Topic: Replacing/ Repairing wood under front fuel tank cover 24 OR
bradenton_whaler
posted 04-07-2003 03:34 PM ET (US) I pull the front tank cover (floor) on my 1981 24' Outrage in order to replace the wood that is rotten. I'm looking for someone who has made the same repair.
It appears that the floor has two layers of wood covered in fiberglass. The top layer (with the nonskid facing the ground) appears to be a 3/4" thick ply. The second layer maybe 1/4". The 1/4" layer extends outward and forms a lip. Is my observations correct? It's hard to tell because I have not removed the top layer of fiberglass? What is the process of fixing this problem? If need be, I can email pictures if my text is unclear.
Thanks,
Frank
bradenton_whaler
posted 04-07-2003 06:04 PM ET (US)
I found out that this is called "re-coring". Any resources for this? What skill level is this project? I only have one of these and do not want to mess up or damage the non-skid top.
Thanks.
bradenton_whaler
posted 04-08-2003 11:26 AM ET (US)
Any resources?
Bigshot
posted 04-08-2003 12:22 PM ET (US)
take it to my bud Rick at 941-723-1188. He will do it cheaper than you can buy the supplies for. I am going there tonight if ya want to go(palmetto).
bradenton_whaler
posted 04-08-2003 01:26 PM ET (US)
What time are you going over there? I might have to work late today and I'm in the Tampa office.
-fr
Bigshot
posted 04-08-2003 02:48 PM ET (US)
Dunno....6ish? call me at 545-3808 and let me know when you are heading home. I can give you directions, etc if I am already there, etc.
rolfwoods
posted 04-09-2003 10:07 PM ET (US)
I have a 1978 OR V20 and have just done the same thing. It's a relatively awful job. It took about 2 days of haRD WORK to remove all of the old wood.I only broke through the gel coat in 2 or 3 places. I the had the good fortune to have a machine shop with a 10' X 4' steel work table with lots of clamps and steel bars. I laminated (2) 3/8" sheets of plywood to the existing shell with West System epoxy. Then applied 3 layers of cloth and polyester resin to make up for the correct thickness. Since you are going to all this trouble, you might consider replacing that 20 year old fuel tank (mine only had 3 holes in it). If you want t see some pictures of this debacle, email me. Rolf
Outrage18
posted 04-10-2003 10:23 AM ET (US)
Rolfwoods-
COuld you please send me email pics from your job of replacing the floor on your boat.
Thank you! Paul
bradenton_whaler
posted 04-16-2003 09:54 AM ET (US)
OK. I have extracted all the wood and now have a the shell to fill. Has anyone recored their decks with Nida-Core. I've heard excellent things about it but wanted to know how easy it is to work with.
Thanks.
Bigshot
posted 04-16-2003 11:14 AM ET (US)
VERY easy to use and tough as hell. Spend the extra money and use it. You can cut it with a knife so easier to cut. Once you glass it you can whack it with a sledge hammer and it will laugh at you.
JimU
posted 04-16-2003 03:22 PM ET (US)
Just did the same reapirs on my 25. Remove th deck. It has two layers of plywood-- a 1/2' sheet and a 1/4 in sheet. Scrape out rtthe rotted wood relpace it with new wood. use polyester resin to glass in the first layer then the second. a good fiberglass man can do it for about $500.Good luck. JIM
Bigshot
posted 04-17-2003 10:25 AM ET (US)
Jim, He already has the wood out.
