Author | Topic: Propellor Guards |
David Newman |
![]() ![]() ![]() Has anyone experience [with] propeller guards? Is there any adverse effect to performance? Was there a US law to make them compulsory? Was it ever put into force? |
wezie |
![]() ![]() ![]() No law that I know of. Several lawsuits blaming propellers, not morons and accidents, for deaths and injuries. It seems to me that the most vicious lawsuits concern folks that know nothing of boats and believe that everything on the water is a party. Loss of speed. Increased drag and fuel. There are some avail for some engines. The only statement that I heard was from a RIB service company in Houston. Hi said that the guard might keep you from shoving your foot into the side of a prop. Without guard, the shape of the prop might tend to push your foot outward. The guard would; however, form a tube and any appendage that got into it would be quickly lost. Sort of down the disposal. Do not know what is coming down the road[.] |
contender |
![]() ![]() ![]() The reason prop guards have come about is because of idiots and people not taking responsibility for their own actions, Nothing more nothing less. |
PeteB88 |
![]() ![]() ![]() Are you looking for one to protect your prop like in shallow water or rivers? I've used them with small outboards with success. Best I found was sold through Clackacraft Drift Boats in Clackamas, Oregon. I think they can have them made for bigger outboards but these have worked for me when I was out there running rivers in smaller drift boats. https://secure.wolfpk.com/clackacraft/shop.cfm?action=product&groupid=1&productid=30 |
boatdryver |
![]() ![]() ![]() I used a prop guard for years on a Yamaha 8T kicker on my jet boat to control drift in shallow rocky rivers fishing for Salmon, to protect the propellor, not personnel. Drag was negligible at 4 mph. Great invention. There were lots of dings on the prop guard; none on the prop. http://i31.photobucket.com/albums/c391/boatdryver/Stbd-Qtr-web.jpg Most Tugs and other commercial vessels use huge prop guards in on the Inland Passage to Alaska because of trees in the water so they can run at night. they accept the drag-induced extra fuel consumption in return for being able to run around the clock. Of course they aren't trying to go 25 knots JimL |
PeteB88 |
![]() ![]() ![]() [Changed topic. This new topic is not within the realm of our discussion here regarding propeller guards--jimh.] |
![]() ![]() ![]() There is more information about the recent legal actions regarding propeller guards in our archives than perhaps on any other website. Read the articles in the archives found by this search. |
skinnywater |
![]() ![]() [Email the moderator for this topic--jimh] |
boatdryver |
![]() ![]() ![]() [Replied to the new topic. This topic is not within the realm of our discussion here of propeller guards.--jimh |
![]() ![]() ![]() Please stay on topic--we are discussing propeller guards. Thank you. |
contender |
![]() ![]() ![]() I stand corrected, after seeing the problems in the shallows water (was not thinking about these problems) of you northern boaters/fisherman I can see were a prop guard will be one of great need. We do not have this type of problem in South Fla.... |
PeteB88 |
![]() ![]() ![]() [Renewed again this new topic. Please stay on the topic of propeller guards. Thank you.--jimh] |
cooper1958nc |
![]() ![]() ![]() Propeller guards like other safety devices are usually met with derision. I recall the tirade against seat belts, because people thought it was better to be "thrown clear." One reader pointed out that guards may increase injury if a limb was caught inside the guard. Perhaps, but a look at the physics of the situation might suggest otherwise. A planing boat at 24 mph and 3600 RPM, with a nominal reduction gear of 2:1, swinging a 15 inch diameter propeller, has propeller blade tip speeds of about 80 mph. Damage from impact is related to the square of the speed, so the damage potential from the blades is about 11 times that from the hull or gearcase itself. At idle speed of 5 mph at 1000 RPM, the blades are going 22 mph and have about 15 times the damage potential as the gearcase itself. At idle speeds, humans can withstand collisions with the gearcase but not with the blades. In Florida huge tracts of inland water are restricted in speed for manatee protection. Manatees are somewhat more rugged than people and can probably withstand gearcase collisions on plane, but cannot do well with prop blade strikes. Perhaps protected propeller boats can in the future obtain some relief from the speed restrictions upon a demonstrated safety increase for these marine mammals. The subject of drag with propeller guards has been discussed earlier. Guards can provide an "endplate" effect that actually increases the efficiency of the propeller. The guard itself is more draggy. The net effect probably depends on the design of the guard, the speed of the boat, and other factors. Interesting is the idea, first articulated here, that guards may be linked to a control that allows limited vectoring of thrust. For instance, a guard may be designed to produce stern lift by vectoring discharged water downward. This would obviate the need for ventilation plate wings and maybe for trim tabs on some boats. Not all safety gear, even if government mandated, is worth an automatic tirade against government, lawyers, or even foolish boaters. |
pcrussell50 |
![]() ![]() ![]() Coop! Seatbelts are a bad analogy. While seatbelt laws may raise the dander of the diminishing populace who cares about liberty, seatbelts do not decrease the utility or efficiency of a car. Add-on Jet drives and prop guards positively ruin the efficiency of outboard motors used on planing hulls. From your post, I can see that you have a grasp of the high-school level equation defining the kinetic energy of a mass in motion. Well done. I'm going to hazard a guess that your area of expertise during your working career as an engineer was not in aerodynamics or fluid mechanics as you seem to be grossly underestimating, (or misunderstanding) the magnitude of the inefficiency that comes about from shrouding a propeller designed for high speed propulsion... which in boating, means, "any where near planing speeds", or faster. I don't dispute your argument about the safety of shrouded propellers, but we are told that we have a runaway greenhouse going on in our atmosphere that we ignore at our peril. Forcing boaters into expensive impeller drives that will require them to run 30% more powerful motors that use 30% more fuel, in order to extract the same utility they were getting with a regular prop, is not something that helps with reducing the greenhouse effect. Which of the contraindicating circumstances is more important to you? -Peter |
![]() ![]() ![]() In a prior discussion about propeller guards, I hypothesized that the manufacture and design of propellers and outboard motors is greatly influenced by a trend to improve performance, and, therefore, if shrouding a propeller in a guard were a method to improve performance it would likely have already been considered and exploited by the manufacturers. |
seahorse |
![]() ![]() ![]() It's been quite a few years, but I remember reading the Coast Guard reports of their testing different types of prop guards. They used cadavers and documented the "damage" in varying situations. The final report stated that the guards pulled and held the body parts into the propeller area and caused more severe trauma than an open prop that may have cut then thrown the body part aside. It was also said that the guards caused more impact damage due to their size on a direct hit to a body. |
cohasett73 |
![]() ![]() ![]() I installed one of the ring shaped guards on my father-in-law's pontoon boat. It worked great at keeping logs and branches out of the prop.On the other hand, I installed a composit prop on that engine and the guard worked great for funneling rocks in and shearing the prop blades off. Tom from Rubicon,WI |
cooper1958nc |
![]() ![]() ![]() O brother. The arguments get sillier and sillier. Global warming will be increased by propeller guards? That's pretty funny. If global warming is the critical issue to small powerboaters, there are at least fifteen things to do that would help clear the air, not the least of which is to immediately retire all two stroke carbed motors. Second, most 15 to 22' outboards could, if anyone wanted to, be made to run much more efficiently at the middle speeds that are most often used, including for instance: running shallow deadrise hulls; running hulls that run flat at slow to middle speeds without the squat of stern weight bias that favors high speeds; using large diameter propellers; developing two speed gearcases that reduce engine speed at slow plane; retuning engines for lean burn at middle speeds; and more. But returning to guards, Jimh says the manufacturers would have done it if it was worth doing. Jimh, if you believe manufacturers have a primary interest in either the environment or even safety to manatees or swimmers, I have underwater land to sell you. Unfortunately or fortunately, in this free enterprise system, corporations have little option but to maximize profits. Unless the government intervenes with regulation, saving the manatees is just not profitable. I wonder why there is a rush to ad hominem argument whenever a subject is discussed that elicits knee jerk disagreement. I won't go into it, but pcrussell50, my fluid dynamics credentials are pretty solid. I have taught fluid mechanics, aerodynamics, and computational fluid dynamics at the graduate level in a major university for years. Not that it matters, because I haven't asked anyone to believe anything that cannot be demonstrated easily. The "endplate" effect is real, and it increases the efficiency of a wing (or a prop blade). Ducted fans have been used, off and on, in airplanes and they work. Sometimes the tradeoff is worth it, sometimes not. Putting a shroud (guard) on an existing propeller design may not be optimal; probably a prop designed to run with a shroud would do a lot better. No one has commented on the possibility of thrust vectoring with a guard, something I find very interesting and maybe worth some work. I could find no USCG tests condemning guards; there is quite a bit of information on the internet though, and it is easily googled. It suggests this is a field ripe for technical development with a real need. Obviously, someone is concerned enough about propeller safety to reduce legal speeds to idle over huge expanses of inland water in Florida. Anyway, people believe what they want to believe. But sometimes reality is much more interesting. |
pcrussell50 |
![]() ![]() ![]() Coop! (Sorry, I don't know what else to call you, since you don't publish your name). My name is Peter, (not pcrussell50) I do publish my name. I am very excited at your credentials in these matters. It will make this argument much, MUCH easier.
quote: It's not knee jerk, my friend. I promise you. I've been not only a student of, but an operator of, high speed fans, both ducted, and unducted, for my entire professional career. Fuel prices being what they are, these topics are of very great interest to my employer, who has many engineers in it's employee, including some on loan from Boeing, GE, a Pratt and Whitney, and Rolls Royce. Oh, and my argument was not ad hominem. It was purely fact-based. My sarcasm at your application of the equation for kinetic energy was an ad hominem attack. I admit it. But it is important to separate which of our statements are ad hominem attacks from the statements that are true, lest the baby be thrown out with the bath water.
quote: I grant you on technicality, that you have stopped short of demanding federal regulations that boats be equipped with these things.
quote: No questions about endplate effect from me. I'm fully versed on it. If I were operating a heavy pontoon boat, that would go no faster than 15 mph, (about 6.7m/s), at 5500 engine rpm, I would use a Dura-Jet. But that form of boating of course, has no place in this forum. You must also know that as you get much over 8 meters per second in water, endplate effect drops rapidly to a second-order state as drag and structural loading become the dominant factors.
quote: May not be optimal?! Coop, you are the master of understatement, my friend! That made me chuckle.
quote: Agreed. Such a system would do much better. In fact, there already is such a system. The Marines use it on one of their "Black", military series Evinrudes, for tactical beaching ops. It is much better than anything else out there, with an engineered housing, a stator, and a proper impeller properly fitted to the housing and designed to work with the stator. And it still sucks. It sucks so very badly it's hard to describe. It's devastatingly inefficient at recreational boater speeds. In fact, I'm not even sure it's _possible_ to reach recreational boater speeds with it. At least DuraJet has the intellectual honesty to publish their test data... where they did not even reach 20 mph... at 5500 engine rpm!? Now why do you suppose they did not publish any data in the speed regime that say, Boston Whaler boaters operate? At least I can tell you that the endplate effect was working well up to about 18 mph though. Because their graph showed something along the lines of a 5% or greater increase in efficiency over a prop... at 10 mph... and if I were a pontoon boater, I would look at getting a DuraJet, really. I would. I launched an initial salvo. You fired back. Now let's talk turkey. Here's where we can hopefully tap into your expertise. You must know that when it comes to turbomachinery, the devil is in the details... very small details. Clearances not at the level of thousandths, but of ten-thousandths, make or break these things. This is one of the reasons (along with high temperature superalloys), that gas turbine engines cost not 10 times more, but 100 times more, per horsepower, than recips... and they STILL have greater brake specific fuel consumption. Now, you're an engineer. One of the things that differentiates and engineer from an pure theorist is, he is charged with making things that are of practical utility. That means finding a way to balance cost versus performance. Nobody is going to pay say, $150,000 for a 40hp outboard even if it is optimized by CFD and painstaking aerospace experimentation, and contains exotic alloys. It just won't fly, (pun intended). If it were up to you, as it would be if government forced this upon us, how much should we be expected to pay for motors that drive our Boston Whalers at their current speeds, a few mph either side of say, 40mph? Double? Triple? More? Or do you think it can be done for not even double current costs? If so, how? Maybe through public funding? This is not like a seatbelt or mandatory helmet law... not in any way. -Peter |
pcrussell50 |
![]() ![]() ![]() Whoops. Sorry for the crappy edit in the middle. I was about to be late for a test drive of a Montauk I'm looking at. -Peter |
