Spent the better part of yesterday setting up my trailer for my 1990 19 OR. After countless adjustments, I was left with about 5 inches of stern exposed beyond the bunks. Is this ok? The tongue weight worked out to be 140 lbs and in a few test runs, braking was nice and smooth. Thanks for any and all input in advance.--Will |
| Tom W Clark |
Will, No, the bunks should extend under the transom. This is very important. 140 pounds on the tongue is a bit light anyway. Tongue weight should be 5-10 percent of gross trailer weight. If the gross weight is 3000 pounds, you want the tongue weight to be 150-300 pounds. I would just move the bow stop forward the five inches and solve both problems. |
| will |
Tom, thanks for responding. You are saying that the entire boat needs to be on the bunks, no exceptions? |
| Legobusier |
Will, That's pretty much what Tom is saying. The transom in particular should be directly supported as it's supporting the weight of the engine. This has been covered recently on a few other threads. Do a search and you'll find more info, but basically, you don't want any part of your hull hanging off the trailer. |
| erik selis |
Tom, Is this a general rule for the tongue weight? It seems like 300 pounds for 3000lb gross weight is quite alot. Most trailer hitches on cars (over here) allow max. 75kg (165lb) and 100kg (220lb) on SUV's and pick-ups. Just seems like alot to me although the rules may differ from country to country. Erik |
| Utahwhaler |
Tongue weight is based on safety and handling characteristics. Too light a tongue weight will result in wild fishtailing of trailer following an emergency manuever. General recomendation is 6 to 10 percent of gross weight. I tend to favor the 10 percent rule. |
| Jerry Townsend |
Will - the words of Tom are right-on. The reason for having the transom supported is that the engine put a lot of weight on the transom from the engine - and "hanging" that weight off a bunk puts a lot of stress on the hull where the bunks end. The hull is not designed for that stress. And pulling your boat down a road induces a dynamic loading which amplifies that stress. The 5 - 10 % rule is good. The 5% is on the light side, while the 10% might be on the heavy side - but too much is better than too little. Somewhere in the middle will work very well. Move your bow stop forward 5 inches, re-weigh the hitch load and adjust the axle position as necessary to attain your desired hitch load. The trailer load calculations write-up in the reference section will help you make these adjustments. ---- Jerry/Idaho |
| j abrams |
I have to take issue on one point about bunks. They should not support the weight of the boat. Bunks are designed to keep the boat stable on the trailer. The weight of the boat should be on the center rollers. I've been trailering a 21' outrage for 5 years with about 1' out over the end of the trailer. The bunks just touch the bottom of the boat and keeps it from rocking on the trailer. |
| KIP GREEN |
THE B/W LITERATURE I HAVE STATES THAT THE HULL IS DESIGNED TO CARRY THE LOAD OF THE BOAT ON THE KEEL AND THAT THE BUNKS ONLY STABELIZE(SP)THE BOAT. KIP |
| Plotman |
Step 1 - get the boat where it needs to be on the trailer to be supported properly - at this point do not worry about tounge weight. Step 2 - after completing step 1, move the axle forward or back to get the tounge weight where it needs to be. |
| Chuck Tribolet |
Is it a keel roller trailer or all bunk? Chuck |
| Bigshot |
Keel roller or bunk is a great question. If bunk....move the bunks aft 5" or buy longer bunks if you don't want to go forward more. |
| will |
Fellas, the trailer is all bunk, no rollers. I have just enough room to move the boat forward to get the entire hull on the existing bunks. Anyone care to guess what that will do to the tongue weight? I am calculating 1250lbs for the hull, 420 for fuel, 400 for engine, 500 for trailer and 100 for incidentals; approximately 2700 lbs. Thanks again--Will |
| erik selis |
I would count more than 1250lbs for the 18-foot(19)Outrage hull. More like 1500lbs. (eventhough the hull is rated less) Erik |
| Joe Kriz |
OK Will, I don't want to guess here so How Many Bunks do you have? 2 long ones and 2 short ones I hope.... What are the possibilities of you adding some Keel Rollers? I prefer the combination of both if the trailer will accept Keel Rollers along with 2 long bunks (approx 10 feet) and 2 short bunks (approx 5 feet). Some people think I came up with the term of combination, but I did not, but I have used trailers configured this way since 1988.. http://continuouswave.com/whaler/reference/trailering/trailer.html There is also a method for predicting tongue weight: |
| Chuck Tribolet |
If you move the boat forward on the bunks, you will have a LOT of tongue weight. So the move the axle forward under the frame to get the tongue weight back where it is. If you move the axle forward the same amount you moved the boat forward, you'll have about the same tongue weight (a little less, actually). I'd do that, then measure the tongue weight, and adjust from there.
| j abrams |
will, I would be more concerned about trailering with just bunks. That Whaler should be supported by keel rollers. With keel rollers you would only need about 3 or 4 feet of bunk. Loading and unloading would also be much eaiser. I would really look into converting your trailer to a row of center rollers. Jim |
| will |
The two bunks are each about 8 feet long |
| Jerry Townsend |
Will - you should be alright. While it is true that BW recommonds using keel rollers for load support and bunks for stability - using two (or more) long bunks provides a low enough loading pressure that it doesn't cause a problem. It is true that keel rollers (in good shape) let a boat launch easier, but using a silicon spray on the bunks significantly reduces the friction of the bunks as well. And frankly, you want some friction! Review the trailering reference section - Jimh has an article in there regarding ramp considerations in trailer configuration. I have my 17 Outrage on a two bunk trailer and have not had any problems. Launches and loads very easily. As I mentioned earlier - move your winch stand and boat 5 inches forward and then move the axle as necessary to achieve your desired hitch load. Incidently, the trailering calculations discussed and provided via the reference section includes a technique for weighing your boat using a bathroom scale. When weighing your boat and adjusting the tongue load, have your boat configured similarily to how you would be towing it - i.e. about 1/2 fuel, engine tilted and locked, loaded cooler, etc. The fuel load is the most important. When you move your axle, be sure that the axle is square with the trailer - by having the same distance from a common point on the hitch to the 'same' point on each side of the axle. ----- Jerry/Idaho |
| Chuck Tribolet |
Boston Whaler doesn't recommend keel rollers over all-bunk. They say do not use all-roller and if you use keel rollers, here's how to do it, and if you use all-bunk, here's how to do that. RTFM. (Your owners manual, that is).
| Joe Kriz |
Everyone has there own ideas but here is a quote right from the source.
quote: From the 1970's, Boston Whaler always recommended Keel Rollers along with Bunks... This is still recommended for ALL the Classic Hulls.... The newer Accu-Track hulls obviously are using the All Bunk or Float-On trailers. Fine... But almost every trailer I have seen uses 4 Bunks.. A friend of mine has a 2 bunk float-on trailer and he hates it.. So do I as I get to help him retrieve his boat.. He is going to be adding 2 more bunks and some Keel Rollers. I guess if trailer manufacturers could get away with 1 bunk, that is what you would get..... Add more bunks and Keel Rollers if you can... Protect your boat.. You have an expensive item sitting on a couple of cheap pieces of lumber. It doesn't cost that much more to keep your boat safe... I am done here.............. Good Luck with your decision and I hope you never have any trailering problems....... Fortunately for me, I never have and I want to keep it that way.... |
| Chuck Tribolet |
I can't ever remember a report here that an all-bunk trailer hurt someone's whaler. Whaler evidently changed their mind. My '98ish Montauk came 17' Montauk It says about trailering: TRAILER SELECTION: Your Boston Whaler dealer can be of Match the trailer to your boat: Avoid over-rating or PROPER SUPPORT OF THE BOAT IS EXTREMELY IMPORTANT: As the SIDE BUNKS should be located so as not to interfere with Float-on trailers are of the all-bunk style. These are
| Tom W Clark |
Yes, Boston Whaler has always (with one exception) recommended a keel roller/bunk trailer with the keel rollers supporting all the boat's weight. The exception is that in the early or mid 1990s Whaler started to say it was OK to use an all bunk trailer so long as the bunks are near the keel and carry their share of the boat's weight. Whaler has since back peddled on that recommendation and they now recommend the keel roller/bunk style of trailer. Either type of trailer will work fine so long as it is set up correctly. Erik Selis, Yes, the 5 to 10 percent for tongue weight is a generally accepted rule. As boats get bigger I think it is best to be closer to 5 than 10 percent and I agree with you, 300 pounds is a lot of tongue weight for an Outrage 18. Let's examine Will's situation and see how much weight he is dealing with (my estimates): Outrage 18 - 1500 pounds (realistically) Total - 3400 pounds So 5 percent of that would be 170 pounds which should be considered a minimum. Like I said, 140 pounds seems a bit light. |
| will |
The bunks on my trailer are probably 8 feet long and there are two of them. |
| Tom W Clark |
Will, If there are only two bunks then you certainly should add two more (near the keel) or install keel rollers to carry the weight of the hull. A two bunk trailer might be OK for a little 13, but not for an Outrage 18/19. |
| will |
Tom, I just sent you an email with some additional questions, thanks again for all of your help.--Will |
| Chuck Tribolet |
Tom, that's strange, the mandatory trailer under the M170 is all-bunk.
| Bigshot |
I have ALWAYS used a bunk trailer. Although I agree that keep rollers are better when combined with bunks, I think they can have a downside as well. I have seen where rollers break and giuge the hull(badly). I have also seen them dent the keel but on old and maybe waterlogged/mistreated hulls. I have NEVER seen a hull damaged from a good modern bunk trailer. These are the types where they use a 4"x10"x8' bunk, not the 1"x6"x5' you see on older trailers or keel roller with bunk/plank trailers. My trailers are set up so the bunks support just under the inside chine and the bunks are contoured to rest against the hull, not poke it. No offense but if a chine is damaged from sitting on a properly set up bunk, that boat is a hunk of junk. |
[Moderator comments: Changed TOPIC; was "last trailering question, hopefully". Please note that if participants wish to exchange private correspondence it is not necessary to publicly announce it.] ----------------------- Many Boston Whaler boats are carried on, launched from, and recovered to trailers without keel rollers. The Reference section of the web site contains a lengthy article on trailers and trailer procedures. See: Trailer Most problems in trailer use occur in loading. My experience is that the recommended trailer (multiple keel rollers) greatly facilitates trailer loading. This is particularly true when ramp conditions are less than ideal. In tidal areas, there may be insufficient depth available to submerge a "float-on" trailer during periods of low tide. In the current marketplace, there are very few "stock" trailer configurations available with a multiple keel roller set-up. The simple 2-bunk "float-on" trailer is the predominant product offered. If you only infrequently launch/recover your boat from/to the trailer, and you use a limited number of ramps with suitable depth and accommodating slope, you may find that a "float-on" trailer works well in those situations. |
| linust |
they say a picture is worth a thousand words... In the 5/85 edition of the manual i have (Owners Manual for 18 foot-25 foot Models) on page 21 is a picture of (I assume) a suggested trailer...hard to say for what model this trailer is intended, but given it's a single axle, I'll assume an Outrage 18 (next to it is a picture of an Outrage 18 on a different trailer). Most interesting is that although the trailer has the preferred keel-roller/2 side bunk configuration, there are only THREE keel rollers on the trailer! Thoughts or comments? This is of interest to me because I (and several other Whaler owners I know of) have all-roller trailers, as were (and are) popular here in the PNW. In my case, the trailer has 32 rollers, with 16 of them (8 on each side) within 6" of the keel. I debated replacing the trailer with an all-bunk, but the money sunk in this one (it came with the boat when I got it but has all-new brakes (x4) and new coupler) would be hard to recover, so I'm replacing the rollers and hardware. I may convert from 16 along the keel to 24, doubling up the rollers on the rear most points, which would give a total of 40 rollers on this trailer. |
| Jerry Townsend |
linust - Of course, the more rollers/bunks, the better. If all of the weight is on the three rollers, which have maybe (a wag) an area of 2 x 3, or 6 sq inches per roller. With 3 such rollers that is 18 sq inches - for the entire boat. With a boat weighing 3000 pounds, that gives a compressive loading of 167 pounds /sq inch - which is, for the keel, relatively low and should not cause a problem. And, of course, if the bunks are taking some of that load, the loading of the keel is decresed. The all-swivel roller trailers you refer to have, as I understand, caused many problems - probably because of the smaller diameter and length rollers - and loading the boat away from the keel where the glass is thinner and the glass-foam-glass sandwich intregity is all important. The all bunk trailers provide a very low compressive loading on the hull. With 2 bunks, say 6" x 8' - or 1152 square inches total, the compressive load on that 3000 pound boat is only about 2.6 pounds per square inch. Totally acceptable. And those using more bunk area, the loading pressure is even lower. --- Jerry/Idaho |
| linust |
Jerry-- Are you a keel roller, under load, deforms to a 2" tangential (fore-aft) contact patch, across 3" of the keel pad? When I look at the configuration of my keel, for a keel roller to support 3" across, it must deform at least 1/2" in the center. Seems that a roller that deforms that much must put up a substantial rolling resistance during launch & retrieval, esp since the keel rollers in the catalogs I have show they're only 3-1/2" total diameter. Granted, I can't report from actual observation, but I can see a keel roller deforming about 1/2 to 3/4" tangentially, and perhaps 3/4 to 1" across the keel. If that's the case, then 3 rollers would seem to provide 2.25 sq-in total contact area...for the OR 18 we're talking about here, that's about 100 psi on those three points (actually less than your 167 psi) As for my all roller setup, the rollers have 3" of contact width, and from their 5" diameter, appear to deform about 3/4" tangentially, for about 2.25 sq-in contact area per roller, or about 72 sq-in total support surface--substantially less than a bunk solution. I'm hoping to move my rollers closer to the keel centerline (they're about 4" away right now) but have to be mindful of the clamshell for the stern fishwell drain tube. |
| Jerry Townsend |
linust - the trailer for my 17 Outrage II has two 6" x 8' bunks. It works fine - no problems unloading (floating off) or loading (driving on). At one time I considered adding a keel bunk - which in my mind is better than rollers as it would result in much more uniform loading. I talked with Shoreland'r people and they thought that it would be over-kill. Regardless, I still might do it. Silicon spray would reduce the frictional resistance. The rolling resistance of a roller - being steel on steel - or at least metal on metal, and perhaps with a little lubrication is not all that much. And some rollers may be made with an graphite lubricated bushing - which would be even better. Realize that my wag - where I came up with the 167 pounds / square inch - was just that - a guesstimate. Using your actual weight would give you a much better feel for your case. In the case of Tom W. Clark's numbers, the trailer weight is not germane for our discussion here. With your multiple roller set-up, on the surface, the loading would seem to be alright - but I would think that it would be very difficult to ensure that all rollers were carrying their equal share of the load. Should one or two roller sets be carrying the bulk of the load, that load will be large - and perhaps large enough to damage your hull. But having rollers 4 inches from the keel is good - and probably about as good as you can get with the multiple roller set-ups. ---- Jerry/Idaho |
| JMARTIN |
In the PNW we do not have the luxery of putting thr trailer all the way in the salt water, unless you really like frozen up wheels. I too have an all roller trailer with a Revenge V22 on it with a 200 and a 15 kicker. Do I have waves in the hull? Eh a few little ones. Less than 1/4 inch at most from peak to valley. Never had any problems. Pull the boat up with an electric winch. Hull looks good and sound. My inside rollers are also about 3 inches from the keel and I go right over my stern clamshell sometimes. It looks fine also. The boat also sits on planks for dry dock storage for 1/2 the year. If there was a major problem with support, why did the new whalers seen in cetacea comments page 78 (thats how I got to the page) only have 2 keel supports under them? |
| bsmotril |
JMARTIN, I've been dunking my galvanized bunk trailers up to the coupler into the hyper saline warm (almost hot) waters of the TX gulf coast for 15 years. Bearing Buddies and a grease gun are the ticket. i've only had one lockup and it was due to a faulty brake shoe, and not a bearing. My only maint is to replace the brakes every 3 yrs. Wheels don't freeze after dunking in salt water unless maintenance is totally neglected. BillS |
| linust |
another thought someone once mentioned to me... there are some popular launch facilities around here (Edmonds, for example) that are sling launches...easier to get the sling under the hull if the trailer is rollers vs. a slot in the bunk boards. no experience launching my boat this way, but went fishing with a friend years ago launching his 16' duroboat (aluminum skiff) this way. |
| JMARTIN |
I have got bearing buddys and I keep them maintained. The problem areas are the surge brakes and the lights. Fresh water is not an option at most of the launches around here so the trailer sits for a couple of days untill the return home. I have read that some people bring thier own fresh water in a sprayer. Maybe an option but at a busy launch, not many people would appreciate my taking up limited dock space will I fuss around with my trailer. |
| HAPPYJIM |
Salt water removal is an easy task if you go to a car wash afterwards. For less than 2 bucks you can power wash the boat and trailer if done quickly. Less than 5 dollars gets both vehicle and boat/trailer rinsed. |
Bunk "float on" versus Keel Rollers: I just saw a demonstration of this at the Stuart Boston Whaler Owners Event. In Cetacea Page 78 you can see an Outrage 25 loading on a keel roller trailer in a process that took about 30-seconds. A few minutes later a fellow tried to load his 28 Connquest onto a bunk "float on" trailer. The lauynching area was marked with a limit for the concrete ramp extension into the water, and the bunk trailer was back in as far as it could be until the rear wheels were at the limit. The tide was rather low (because of the new moon), and the big Conquest could not be floated on the trailer. It stopped short about five feet from the fully-loaded position. The boat had a pair of 225-HP 4-strokes, and these were called on to drive the boat forward on the bunks these last five feet. The engines were running at nearly full throttle, while the poor dock hand from the marina was grinding away on the very powerful two-speed winch. In spite of thousands of pounds of pull from the winch and hundreds and hundreds of horsepower, the big boat only inched its way onto the trailer in painful, tiny increments. The irony of this situation was that by using the engines to power load, the big twin propellers were drawing water out of the ramp and actually lowering the water level a bit, with the result that the boat was sitting harder on the bunks. Finally, after about ten minutes of roaring engines and grunting winch grinding, the Conquest was loaded. It was a very tedious process. At most of the ramp locations in the state of Michigan, it would have been completely illegal as "power loading" is prohibited. Even in these tidal waters, there was a great deal of mud and debris stirred up from the 450-HP of thrust the engines put out for ten minutes against the bottom of the ramp. No wonder they did not dare back the trailer in any farther; I am sure the ramp end was probably quite undermined from this type of erosion. There is no dispute that given the ideal ramp situation and a smaller boat, it is not a problem to load onto all bunk or "float-on" trailers. It should be remembered that not all ramp facilities will permit the amount of immersion of the trailer that is required to accomplish loading by the "float-on" method. If you anticipate using your boat at a variety of ramps and in tidal areas where there is diurnal variation in water levels, strong consideration should be given to using a keel roller trailer because of the much easier loading it allows. |
