Topic: Replacement Powerheads - Toasted Engine
Owen Schultz |
posted 04-19-2003 05:40 PM ET (US)
Well, after purchasing my first boat ever...a 1988 17' Newport with a 1990 Evinrude 100HP 4 Cyl with VRO I was as happy as could be, almost giddy. Took it for its first outing and it ran fine for about an hour. Had such a good time we took it to a second lake. Then while running wide open it just bogged down and quit. It did this a few more times and at one point was very hard to get restarted so we took it out and dropped it off at the local shop for a check up. They took it for a ride and said it wasn't revving up to the proper RPM's that it was only getting up to about 4800. Although when I had it it was up to 5500. They then took it back to the shop and the top left valve (looking from in the boat) had very low compression and was toast. So they reccomended I purchase a new powerhead and redo the engine. Since the same shop reccomended the boat to me to buy and serviced it before it went out they are going to give me the parts at cost. The remanufactured powerhead is going to run $1600 and they are going to do the work for $500 Usually ($750+ they say). I bought the boat for $5500 and it came with a two year old galvanized Shore Land'r trailer, a new bimini top, and they threw in a new refurbished aluminum prop. I have contacted the seller (a friend of mine)to see if he will help absorb some of the cost. Any comments from you motor heads out there about how you would procede mechanically? Anything I should be aware of? Will the engine be like new? Will I feel any difference in power since the valves on the new powerhead are bored out? Would anyone put a new engine on it instead? What a bummer......
shoctor
posted 04-19-2003 06:15 PM ET (US)
Sorry to hear that you had such a bad experience. The hull is worth it's weight in gold. The new powerhead is a good option and a money saver. However you have to look at the rest of the motor. You are on the verge of old technology and the resale would not be there even with the new powerhead. A new motor is nice but expensive. I had the same dilema and decided to go with a used motor that had low hours on it. The motor runs great and is ten times better than the old. the price for the new powerhead is (average) However is this price for them rebuilding the powerhead or a "new" powerhead. If they are rebuilding I would lookcarefully as my experience is they don't last as long. New is best but a good used can be a good second choice. I would look at iboats.com they seem to have great deals and eople have good experiences thus far. Just my .02 Shane |
Owen Schultz
posted 04-19-2003 06:47 PM ET (US)
They were going to order a remanufactured power head that is already rebuilt. Although they are master mechanics they said they would recommend the powerhead come rebuilt. As they explained it, they can rebuild it charging more in labor and less in parts, or they could order it pre-built charging more in parts and less in labor. Either way they said the cost would be close. I am starting to think I should look for a newer used engine. The fellow i bought it from is willing to give me a $1000 back. I agree with you about the resale. They don't even make the E100STLESB anymore. I definitely want to put another 100HP on it though. It was running so sweet for that one golden hour, and the boat was handling so well. You could make super tight turns without it sliding off track at all. I don't think I can afford a new motor. I guess I'll start seaching the net for a used. Any good links to used motor web pages would be appreciated as well as any advice on a sweet 100Hp to look for. I can't wait to get back on the water. That was the best time I've had all year! |
whalernut
posted 04-19-2003 08:11 PM ET (US)
Owen, I am sorry about your motor dilema. I have a 1975 85h.p. Johnson on my 1973 `16 Currituck and it still runs strong, so it baffles me why your engine went so fast, I really don`t trust VRO myself, but some people like and trust them. anyway, you said you were looking for a 100h.p. again, you would be easier to find a good used 90 or 88SPL, the 90 being VRO and SPL being mix 50/1, my preference, I know it is getting a very good bit of oil. I don`t know if your old controls will work, but they could be modified I think if not. You may also look into a Yamaha 90 in Oil Injection or Mix, the oil is under the cowling on their oil-injection system as are the 90 Mercs. To bad you didn`t have more money, a New 4-stroke EFI would be my first choice, but I don`t have the money either!! If my beast on an 85h.p. Johnson ever bites the dust, I would seriously think about sitting the boat and saving up for a Merc. 60h.p. 4-stroke or Zuki. 50h.p. 4-stroke, I feel the 70h.p. Zuki 4-banger is way to heavy for my older lighter Currituck. But then I really dig the non-oil injected Yamaha 70 h.p. 2-stroke or the 90, depending on price, I really don`t need alot of speed. Good luck, I feel I will be in your shoes one of these days, and there is alot of choices out there, the best case cenerio is one that would be the same bolt pattern as my old 85, I really don`t want to have holes filled!! Jack. |
Sal DiMercurio
posted 04-19-2003 08:20 PM ET (US)
Owen, hold on a sec. If you buy a used engine, you have no idea of what your getting, the guy is probably selling the engine cause he beat the crap out of it. A new power head is just as good as a new engine if done right. Hell, if the seller is going to bounce for a grand, your in a rebuilt for a grand, believe me, you wont find a decent used 100 hp for a grand, that dosen't have 3,000 hours on it. My guess the reason the other engine blew is, he most likely "NEVER" de-carboned it & you really put the hurt to it running wot every where you went. If you don't de-carbon an engine, expect to pay the piper. By the way, those things aren't called valves, their cylinders with pistons in them & they require top notch oil such as omc tcw3, not elcheapo from walmart. Sal |
Owen Schultz
posted 04-19-2003 09:07 PM ET (US)
Whalernut - You are right, the choices seem unlimited. One thing I wonder about is why there are no more 100's being made. Seems like all I can find new are 90's and 115's. My Newport is rated for a 100 max and I'd like to put the max on it if possible for cruising. Why do you prefer mix to oil injection? Are you familiar with the drawbacks of each? I'd be interested in knowing that.Sal - Yeah, cylinders. Ooops. After looking around at new and used newer engines I have kind of got sticker shock. My god, the motors cost more than my boat. A rebuild is sounding better all the time. How does one de-carbon an engine? Is it something the end user does or the shop? How often should one do it? I think you are right, you never know what you are getting when you go used. You seem to be mechanically knowledgable...do you prefer injection or mix? The oil tank had the OMC oil in it as that is what the shop recommends. |
Sal DiMercurio
posted 04-19-2003 10:35 PM ET (US)
Owen, de-carbing a carboratored engine is so easy my grand daughter can do it. Just buy a can of "Engine tuner from any omc [ johnson evinrude ] dealer & follow the directions, sure cleans the inside of the engine like new. Your engine will idle & run far smoother & you wont have to worry about carbon building up behind the rings & breaking them, [ most likely what happened to yours ]. As far as injected oil system, I have full confidence in the newer engines with vro or FICHT. I run a 2000 - 200 hp Evinrude FICHT [ oil injected ]on my v20 outrage that scoots 60+ mph. Yep, 60+ Sal |
John O
posted 04-20-2003 12:49 AM ET (US)
Owen,I feel your pain. I bought a 1988 Newport set up as a center console. I blew the Johnson 1988 88hp spl at the end of the summer. After a long search for a decent used I decided on new. I found a new 2001 75hp Merc 2 stroke in Fla that was a floor model. I picked it up for 3800 plus shipping 200. so for 4k I have a new motor with a 1 year warranty. I did have the benefit of shopping over the winter. I drove several people here on CW with my many inquires of various makes and models. This was a major purchase for me and I took my time. I think you are fortunate that your friend gave you something back. I would either take the rebuilt with some sort of warranty or bite the bullet and go new. 90 hp should be plenty for the Newport. I would have prefered a 90hp but the price was right for the 75 Merc. Locally I was quoted upwards of 7000 for a merc 2 stroke salt water series. |
frank_king
posted 04-20-2003 01:20 AM ET (US)
if you go with a reman or rebuilt you had BETTER make sure you do not have plastic bowls on the carbs.omc has an upgrade on the v-4 carbs that came out with plastic bowls on them. the plastic bowls were faulty...... they crack down inside the lower bowl area and allow "unmetered air" into the engine. if any "unmetered air" gets into the engine the fuel and air mixture is not correct and the engine burns up. this is fact.... the way to fix it is to install the newer carb bowls. not to many people know about this and they just install all of your external parts on a reman powerhead and in time it burns up again. the people who fix it don't know why it happens, it has some people scratching there heads. go reman because you should get a longer warranty than if it is rebuilt. (SHOCTOR) it has to do with who you have rebuilding a powerhead. frank
whalernut
posted 04-20-2003 10:47 AM ET (US)
Frank, do you know what years the V-4`s had the Plastic Bowls? You have me thinkiong about replacing them on my 1975 85h.p. V-4? Or am I fine with this older model? Jack. |
frank_king
posted 04-20-2003 12:04 PM ET (US)
not coming off as a smart a@#, just look at your carbs and see if there are plastic bowls on them. i am not sure of the years that omc put the plastic ones on the v4, i just look and can tell. frank |
frank_king
posted 04-20-2003 12:09 PM ET (US)
also when replacing the bowls the jets do not just get pulled out and reinstalled in to the new bowls.omc says you have to order new jets with the new carb bowls. the outside diameter thread pitch is diff on the new bowls. the actual jet size doesn't change, just the thread pitch of the jet. frank |
jimp
posted 04-20-2003 12:19 PM ET (US)
Owen - Tough break. I did the same thing last summer. My 1990 225 Johnson was running better than ever before it ate itself. Repairs would have been $8,200 to put it back together. I looked at used engines, new powerheads, etc and decided on a new engine. I looked at 1990 as "old technology" (things MUST have changed since 1990!) and figured a new engine would eventually help resale, plus hopefully be more reliable and supportable. My new engine will be installed in the next week. JimP |
andygere
posted 04-20-2003 01:17 PM ET (US)
Owen, If your net out of pocket will be $1100 for the new powerhead, you can't really go wrong. You will still be way ahead on market value for that boat, motor and trailer assuming the boat is in good shape. Get the best warranty you can on the work and get back on the water. A new outboard will cost you at least what you paid for the whole rig, and if you buy used it could blow up tomorrow. If possible, get the shop to try and figure out the cause of the powerhead failure so it doesn't happen again. |
bsmotril
posted 04-21-2003 10:04 AM ET (US)
If you are going to replace the power head, also rebuild the carbs. If Carbon did not kill it, a lean running carburator probably did. Don't take the chance of the old carbs killing the new powerhead in the same manner as the original. BillS |
Owen Schultz
posted 04-21-2003 04:17 PM ET (US)
Yeah, the shop said they would rebuild the carb, and one of the guys says he always replaces the VRO as well. However, the plot has now thickened a little! It turns out the block for that Evinrude is not made anymore and they cannot get it through their main choice of supplier. They have found it through another, but their cost would be $2200 instead of $1600. They have offered to sell me another Evinrude that is a used 1994 90HP for $2000. This means that with the guy that sold me the boat kicking in $1000 that i will be into a new (used) motor that is 4 years younger for $1000 and be on the water this weekend. Sounds pretty good.I am thinking that I will go this route. I will be restoring this 88 17' Newport for a while and figure I ought to get a few years out of the new used engine. According to them even though it is a 90HP and I had a 100HP there won't be much difference in power sice they use the same block. Upon completing my restoration I will then (bank account willing) put the crowning jewel of a new motor on her. The guys at the marina are working very well with me. I feel sure that if this second motor blows in the next couple years that they will sell me a new motor at close to their cost. This brings up a very interesting question though that perhaps some of you have dealt with. It seems that many of the boats made these days are not sized for a 100HP anymore. All of the motor makers are selling 90HP and 115HP now. I have heard that I can get the Coast Gaurd maximum capacities plate for my Newport modified to accept a 115Hp motor by dropping the persons allowed on board rating by one person. This may be desirable when it comes time for the new motor. Anyone done this before? I would think this would put the cruising spead near 50mph. Comments? |
Sal DiMercurio
posted 04-21-2003 05:04 PM ET (US)
Owen, it would take no less then 1 year to get the tag changed, & I really don't think they will do it. To be honest, I think someone is jerking your chain about being able to get it changed, i'v never known or heard of anyone being succesful. I looked into it because i'm 50 hp over max rating, couldn't get to first base. Sal |
