| Author | Topic: Bottom Paint Removal |
| ron3637 |
I am currently looking at a 1998 23 Conquest that has been kept in a slip at the ocean. I plan to keep the boat at a botel and was considering the advantages/negatives of removing the bottom paint or just leaving it as is. would like to know how difficult the paint would be to remove and a estimate of the cost for doing so. i dont want to get involved in a project that will cause me more trouble than its worth. i don't plan on doing the removal myself. Any advice suggestions would be appreciated |
| dhlaw |
well at the rate you are buying the boat by the time you actually close the deal the paint should be washed off......... |
| Barry |
Removing bottom paint is a LOT of work. The easiest way to do it is to pay someone else. If you are doing it yourself, Peel Away stripper works fairly well. However you will still have to scrap, sand, compound, polish, and wax. If the bottom paint is in decent condition I would recommend you consider not messing with it. If it is not in good shape it may be easier just to repaint. |
| bsmotril |
Some bottom paints are considered toxic and the removal requires proper disposal of the debris. If it is one of the newer ablative paints, it will self remove over time. I would leave it as is and think of it as a little extra protection for your hull from the fork lift jockies who stack and pack.\ BillS |
| ron3637 |
It never fails their is always one jerk in the crowd. |
| kglinz |
First step is to determine what is on the boat now. Then contact the manufacture and find out remove it without destroying the Gelcoat. A person could spend years learning about bottom coats. |
| ron3637 |
P.s. I want to thank the other posters for their help. |
The best tool for use in removing bottom paint is your checkbook. The ease at which the paint can be removed depends on the type of paint and the preparation given to the hull before the initial application. In my case, I found that the hull had not been rough-sanded at all prior to the first coat of bottom paint. This eased the removable enormously as the paint was not well adhered to the gel coat at all. I also found that I could mechanically scrape most of it off using a razor-edge paint scrapper, and if carefully done I did not scratch the underlying gel coat very much. I don't recommend this, though, as it is possible to get a gouge into the gelcoat that will require deep sanding to remove if you are the least bit careless with the scraper. I started this project with my transom, which needed to be clear of bottom paint so that I could install new setback brackets and transducers. It took a couple of days to get the transom cleaned up. The bottom paint I have on the hull is black and it bleeds off very easily if you wash it with a sponge. I have to be careful when washing the boat that I don't wash the bottom paint or I get big black stains on my sponge. It comes off rather easily. I intend to just let it wear away, although if I don't get the darn boat in the water more this year than last it may take a decade or two to accomplish. |
| dauntlass 18 |
I own a Conquest which I keep on a trailer. When I first bought boat I was sorry the bottom was painted.After two years and a few minor brush touch ups bottom paint is not too bad an idea.The paint on mine is a very hard paint.As part of sale I had dealer repaint bottom and supply me with a qt. of paint for touch up.I am going into year three of ownership and the paint is still in great shape.I do not have the touch paint avilable to ck on brand but Micron comes to mind as what is on my boat.Hope this helps you. |
| dhlaw |
gg |
| dhlaw |
Ron, I am sorry that you are offended but lets get real here. Almost two years ago you and I were e-mailing regarding my 21 Outrage that you had interest in, now you are still without boat. What gives?? If you think that you are going to find a bargain on a newer whaler you are out of luck. There are too many people out here that know the value and are willing to pay for it. As far as bottom paint goes, I had my 28 Conquest painted when I first bought it. Since then it has been put on a lift and I had the paint removed and the bottom looks like new. The main component was $$$. $1500 to be exact, and worth every penny. Bottom line is that boating is a very expensive hobby and from your reluctance to purchase I get the impression that you may not be prepared for the cash outlay (either financially or emotionally). Now buy a boat already! Any of the past 20 boats you have asked about would have been fine craft, as long as they say whaler. |
| ron3637 |
Even if the boat will be kept out of the water,I take it from most of the replies that as long as the bottom was painted properly there is no real advantage to removing it. Will the bottom paint eventually wear off leaving the gel coat behind or do I have to keep painting it? thankas |
| Barry |
The boat looks cleaner (nicer?) without bottom paint. I may also be little faster. As the paint wears away the boat can look lousy. The gelcoat underneath the bottom paint may have been sanded with a fairly course grit to allow the bottom paint to adhere better. That is one of the reasons that sanding will be required as part of the removal. Sanding is the only way to clean up and smooth out the previously sanded gelcoat. Of course if you sand too much, you'll remove the gelcoat and then need to re-gelcoat. |
| dhlaw |
The advantage to removing the paint is that you will gain 2-3 knots in sped and fuel efficiency will go up. Further, bottom paint hurts resale and looks like crap. |
| dauntlass 18 |
Ron go to www.uspaint.com ck out Ultra Coat bottom paint its the paint used on my boat.The finish does not chalk off like other bottom paints I have had on other boats I have owned.The finish really looks good.Like I stated before I would prefer no bottom paint but if painted and I wanted boat I would put a hard finish paint on boat before I tried to remove bottom paint.(I just checked my can of touch up its Ultra Coat 2779 black) |
| dauntlass 18 |
A correction web site www.yachtpaint.com sorry for the error. |
While it is widely cited that bottom paint reduces speed, the ultimate bottom surface is not always bare gelcoat buffed to a glossy shine. I recall hearing really gung-ho sailors talking about applying some special coating on the bottom to increase speed on their racing yachts. I think the stuff was so expensive it was banned from most recreational racing. It has something to do with maintaining laminar flow, but may only be effective at sailboat speeds. ron3736 has been conducting a very thorough search for a Whaler. We all look forward to hearing the final results of this process of discovery. |
| ron3637 |
How thick is the gel coat on a whaler? thanks |
| bsmotril |
Thick enough for the average jerk to not have to worry too much about it. But the laminate underneath is thinner than hulls with a non sandwich core. That is why Whaler says the trailer must provide keel support. BillS |
| doobee |
Dolphininite has a new bottom paint that can go on over old bottom paint and when you are done the hull will have a glossy finish. When wet it offers reduced drag and greater fuel efficiency, and it prevents organisms from attaching to the hull. Check it out at dolphinite.com |
| ron3637 |
What would be the appoximate cost for a quality shop to restore a painted bottom to original condition. I know it will probably vary based on the paint used and other factors, but i am only looking for a ball park range thanks again |
| Bigshot |
Dhlaw....I was amused! |
| Chap |
Nice jimh, Laminar. My father in law brought it up while discussing his theory on fast sailboats. He likes to wet sand a tad and get the water "as close to the hull" as possible. He dug this up: http//old.sailingworld.com/grimes.htm We also related it to the Speedo swim suits used in the Olympics, shark's skin application and maybe an outcropping of the concept listed in the article. Thanks |
| bsmotril |
"Riblets" was the surface coating to reduce sailboat drag. Thin horizontal ribs to maintain laminar flow. There was another theory of a limited amount of hull roughness to cause turbulence in the bonudary layer flow. Both were supposed to reduce drag, but I don't recall which was the better of the two. Lot's of Riblet info on google, ignore the ones referring to pork though. BillS |
