Topic: New method for removing bottom paint
LHG |
posted 04-30-2004 04:05 PM ET (US)
I recently came across an article in "Power & Motoryacht" magazine, April 2004 edition, that I thought would be of interest to Classic Whaler owners and buyers. For many, bottom paint is not needed or desired esthetically, but is a major hassle to get rid of.The new procedure, at least to bottom paint removal, is the use of a Soda Blaster machine, using ordinary baking soda as the removal agent. The cost is very low for doing a removal job such as a Whaler would require, $300-$500 range. This process does absolutely NO DAMAGE to the underlying gelcoat and only takes about 45 minutes to do a 35' boat with 12' beam! It is also environmentally friendly, with no toxic fumes, scraping, etc. The company making this device is MMLJ, out of Houston Texas, and they can refer you to a local contractor (marine yard) who has the equipment to do your hull. Phone is 800-727-5707, or www.mmlj.com. The process has been used for cleaning buildings and grafitti removal for several years now. Evidently the City of Chicago alone has 30 of their machines. This sounds like the solution many have been looking for for years. Underneath the bottom paint,it is still likely a wet sanding & buffing job would be needed to repair initial hull grinding done for paint adheasion.
Plotman
posted 04-30-2004 11:06 PM ET (US)
I really wish I had seen this about three weeks ago....Just spent way too many hours on my back sanding.... |
Kingsteven18
posted 05-01-2004 10:49 PM ET (US)
Even if the blasting gets all the paint off, sometimes the gelcoat remains discolored. I had a couple of boats (16's)blasted with ground chestnut shells and painted them with white epoxy when I was done. |
AC
posted 05-02-2004 10:04 PM ET (US)
Blasted with ground chestnut shells!? Now I've heard everything! |
David Jenkins
posted 05-04-2004 06:11 AM ET (US)
Chestnuts blasting on your Whaler hull, Toxic particulates in clothes and nose, Your wife's Tide soap being spilled by the tire, Can make you wish you had a new boat, like Moe's |
Cicada
posted 06-08-2004 09:04 PM ET (US)
I've checked on the web, called some local marinas and some sand blasting companies and can't find anyone that does soda blasting in the Detroit area. I've found one place in Gaylord and one place in Marquette that work with boats. Anyone have any direction for the Southern part of Michigan?Also checked into the purchase of the equipment. Found one with a 10 lb. cylinder for $250. Prices jump up to $1800 for a basic commercial unit. Paul |
posted 06-08-2004 09:20 PM ET (US)
There must be someone in SE MIchigan with this equipment. A few years ago the exterior brick and granite of the Penobscot Building was soda blasted back to its original appearance with outstanding results.Please let me know if you locate someone. I may use their service, too. |
scotts152001
posted 06-09-2004 09:29 AM ET (US)
I had my 24' OR bottom paint removed by soda blasting and it worked great. The gelcoat surface was roughened a bit from the process, so I wet sanded it with 800, which was quite a job. Glad I removed the paint, as the hull had some damage that the previous owner repaired with silicone and painted over to hide the problems! |
Cicada
posted 06-11-2004 10:13 PM ET (US)
Unable to locate anyone in the Detroit area that does soda blasting with boats. Seems odd.JimH, The Penobscot Building was cleaned by Ohio Building Restoration. At a cost of about 1 million. The soda blasting process was developed when they were cleaning the Statue of Liberty. They had attempted sand blasting but found that it was blowing through some of the copper. We have a new trailer for the Outrage coming next week and had to make a decision to go with something. I did locate a supplier of soda locally that also rents equipment. Decided to purchase the small portable unit, 200 lbs. of media and am renting an air compressor in the morning. The process requires a sizeable compressor that will move 15 to 18 cubic feet per minute. If anyone's interested I'll detail the costs etc. At any rate I'll report back on the experimentation. Paul |
Cicada
posted 06-13-2004 10:36 PM ET (US)
Ok. Plan B.The small portable unit is not the right tool for removing bottom paint. It will remove the bottom paint but the time involved is excessive. I spent 3 hours under the boat blasting and completed about 25% of the hull down to the epoxy barrier coat. It will also remove the barrier coat but the time is increased exponentially. Large surfaces require a commercial sized unit. The soda blasting abrades the gelcoat to a matte finish and texture. It seems like it would be simple (not easy) to sand and buff out. The operation of the equipment is pretty straightforward. Fill the unit, turn on a couple of valves, adjust the pressure and media flow, point and shoot. A respirator and goggles are required. As are ear plugs… found that out the hard way, dug baking soda out of one of my ears for quite a while. Be prepared to control the dust or for a large clean up. The media vacuums up easily and cleanly, unless it gets wet. Any residue or media that’s left after vacuuming is easily washed away. It’s water soluble. The dust does get everywhere, close windows and doors etc. to any areas in the proximity of where you are working. The media is pretty innocuous stuff, non toxic etc. Won’t need an antacid after working one of the units for a while either, but I wouldn’t recommend it as a means to relieve heartburn. If I were to work with a large unit I would not consider it in a residential area. The unit does appear to be a great choice for cleaning parts. Used it on the side panels that cover the electric and fuel lines on the 18 Outrage. There was some Sikkens from a prior refinishing that had dripped on the panels. Nasty stuff to remove. The Soda blaster did a great job cleaning the panels of sikkens, scuffs and grimes. It would probably work as well on the deck plates. Don’t know about the Marinium fittings but will try next time I get the compressor. Also considering using it on areas on the lower unit and interior of the hull where Sikkens and various other liquids of unknown origin are proving to be tough to remove. At this time still determined to get the boat back to the gelcoat. Need to change the approach. Paul
