Topic: How hard is it to restore a hull?
billh1963 |
posted 08-29-2003 12:25 PM ET (US)
I looked at 1968 13' boat today that looked pretty rough. The engine is probably 10 years old, the trailer is the original steel one from 1968 (but is still in good shape..fresh water only), but, the hull looks like crap. The boat was left in the water for most of its 35 years of life. The gel coat looks like it has major cracking over the whole hull, the blue inside is faded to a faint baby ble, and there is a stainless steel transom plate over most of the transom. The wood at the top edge of the transom has been exposed for some time (the fiberglass has broken off long ago). I can probably buy this thing for around $500 (trust me...it looks ugly). Could this hull be restored and at what cost? Would it be worth the effort>Thanks!
Robob2003
posted 08-29-2003 01:36 PM ET (US)
Billh 1963,My first inclination would be to pass. Before I bought my 1966 Sakonnet I was looking at a boat that needed the transom replaced and I was quoted in the neighborhood of $2,000. That's not a neighborhood I want to visit. I only paid $3,600 for mine with a good trailer and a newly rebuilt 100 Johnson although it took two years of shopping to find one with a mahogany console and seat I can rebuild myself. I would shop around unless you're really good with fiberglass and can avoid the repair shops. Bob on Tampa Bay |
billh1963
posted 08-29-2003 02:06 PM ET (US)
Thanks, Bob. That's my first inclination... run away! I just bought a 17' Montauk off the marketplace forum here (I'll get it at the end of September). Anyway, this boat popped up in the paper and I thought if I could get into it cheap enough I could fix it up over a couple of years and give it to my two boys when they hit their early/mid-teens. I have to admit...it looks like more than I want to get in to. Thanks! |
SMLWhaler
posted 08-29-2003 02:36 PM ET (US)
I have a 1963 13' that was given to me with the trailor, no motor. When I first looked at it I wasn't sure I could do it justice. It was a fresh water boat and had been on the trailor for many years. The hull had lots of spider cracks and several delaminated areas that required some major patch work. The inside was rough too but no delamination as far as I can tell. However, it sounds like it was in better shape than the one you are considering. I have been working on the hull since the first of June. I have the hull finished with the exception of buffing and waxing. It was a tremendous amount of work. Sanding, patching and sanding, sanding and then more sanding. I sprayed new gel on the entire hull. It looks really good. Its hard to work with the gel but not as bad as I had thought it would be. If you feel ambitious go for it. Its a lot of fun. Good Luck!! |
ryanwhaler
posted 08-29-2003 05:31 PM ET (US)
If its got a good motor, go for it. What kind of motor does it have? How much hp? |
ryanwhaler
posted 08-29-2003 05:32 PM ET (US)
PS,Does it run? ;-) |
spenttherent
posted 08-29-2003 10:58 PM ET (US)
I am in the final stages of refurbing a 17 Nauset and it is a lot of work. I tried doing it myself at first but let a professional take over. It was taken down to the glass, primed and will be painted with Emron (spelling may be off). The exterior sides and bottom are done and it looks great. When I found the boat it looked like yours sounds. I paid $500.00 for the boat with an old but in good shape trailer. It sounds like a lot of work. |
hooter
posted 08-30-2003 04:05 PM ET (US)
Best way t' answer your question is with the fine set of photos fellow member "Gep" posted a few days ago. Go get' her!link: http://f2.pg.photos.yahoo.com/mgephart1234 |
billh1963
posted 08-30-2003 06:39 PM ET (US)
It's got a 30hp Mariner on it...about 10 years old. Runs good. The boat looks complete...console, plank seats, etc. It even has a trolling motor mounted on the bow. The hull just looks so crappy with heavy growth on the bottom and serious gel coat cracking. I'll try to take some pictures. What does a professional usually charge to refinish a hull? I know it depends on how much work is required but what is an average based on everyone's experience? Bill |
wayne baker
posted 09-02-2003 10:45 AM ET (US)
Bill I must agree with the majority of the post above. The boat is worth 500.00 with a running 30 horse. But if you plan on hireing out hull refab you could buy a much nicer hull for less money. One the other hand as a project another 500.00 and a lot of hands on time will net a nice boat with small dollars invested. |
