Topic: 1990 johnson 150 water pump
striper swiper |
posted 05-10-2004 10:39 AM ET (US)
Does anyone know how difficult or easy changing a johnson 150 water pump is.What special tools are required,OR,just pay the mechanic?Thanks ,striper
wildeone
posted 05-11-2004 08:57 AM ET (US)
Very easy if you have a Clymer manual. I just finished changing mine this weekend on a Evinrude 150, about 1.5 hours, although this was the third time I had done it.Here's a tip, follow the Clymer directions COMPLETELY, I skipped a step the first time and spent all day trying to get the lower end off. My shop labor in New England is $80.00/hour, so I would guess the mechanic would charge me $200.00 - $250.00 if they could get to it before July 4th weekend. |
where2
posted 05-11-2004 12:39 PM ET (US)
Should be about as tough as doing the pump on my 1985 70Hp Johnson. Dropping the lower unit took about 1/2 hour (casually, not actually reading the manual since I'd done others before). Replacing the pump would have taken the mechanic less than an hour (I watched him remove the entire pump in 8 minutes at lunch yesterday! I learned some tricks watching him disassemble it!).Since I wanted all the lower unit seals replaced, I entrusted the job to a local independent mechanic. I dropped it off yesterday at lunch, he said give him a call at the end of the week, it should be ready... The Johnson/Evinrude dealer said if I dropped it off, they might be able to fit it in between other jobs this week, or they would definitely get to it next week... Special tools: Mechanic had a nifty socket of some sort to hold the drive shaft while he turned the impeller with a pair of channel-lock pliers to release the plastic shim that holds it. Other special tool was a large flat blade screw driver (same one he used to drain the lower unit oil). As I said, he disassembled it in roughly 8 minutes... I jokingly said: "Wow, that was quick. I'd still be messing with it 30 minutes from now, after reading the book twice if I was doing this at home..." |
striper swiper
posted 05-11-2004 10:49 PM ET (US)
Sounds like it may be e z.I"m not a spaz ,i can do a lot ..but when things go awry i call myself snowball.because things snowball out of control.But in this case..I"m not sure? |
