  cutting down transom
Author Topic:   cutting down transom
JesseS posted 04-07-2003 06:14 PM ET (US)   Profile for JesseS   Send Email to JesseS
I have a 1980 13' whaler with a 20" transome. I have a short shaft 25 horse evinrude that i will use on the boat. Do you think I would be making a mistake if I cut down the transom on my boat, I don't want to have to spend 250$ on a extention for the lower unit. Thanks for the help.
Taylor posted 04-07-2003 06:26 PM ET (US)     Profile for Taylor  Send Email to Taylor
It seems that most of the discussion around 13 footers and transom height has revolved around long shaft engines on a 15" transom, which is what earlier 13's had. Considerable effort has been spent by some to build their transom up to accept a 20" motor. They seemed to prefer them that way.
I would think that cutting the transom of a later 13 down would be a bad idea. First, it would expose the wood embedded in the transom. Second, I thought that short shaft engines are now rare. It might have a negative impact on your resale value.
Over the LINE posted 04-07-2003 08:27 PM ET (US)     Profile for Over the LINE  Send Email to Over the LINE
I think cutting down the transom would be a bad idea. Either make your motor a 20" or change to a 20" (you may end up with one in the future anyway as 15" are hard to come by except smaller HP) Possibly look at a jackplate with a large setback. This may allow enough room for shift cables etc. without any real modiification. Have not done it myself, it's just a thought.
doobee posted 04-07-2003 08:36 PM ET (US)     Profile for doobee  Send Email to doobee
Don't cut your transom! (he said sternly)
After you figure the cost of your time and materials (FG, resin, gelcoat, multiple grades of sandpaper, rubbing compound, and wax), along with the loss in resale value, $250 will seem cheap.
hooter posted 04-08-2003 09:49 AM ET (US)     Profile for hooter
If that short-legged engine is important to you, Ah guess Ah can relate. Gotta neighbor lady with a old Bearcat hangin' on the wall of her garage, Ah've been offerin' to buy from her for the last 15 years. She won't part with it, "Because that was give me by mah Uncle Omer, and he meant the woild t'me!". So there it still hangs. Your Uncle Omer give you that motor, by any chance, or mebbe your Great Aunt Binny May?
You'll probably find an older 13' out there with the short-pants transome, the owner of which would gladly trade for your long-pants 13'. Just a thought to save that $250 and make ever'body happy.
Keep that ugly saw away from that innocent li'l Whaler, ok?
Bigshot posted 04-08-2003 10:20 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
bad mistake!
Look on e-bay for a long shaft lower unit or do a 6" setback jackplate and it will work. Clark has installed a few 15" on 20" boats and loves the performance. Either way, the $250 aint worth the fiberglass itch you will receive. Also with the curvature of the transom, I doubt she would mount right if cut. PLUS....everytime you come off plane water will come over the transom and the engine, not good.
JesseS posted 04-08-2003 04:57 PM ET (US)     Profile for JesseS  Send Email to JesseS
I will not cut down the transom. I wasn't big on the idea, but if there were alot of other whalers with the 15" transom might. I have used the 15" motor on the boat for a year and I'm not happy with the performace, because it sucks air alot in a heavy chop and when I turn hard. I also seems slow with the 25hp(under 25 mph) and barly planes with three people. I guess I start looking for the extention.
doobee posted 04-09-2003 12:27 AM ET (US)     Profile for doobee  Send Email to doobee
Another innocent Whaler saved by the transom police!)
Bigshot posted 04-09-2003 09:28 AM ET (US)     Profile for Bigshot  Send Email to Bigshot
That won't help your speed or ability to plane. 25 is not made for 3 adults. Find a 30-40hp 3cyl.
