  Time for Impeller???
Author Topic:   Time for Impeller???
GAwhale posted 07-29-2003 02:53 PM ET (US)   Profile for GAwhale   Send Email to GAwhale
Hello All! I haven't posted in a while. I have been kind of busy. I spent a week on the Island of Nantucket and saw lots of Whalers, but was hard pressed to spot a 190 Nantucket. I also spent a long weekend in Sarasota and saw lots of whalers.
This is the third season for my 2001 Montauk and 2001 90 horse two stroke Mercury.
I stopped by the shop at the marina where I keep my yacht. The mechanic suggested changing the rubber impeller every two to three years.
He would change the impellar for approx $125 and change the lower end oil for $16.
Is it time to change the rubber impeller and is this a fair price?
Thanks in advance for any advice.
Sal DiMercurio posted 07-29-2003 03:23 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Evinrude engines need to be changed every 2 years, Merc engines are recommended at every 100 hours I belive.
Even if the engine is a 2000 & still in the crate, the fingers on the impellor loose their elasticity & can no longer pull or push enough water to cool the engine.
If your in the 3rd season on that engine, it is highly recommended to change it soon because it's past the time to change.
Even if you have a strong tell tail flow, it's time after 2 years.
The worst thing a person can do is, not run the engine for a couple years, by then the impellor is shot without ever being in the water.
Sal
Sal DiMercurio posted 07-29-2003 03:24 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Sal
simonmeridew posted 07-29-2003 08:22 PM ET (US)     Profile for simonmeridew  Send Email to simonmeridew
Sal:
My 99 Johnson 70 with original impeller still shows good pressure on the water pressure guage: 12 psi at idle and up to 25 + psi at WOT. This has been consistant for the last 3 years. The motor has maybe 200 hours on it. Do you think it still needs new impeller?
simonmeridew
Dick E posted 07-29-2003 08:46 PM ET (US)     Profile for Dick E  Send Email to Dick E
I agree change your impeller.
Regarding fair price.
It should take about 1.5 hours labor for the impeller change. $25 for parts. $125 total that's about right.
Lower unit about 9 bucks for the lube and 7 bucks labor are resonable.
Sal DiMercurio posted 07-29-2003 10:16 PM ET (US)     Profile for Sal DiMercurio  Send Email to Sal DiMercurio
Simon, 3 years is the "absolute maximum", better change it or your gonna be sorry.
I'm pretty handy at fixing engines & I wouldn't think of going over 2 years, but of coarse, I fish a looooong way out sometimes & would have to hide my face in shame if I needed to be towed in because of not changing the water pump.
The $125 - $150 is very cheap insurance every 2 years.
I'v seen tell tails really pushing water out & the next day,.......no water & 18 miles from land, it aint fun my friend.
Why wait till it gos out ?
I gaurranty it wont go out at the dock of on the trailer, only a minimum of 10 miles from the nearest ramp & usually just before the sun gos down so you can really go nuts trying to find help.
Do it asap & it's done for 2 more years.
It's called preventative maintenance.
Sal
Smallfrye posted 07-30-2003 02:58 PM ET (US)     Profile for Smallfrye  Send Email to Smallfrye
My Johnson 225 ran fine through the time it took to decarb and tune the motor on earmuffs. The next day I started it and lost water pressure in a few minutes. The tell tale was still flowing but the motor over heated in 10 minutes.
Sal is right, this should be scheduled manintinance every year or two, based on use. This is very cheap insurance.
Sal, in the process of dropping the lower unit to replace the impeller, the drive shaft seems to be hanging up. The lower unit drops about 3/4" before this happens.
My experiance is mainly with Merc's, is there something about this Johnson that is different ? What am I missing ?
BW23 posted 07-30-2003 03:50 PM ET (US)     Profile for BW23  Send Email to BW23
Did you disconnect the shift rod below the carb's ??
If not, you need to.
whalersman posted 07-30-2003 04:33 PM ET (US)     Profile for whalersman  Send Email to whalersman
GAwhale,
BW23 is correct... There is a screw below the carbs that attaches the shift rod to the shifter arm.. This screw/bolt is not easy to see or get to... I used a couple of 1/4" extensions with a swivel inbetween and then a small 1/4" ratchet... Once the screw is removed, the lower unit will come out the rest of the way...
Getting the screw back in was even more difficult... I had to have a buddy come over and guide the shift rod up while I aligned the rod in the upper shift bracket...
Joe
whalersman posted 07-30-2003 04:34 PM ET (US)     Profile for whalersman  Send Email to whalersman
The question above should have been directed towards Smallfrye....
GAwhale posted 07-31-2003 08:46 AM ET (US)     Profile for GAwhale  Send Email to GAwhale
I finally dug up the owner's manual for my Mercury outboard. The manual covers the 75 - 90 - 115 - 125 horse power outboards.
Under the maintenance section under
'EVERY 300 HOURS OF USE OR THREE YEARS' it states,
'Replace water pump impeller (more often if overheating occurs or reduced pressure is noted).
I do not have an hour meter, however I feel cetain my engine has barely 100 hours. I am going to wait one year before I replace my impeller.
Smallfrye posted 07-31-2003 09:37 AM ET (US)     Profile for Smallfrye  Send Email to Smallfrye
Thanks Guys, this sounds like a typical three arm application. I will get some help to finish the job.
Jim
