| Author | Topic: Thickness of a Whaler hull |
| Binkie |
We have all kinds of info on hull dimentions, and models, wood attachment places,but I never have read anthing about hull and deck thickness. I realize because of the foam filled construction,they are totally different than the more common glass boats. Does anyone have any hard facts, pertaining to this? I know that when glass boats first were manufactured in the fifty`s, no one knew what the limitations were, so they just made them super strong. I remember going to a boat show when I was a teenager and seeing a display for one of the first glass boats. The salesman had a sledgehammer, and asked me to give the boat a real hard smack on the side of the hull. Well I hit that hull as hard as I could with the hammer, and I thought I`d be looking into the bilge, but the hammer bounced back so fast I could hardly hold on to it, and it never left a mark. I would hesitate do do that to my Whaler. I know the hull bottom is 3/4" thick on a 31 Bertram, because I measured it when I drilled a hole for a transducer. |
| Buckda |
Based on what I've heard from people in the industry is that the glass on a Whaler is better than many others. Cases in point: I'm having trouble also with your comment about overpriced new Whalers. True that they are an expensive boat, but it is a premium brand, and you generally get what you pay for. Additionally; some of the smaller boats are actually priced lower than I recently thought that they were - suprisingly. You can get into a nice 190 Outrage with trailer and all equipment for under $40K. |
| erik selis |
I wouldn't be able to tell you what the thickness of a Whaler's hull is but I don't think fiberglass thickness is directly related to the global strength of the hull. It's not the quantity but the quality and the way things are put together that provides the strength. Gelcoat thickness, i.e, does not provide the real strength. It's how the fibers of the fiberglass cross each other and in which direction, together with the backing of the fiberglass, that provides true strength. http://www.whaler.com/Rec/default.asp?content=construction Whaler may not have the thickest layer of gelcoat or the thickest layers of fiberglass but the Unibond construction method makes for one of the strongest fiberglass hulls available. Erik |
| Buckda |
Agreed Eric, but I don't think Whaler is stingy on the fiberglass either, and judging by the hull weights on the newer boats, I don't think they're being stingy today. |
| David Livingstone |
Binkie, the glass on the 1966 16' that I did over a couple of years ago was real thin. Don't think I found 1/4" thick piece in the hull sides or around the absent floor. See the bottom of page 30 on cetacea http://continuouswave.com/whaler/cetacea/cetaceaPage30.html . Finished photos are on page 60. That said, to Buckda's point, I also have small u-mounts (held on by two screws each) that my Bimini straps attach to and they show no sign of wear on my 98 Montauk. David |
| Binkie |
I don`t think there is any question that hand laid up hulls are stronger than hulls laid up with a chopper gun, as chopper gun hulls are entirely laid up with fiberglass matt that is shreaded, and mixed with polyester resin, wherein hand laid up hulls, the outer layers are made up of fiberglass mat,(same materials as chopper gun) but inner layers use woven roving of various strengths, and are covered with more fiberglass mats. The new thing now is using kevlar instead of woven roving as a core material in fiberglass race boats. This gives extreme lightness and strenghts, and I`m sure it will evolve into pleasure boats someday. Some of these kevlar race boats are so lite, that the blowover problem is elevated. I don`t think any builders of small pleasure boats are using hand lay up anymore. I`m not questioning the strengh of Whalers,but I would like to see what their glass specifications look like. I`m sure it is not up to the person on the gun. and I think different boats have different specs. We all know they won`t sink. and you can always use the floating parts as a life preserver. Rich |
| GradyFan |
Binkie wrote: quote: Grady still does hand layup. |
| poker13 |
David, How did the 16 footer come out? Have you posted any pics? |
| merc125 |
I've cut out a section of deck from the 1966 13 I recently purchased, it is not thicker than 1/8". I'm repairing a hole in the floor behind the driver's seat. The hole must be ten years old full of mold and dirt, in a low spot on the deck , but no moisture has penetrated the nearby foam and the surrounding deck to foam bond is in very good condition. [Dead link removed] MartyD |
| pglein |
The whole point of the unibod construction is that it provides the strength and rigidity of a much thicker hull while only requiring two layers of glass about 1/8" thick. The unsinkability was actually a side benefit of the construction method. The glass is NOT from a chop-gun. Anyone who has ever laid up various kinds of fiberglass will know the difference (and I have). The glass on whalers is called "matt". It comes in cloth sheets and is made up of 1-2" unidirectional strands of glass. This gives it the maximum amount of strength given the way in which it is utilized. While draditional "boat cloth" (woven strands that run the length and width of the sheet) is better in traditional contruction methods as it provides directional tensile strength in four linear directions. The unibond construction method relies on the stress being distributed in all directions AROUND the foam core. This means it must have tensile strength around a full 360 radius. Thus, matt cloth is the better option. The fiberglass used on Whalers is by no means cheap, and anyone who says that they laid up the hulls using a chop gun, should be drug out in the street and shot. |
| David Livingstone |
Poker13, Jim published the finished 16' on page 60 of cetacea http://continuouswave.com/whaler/cetacea/cetaceaPage60.html . David |
| Binkie |
Several years ago, I took a tour of the Duskie plant around Miami, and they advertised that their hulls were hand laid up. So when I saw them shooting the hulls with a chopper gun, I asked the guide, where is the hand lay up section, and he said your looking at it, You don`t see any robots shooting those guns do you? I guess some folks have a different idea of hand lay up. Duskies are cheap copies of Makos, and I heard of a 26 footer that split apart at the keel and sunk.They used a 2 piece mold that is bonded at the keel. I heard about a 31 foot stone crab boat off Naples two years ago, that was carrying a load of crab pots, in heavy seas, and the hull just blew apart and sunk, and the 2 man crew died. It went down so fast, they didn`t even have time to get the eperb out of its rack. It was probably a hopper gun hull, but I don`t know for sure. I`m happy to hear that Whalers are hand laid up, even with mat only, and no chopper gun |
| busted 15 |
HAHAHA hey PG smoke another one brotha,think the fumes from your hand laid chopper are effecting ya |
| sweetrevenge |
Busted 15... ownes a Bayliner! I've owned 5 Boston Whaler's one I put on a coral head at 3/4 throttle with 7 people onboard! in the morning i dove over to inspect the damage expecting to see a cracked hull just to find a little chipped gelcoat. Any other boat and we all would have been swimming! |
| busted 15 |
naaaa actually im boatless at the moment ,thinking of picking up a checkmate this weekend and having a all welded alum built this winter,funny thou same company that builds Bayliner builds Whaler,maybe they use the same manufacturing procedures,im gonna stop stiring the pot here anyhow you guys take these things wayyyy to serious,your boats are all indestructable, they will last forever and ever have fun fellas take a deep breath |
| acassidy |
On my 22’ 1983 Whaler I replaced the front through hull with a 1”, 6” threaded brass through hull for a raw water pick up. The fiberglass was a good ½” thick there in this spot. Whaler always impresses me is the rigidity of these hulls. Going around the boat show one year, I kept bunching the sides of hull with my fist lightly seeing the flex and strength in the cheaper hulls. I like to broke my hand doing it to a Whaler at the show. |
| Tom W Clark |
"...anyone who says that they laid up the hulls using a chop gun, should be drug out in the street and shot." Whoa. Peter, next time you might consider engaging your brain before putting your fingertips in motion. The fiberglass skins of Whaler hulls are laid up with predominantly chopper gun applied resin and 'glass fiber. While 'glass mat is used in areas of high stress and abrasion, like the keel an certain stressed inside and outside corners, the rest of the skins are just chopper gunned. The skins are not that thick either. 1/8 inch is typical of the smaller Whalers. As the hulls get larger so must the thickness of the skins and the lay-up schedule is increased accordingly. But Peter is correct that the strength of the Whaler hull comes from the composition of the Unibond process. It is not the skins alone that provide the strength but the combination of the foam and the two skins. Whaler hulls are remarkably strong for their weight. Conventional hulls must derive their strength from the fiberglass skin itself and thus the fiberglass is much thicker. Whaler hulls are susceptible to punctures because of their thin skins but as (apparently the only) one here who has actually swung a sledge hammer against the side of a Whaler hull, I can tell you it is surprisingly strong. I can also tell you the thickness at the keel of even a little 13 footer is as much as 1/2 to 3/4 inch. It is also something of a myth that the first fiberglass boats were "overbuilt" and thus super strong. It is true that early manufacturers didn't quite understand all the strength properties of fiberglass and may have added more here and less there in their hulls, but mostly they didn't get the ratios of 'glass to resin perfect and simply added weight that didn't add strength. |
| pglein |
Tom, you have to excuse my narromindeness. I tend to forget that Whaler made boats after the 1970's. Back then, the chopper gun technology was pretty much non-existant. Having done repairs to my 1971 hull, I can tell you it was not laid up with a chopper gun. If they started doing that later on, I guess it wouldn't surprise me, nor would it concern me if parts of the hull were done that way. |
| RocketMan |
How about a typical commercial, government, or Guardian-type hull? I'm under the impression that they could, but not necessarily be, thicker than the 'recreational' versions especially if they are custom ordered. |
| BOB KEMMLER JR |
is that a checkmate or crackmate?,which is what quite a few of former owners call them.Don't believe all those soggy whaler stories either.I have a piece of foam from my 95 rage that has been sitting in a jar of wtare for over two years now,no waterlogging at all. |
| Tom W Clark |
Peter, Don't shoot! I have to take back something I said above. The maximum skin thickness of a 1970 13 footer appears to be 1/4" at the keel, not 1/2" as I stated. The skin thickness tapers down to 1/8" at a distance from the keel of only about 6 inches. I just happen to have a cross section chunk from a 1970 Sport 13 here which is some of what I have left over from a hull I completely cut up and dissected some years ago, the famous "Chainsaw Whaler." RocketMan, CGP (CPD) hulls always have heavier layup as do all the pre-CPD "Commercial Duty" or "Workboat Specifications" (a.k.a. "Red Dot") hulls. |
| pglein |
I know the repairs to the hull I did on mine indicated that the skin was rather thin no more than 1/8", maybe even less. Although, this was in the bow, halfway between the keel and the port sponson; an area that I would expect to be very thin as it would experience very little wear. By the way, it's actually quite easy to tell chopper gun lay-up from hand-laid matt. Matt comes as a flat sheet of glass and as such the glass strands are generally all straight and don't appear disturbed. When glass is laid up with the chopper gun it does not lay flat on the mold. It has to be flattened using a roller (so does matt, but not as much) and durring this process, the strands of glass are forced down and often become bent or curved. Thus, if you look at the fiberglass up close, look for strands that are bent over, or appear to be folded. If there is very much of this, it was likely applied with a chopper gun. Come to think of it, in the areas of high wear (along the keel, and sponsons), I distinctly remember seeing a boat cloth pattern in the glass. This obviously was laid up by hand. The chop method has it's uses, but in my opinion, traditional hull construction is not one of them. Chop works great for non-structural moldings such as seats and cabinets or even center consoles, but I wouldn't use it for anything that carries a signficant load. Honestly, most of those types of applications are worth considering vacuum formed plastic anyway. |
| RocketMan |
If the Guardian hulls are layed up thicker, then are they considered more expensive to buy than recreational hulls for comparable length and features? I'm under the impression that the recreational hulls are likely to have a better finish with the popular colors and more creature comforts. And the Guardians are more industrial in nature with the thicker hull wall and features ala carte contracted for by the original buyer. |
| rtk |
There is fiberglass mat: www.fiberglasswarehouse.com/chopped_strand_mat.asp And there is fiberglass cloth: www.fiberglasswarehouse.com/fiberglass_cloth.asp Both are used in traditional hand laid, or rolled fiberglass boat construction. Often a combination of the two will be used for layup, depending on the application. I think the chop gun was designed to emulate the strand mat cloth. A quick way to build up the fiberglass strands with resin to achieve a desired hull thickness in non-structural applications. It is easy to confuse a boat that was hand laid with mat cloth with a boat that was built up with a chop gun. Rich |
| Tom W Clark |
RocketMan, The Guardian (and all the other commercial/workboat models) are not just more expensive, they are MUCH more expensive. |
To add some confusion: here is a picture I took c.2003 at a Whaler dealer. This shows a hull cross section the dealer had on display. It is photographed with a very wide angle lens, so it looks larger than it really was. The object is about 4 inches high, as I recall. I do not know what boat it is from, nor exactly what all the stuff in the laminate might be. As you can see, there are a number of layers on the upper surface. I don't know if that is the hull or the topsides! |
| Tom W Clark |
Jim, That is an interesting photo. I suspect the outer hull skin is down, the inner hull skin up with backing material showing. The most remarkable thing about that photo is that it looks to me that it actually displays a section of a "Shear Brace", the formerly secret structural part of Whaler hulls. I would be surprised if a Whaler dealer had that to show customers as a factory authorized display |
As I mentioned in my article about the tour of the Boston Whaler plant, the laminate schedule of a Boston Whaler is something of a trade secret, or at least something they don't go around using in promotional literature. They don't even give it out to technical magazine reviewers. You can understand their position. They have done research and testing to find what works well and at the same time does not cost too much. There is no problem in making a boat fantastically strong and light, but just that it can be very expensive. If you are in a high-volume production situation, you want a laminate that is strong, easy to build, and not too expensive. You should look at the laminate with an eye to the results, not the construction. Whatever thickness it is, the hulls will last for decades if given reasonable care and not abused. That is a better yardstick that measuring the thickness of a laminate and pronouncing an opinion on it. These days Boston Whaler applies some science to the design of the boat and the strength of the materials used. In the way back it was probably not quite as scientific and more a result of trial and error. |
| BIG O |
I am sitting at my desk reading the post, and I took out my calipers, as I have a piece of my whaler here which I cut out to mount my bottom finder, its 9.75mm thick. I also have a piece at my warehouse when I mounted my transducer thru the hull, next time I go out I will bring it back and take a picture, I can tell you I had a hec of a time drillin thru the hull Big O |
| Binkie |
For us non engineers could you convert mm to fraction of inches. Thanks. |
| luife |
Tom W Clark, interesting comment about the secret or formely secret "Shear Brace" used in the BW hulls. I have never heard about it. It would be nice if you can explain briefly what is it. Thanks. |
| Tom W Clark |
Luis, Check these threads out: http://continuouswave.com/ubb/Forum1/HTML/004754.html http://continuouswave.com/whaler/reference/originalPatent.html |
| RocketMan |
25.4 mm per inch 2.54 cm per inch |
| luife |
Tom, thanks for the links. Actually, after reading those threads, I remember reading another thread about a repair on the deck of a Montauk and the owner stated and showed it in some pictures that there was a 2X4 within the hull. Maybe that's one of the sheer braces used for that Montauk. Interesting!!! |
| Binkie |
Rocketman, OK, we have a thickness of 9.75 mm. and you say that 25.4 mm equals one inch. No matter how I divide, multiply or subtract these numbers, (by the way I don`t know what one to use) I`m still going to wind up in the tenths of an inch. this is not going to help me out, because as every carpenter knows inches are divided into 1/16ths, which I believe is what boat builders use. You probably use the metric system when you design rockets, that why they call it rocket science. Actually rockets are not all that hard to understand, you always point the pointy end up and always light the end with the fins on it. Simple right? |
| Bthom |
9.75 mm = 3.07 eighths of an inch Cheers Brian |
| RocketMan |
Binkie - Yeah, shimple, we can do anything with funding and political will. American aerospace, believe it or knot, is one of the last bastions of 'British - American' ('English') units while Europe, Japan, the Russians and perhaps the rest of the planet use metrics. Except for maybe Canada and the Brits, who also use 'English' units, but with a twist! (e.g. 'imperial gallon') Cheerio. |
| andygere |
When I replaced the brass drain tube with plastic one in the forward sump of my Outrage 22 Cuddy, I had to oversize the hole. The section of hull I cut out was close to 0.5 inches thick (that's 1/2 inch or 8/16 inch for those non-engineers and scientists out there). I have a photo of this next to a ruler, which I'll post as soon as I can find it. It seems plenty thick to me. The unibond construction works kind of like an I beam, where the foam is the web, and the glass skins are the flanges. The glass does not need to be as thick to develop the same strength as in a single skin hull. In addition, a puncture failure in a conventionally built fiberglass hull can and often does result in the boat sinking. Not so with a Whaler, so the resistance to simple punctures of the outer skin is not nearly as critical as with other boats. |
| andygere |
Here's the real deal on the outer hull thickness and inner liner thickness of a 1989 Outrage 22 Cuddy. Note that the ruler reads in 1/16 inch increments, so nobody will have to do any long division to understand the measurements. http://photobucket.com/albums/v408/andygere/Whaler%20details/?action=view¤t=Outerhullskin.jpg http://photobucket.com/albums/v408/andygere/Whaler%20details/?action=view¤t=innerhullskin.jpg |
| highanddry |
Why let an idiot like Busted stir you guys up so,laugh at him and his Bayliner or aluminumthis and Checkmae that. If I wanted a Checkmate Icould probably buy one, kinda like a waterborne Corvette for guys with an image problem and hope all the flash and noise will make up for their defficiency, real or imagined. Feel sorry for him, poor thing. |
| aja |
I am a bit surprised nobody has mentioned that the thickness of the fiberglass outer skin is by no means the only factor in the strength of a whaler hull. If there was some way to make a hull using only the skin of a whaler I don't think anyone would argue that would be a bad idea. Similarly, making a hull out of just the foam core with no fiberglass skin would be a bad idea. The strength of the hull comes from the laminate of both materials and how they interact under stress. The whaler design is among the most rugged and robust available as evidenced by the popularity of these hulls for work boats. Our boat club has two 17’ hulls which have been through many years of abuse and neglect. Although they are by no means gems to look at today, I suspect these boats have held up better than any other would have under the circumstances, primarily because they have not sunk! |
| busted 15 |
hey High-and-dry now resorting to name calling is not very nice,maybe you could help PG drag me out,now I called it what it is, a chopper gun laid up boat ,whats the issue other than your hurt ego |
| dgoodhue |
In your frist post of this thread Busted 15 wrote: "its a chopper gun POS" "will vary from almost nothing to I would say no more than 1/4 inch and im being generous " "cut your hull on a sharp object and your overpriced new Boston whaler" You come on an enthusiasts website, and insult their boat b with word of "POS" and "overprice" and you want everyone to treat you nice?
Quote from http://en.wikipedia.org/wiki/Internet_troll "In Internet terminology, a troll is a person who posts inflammatory messages on the internet, such as on online discussion forums, to disrupt the discussion or to upset its participants. The word, or its derivative, "trolling", is also used to describe such messages or the act of posting them." |
| danhelminiak |
After removing all the through-hull fittings on my 1988 Guardian I have found the gunwhale and transom areas as having 3/8" thick skins and the bottom having 1/2" skin. The bottom thickness measurement was taken about 6 inches from the keel and about 4' forward from the transom. |
| fairdeal2u |
I always worried about penetrating the green fiberglass layer.Whenever I saw a chip past the gelcoat it was covered up immediately with marinetek. Bob Dougherty builds his new boats differently. High tech fiberglass materials and hand laid layers of webbing with heavy duty stringers and different types of foam placed and used accordingly. |
| onlyawhaler |
This is an interesting thread. One of the other boat lines I have great respect for Cobalt. They are top end family oriented boat in Kansas. They are family owned and in my opinion, represent one of the finest, home grown, kept in the family lines of boats in America. They have never been sold or aquired by the big names. Yes, they sink. That aside, they are famous for their premium gelcoat and glass work. I went through their factory 6 years ago while in the area on business and their tour is very detailed and explaines alot in skill of hull layup. They start with the gelcoat in the mold and then follow it up with a layer of choppergun. Their explaination of the first layer of choppergun first next to gelcoat is that it provides inital strength and hides the print through affect of glass mat or woven glass matt which they apply next. 4 layers of handlaid glass or woven matt with chopper gun shot in between each handlaid matt make up the hull and more in key areas. It was very informative. They do great work and make no excuses for choppergun glasswork in part of the makeup of their hulls. Whaler does use chopper gun glass in their hulls. Both the classics and new models have it. My question is how much handlaid matt is in there as well in the different models. I would guess that the classics have more chopper gun glass and the newer models have both. I am guessing on this because of the big difference in hulls weights between old and new. That weight is probably more glass work. Sterling |
| VI Jamie 22 |
I get to test drive a tremendous variety of boats. I am checking out my outboard repair, but I am always checking out the boat at the same time. You would not believe the number of boats that have stringer/bulkhead problems. I feel the twist in the hull when it lands of a wave. It makes me cringe. When a boat is solid and comes off a wave, it feels good, sounds good and is easier on the occupants and overall will ride and perform better. I have never been on a whaler that did not feel solid. Even my 1978 v-20 with its flatter than average bottom, always landed solidly. It is the first thing I checked on my 1979 22. In the sea conditions I live in, I wonder how many boats that spend their life down here could say that. |
| cbgann |
Per our Boston Whaler historian, Whaler started using the chop and hand layup process in 1958. Bill |
| cbgann |
As far a thickness, I agree with prior posts, the avg. thickness on the unreinforced areas of the 13-17' classics is roughly 1/8" max. plus the gelcoat and the alert is closer to 1/4" with cloth at the gunwhale and chines. The standard rubrail will not cover the hull to deck weld on the alert series without the L insert. Bill |
