Topic: transom replacement
arctic cruiser |
posted 08-13-2003 03:56 PM ET (US)
Hi,Looking for some experiences on transom replacement/reinforcement. The transom on my 1971, 21 foot outrage has some cracks and I am concerned that this will develop into something more serious over time. Currently the boat has a 225 hp Yamaha v6excel which likely is heavier than the transom was originally designed for. Any info on methods, materials and how this can be done would be greatly appreciated. Peter
dfmcintyre
posted 08-16-2003 09:45 PM ET (US)
Peter - The 1973 21' Outrage I rebuilt had dry rot in the transom, and it was replaced. First, have you checked for any dry rot? And where are the cracks developing? What the shop that handled the transom did, was cut out the rear section with a circular saw, from the top of the transom, just inboard of the sponsons (where there is a little step pad), all the way to the bottom. They then pealed off the outerskin and dug out all the rotted wood. Replaced it with multiple layers of 3/4" marine plywood, bent or planed to meet the origional curve. Then added multiple layers of glass and finally painted it during the whole boat paint job. Ran around $3000 on top of the other stuff being done. Don |
arctic cruiser
posted 08-18-2003 01:46 PM ET (US)
Don,thanks for your reply, the cracks on transom are where the transom meets the actual body of the boat (sponson?) I have not checked for dry rot and that will be the next step. What is the best method to check for the rot? I have read the article on restoration of your boat, looks great and very helpful! Just wanted to ask you another question on using the sikkens vs. gel coat; - due to the poor condition of the gel coat on my boat, I am considering sanding most of it off and painting with the sikkens 2-step system that you used, did you sand off all the original gel coat prior to application of sikkens? how have you found the durablity and performance to be? Since I am doing all this work myself, the sikkens system sounded like it was easier to apply than gel coat, but the transom part sounds like a tricky job.... thanks peter |
Bigshot
posted 08-18-2003 01:53 PM ET (US)
Why on earth would you sand off the gel? Just sand with 220 to scuff it up some and paint. The gel is what gives the boat its shape, NEVER remove it. New way of replacing transoms is they dig out the wood and leave the inner and outer skins. They then fill with a liquid epoxy.....really neat. |
arctic cruiser
posted 08-18-2003 03:12 PM ET (US)
thanks,ok, will not sand off gel coat, but I am wondering if a couple of coats of west coast system epoxy over the old gel coat followed by the paint would be a good set up.....any thoughts? |
Bigshot
posted 08-19-2003 10:23 AM ET (US)
Not necessary. Boats flex.....you do not wnat them too rigid or paint/gel will crack. |
DaveNJ
posted 08-19-2003 11:30 AM ET (US)
The pourable transom repair that Bigshot is talking about is: http://www.transomrepair.com/ |
arctic cruiser
posted 08-19-2003 04:44 PM ET (US)
the transom repair system is quite impressive. what is the best way check for dry rot, drill some holes into the transom? |
arctic cruiser
posted 08-19-2003 04:45 PM ET (US)
