Topic: How to repack grease in trailer hubs?
TheNorthWaves |
posted 08-09-2004 10:35 PM ET (US)
hey guys,my 14' whaler's trailer has hubs that are kind of moaning/humming (ie: makin some kinda noise, at least i assume its the hubs not something else). I want to repack the bearings with new grease because, well, my dad said that's what I should do. But I generally dont know how to do that. The trailer is a lil rider, as if it makes a difference. It's gotta happen tomorrow too, before the 800 mile trip. Anyone know how this goes? -tim
Jerry Townsend
posted 08-09-2004 10:46 PM ET (US)
Tim - Repacking bearings is an easy chore - but, in view of your inexperience and your immediately forthcoming 800 mile trip, I suggest that you take your boat/trailer to an automotive repair outfit and have them repack the bearings. They may even let you watch them - but, if not, you can learn on your via the forum and a little time. ---- Jerry/Idaho |
Florida15
posted 08-09-2004 10:50 PM ET (US)
I agree with Jerry. Go pay a garage $30 or $40 and have them repack the bearings. It's worth it for the peace of mind. It's not hard to do if you have the time and pay attention when you take them apart but with an 800 mile trip coming up , you don't really have the time. If you take them apart and get stumped, you are screwed. It's not worth possibly having to postpone your trip. |
Florida15
posted 08-09-2004 10:51 PM ET (US)
Chuck Tribolet
posted 08-09-2004 11:23 PM ET (US)
If it's making noise, you'll probably need to replace the bearings. One good check on bearings is to check their temp after a nice long freeway run. They should be just warmer than ambient.I agree with the others, given the time constraint, pay somebody. Chuck
bsmotril
posted 08-10-2004 08:40 AM ET (US)
For less than $10 you can by a repacking tool. It is a much cleaner way to repack the bearings versus doing it with your fingers. Also it is better at getting the old dirty grease out and keeping it separate fromt he new stuff you are putting in. The tool comes with instructions and any auto parts store will have one. BillS |
CFCAJUN
posted 08-10-2004 10:31 AM ET (US)
I recommend you install "bearing buddies". All you need to do to maintain them is buy a $14 grease gun, and before each trip just pump the bearing buddies up with grease and off you go. http://www.bearingbuddy.com/ |
PeteB88
posted 08-11-2004 10:45 AM ET (US)
Man, you gotta learn to do this yourself. No big deal, bearing buddies are great. IF they are grinding they probably need to be replaced - take no chances there. But the regular preventive maintenance is easy - just get someone who knows to show you once. What happens if you breakdown in the backcountry? Screw Onstar!! I gotta be self-sufficient!! |
striper swiper
posted 08-11-2004 12:39 PM ET (US)
Baering buddies-omc lube-easy as sin.if you can"t do this SELL YOUR BOAT |
CFCAJUN
posted 08-11-2004 03:42 PM ET (US)
To repack the bearings you need to first remove them. The trick is to carefully pry them out without scratching the surfaces, or teraing up any O-rings that may be present. Just try to get the bearings out as gently as possible.If you think they were grinding, take them to a bearing shop and replace them with a match. If they are good, you need to clean them. I normally use soap and water to cut the grease, then gasoline. Once you have clean bearings, you need to pack them. This is easy, but dirty. Get some disposable latex gloves. Take a wad of bearing grease and place this in the palm of your left hand. Holding the bearing in your right hand, start pressing the bearing into the wad of grease in your palm and attempt to get the grease to be forced through the spaces and out the top of the bearing. Continue doing this until you are sure that you have forced grease through every open space in that bearing assembly. All you are doing is removing space that will allow friction and heat to build up. Just make sure that the grease gets all the way through the bearing. |
TightPenny
posted 08-19-2004 03:44 PM ET (US)
Ah... someone from the old school. That is the way Bill Westlake (may he rest in peace) taught me back when I was in high school, back in the late 1960's. After packing them, smear more grease over the face of the rollers, and place them back into the hub. Then smear some more over the end of the bearing that you can see. Don't forget to replace the grease seals with new ones. |
Buckda
posted 08-19-2004 04:18 PM ET (US)
Then install your bearing buddies and pump them full of grease, add the bearing buddy bra to keep it from splattering all over your hull and you're in good shape! |
waterguy
posted 08-19-2004 05:44 PM ET (US)
Maybe this site might help: http://www.rverscorner.com/articles/bearing1.html |
Ferdinando
posted 08-20-2004 02:27 PM ET (US)
Tim:If I was you just buy the new "Turbo-Lubes". They don't use grease and all you have to do is ck the oil level. I have had them on for the past two yrs without a hitch, they run great. Will not go back to grease. Fred |
