Topic: Cost to Reseal Lower Unit
kend |
posted 11-22-2003 11:29 AM ET (US)
I have been told I have a minor leak in the lower unit of my 1988 90 Johnson outboard. There was a trace of water in the gear lube when changed. it changed the color to a light coffee color. The repairing tech. has quoted $210.00 labor $45.00 parts(seals)and wants to replace the rotor.With a total bill including winterizing at $317.50. Am I being riped off or does this sound correct.
raygun
posted 11-22-2003 12:37 PM ET (US)
I'd pass on the $62.50 "winterizing" portion of the estimate unless you are unable to operate spray cans and a grease gun. They will be changing the lower unit oil as part of the seal job anyways, so all you need to do is fog it, lube the fittings and spray it down with anticorrosion spray, right? Did I miss anything anyone? What's their shop rate? 70 an hour? Most importantly, do you feel confident in their work? Ray |
posted 11-22-2003 12:39 PM ET (US)
In my experience, that sounds like a very fair price for opening the gear case and replacing the seals. My local mechanic charges about $275 for that work.I do not understand your reference to "the rotor". Perhaps you are talking about the water pump impeller. Anytime you have the lower unit removed from the engine and torn apart, it makes good sense to replace the water pump impeller. Typically a kit of parts to rebuild the water pump (the rubber impeller and some new gaskets, seals, etc.) will cost about $50. If you need a new housing for the water pump, this will cost about another $50. (All prices are approximate and will vary with choice of OEM or after-market parts and the engine brand.) Regarding the cost of winterizing, this typically is about $75 from my mechanic. Your estimate of repairs and service sounds reasonable to me. |
raygun
By "rotor" do you mean the water pump impeller? I'd hope that is being figured into the reseal job, you wouldn't want to pass on that. |
posted 11-24-2003 10:38 PM ET (US)
[Changed TOPIC; was "1999 90 Johnson repair".--jimh] |
Steve Leone
posted 11-25-2003 12:51 AM ET (US)
$275.00 is the going rate. Make sure all the seals get replaced. The waterpump is usually included with a re-seal. Check the spline on the crankshaft and make sure it is ok. It will need to be greased before it is installed. Steve |
Dick
posted 11-25-2003 11:18 PM ET (US)
I closed out a work order today and resealing the lower unit was part of the job. Our labor rate is $99.00 per hour and our flat rate is 3 hours for a lower unit reseal plus parts. This was on a Merc but it's going to about be the same on a J/E.As Steve mentioned, when the lower unit is allready torn down it's no big deal to install a water pump kit, and it should be done. Sitting here in Seattle with my labor rate and my parts prices which are MSRP I would ballpark a reseal, impeller change, pressure test and test run to check water flow at close to $400.00. Just to try and justify our labor, rate we are on the water in a very upscale area and just down the road from Micro Soft Headquarters. The property was paid for many years ago but you wouldn't want to pay the taxes and insurance. We have a couple shops in the area that are well over $100.00 per hour that are not on the water and don't do a test run after the repairs. Dick |
