  Rage motor replacement otions
Author Topic:   Rage motor replacement otions
Curtis Johnson posted 09-17-2004 05:58 AM ET (US)   Profile for Curtis Johnson   Send Email to Curtis Johnson
There is a Rage with a bad OMC motor that might be available locally. Are there easy options for replacement? Thanks
where2 posted 09-18-2004 12:21 AM ET (US)     Profile for where2  Send Email to where2
Somewhere Tuna1 is lurking about, and I seem to recall a post where he was attemptng to determine the hull differences between the later years '96-'98 with the Mercury 175Hp Jet, and the earlier years with the 90Hp & 115Hp OMC TurboJet. Tuna1 was interested in retrofitting a late model 175Hp jet. Somewhere else (another site) I've seen mention of someone mating a 200Hp OMC Powerhead to the TurboJet pump, that user was experiencing overheating problems at the time of their post.
Tomorrow, I'll be removing the 115Hp engine from my Rage to extract the broken bolt from the thermostat housing.
Based on my two evenings in the engine compartment thus far, I wouldn't say anything is particularly "easy" about working on the engine in this boat. It's not as bad as working under the hood of a Saturn (I've only ever owned VW's, but the Saturn I worked on wasn't fun).
If you've got some time and some $$$ to burn, pick up the Rage and get some wrench time on it. I bought one that was overheated by the previous owner, and I'm still working the kinks out of that problem (between passing hurricanes in Florida). I took mine out for one spin, and actually enjoyed the thing. It won't replace my 15' Sport, but it may make a nice addition to the family after it's running correctly.
where2 posted 09-20-2004 07:19 PM ET (US)     Profile for where2  Send Email to where2
This week's installment: Contacted my local independent mechanic today to price the parts and labor to R&R my 115Hp engine. Over the weekend, I found that one cylinder is within reach of doom, since little chips of metal have been floating around on top of the piston, hammering the daylights out of the piston and head. Mechanic says $1000-$2000 depending on the parts necessary. A short block is $1500 (presuming I have a good used core). I've got 110psi compression in 3 cylinders, 85psi in the 4th (with dents in the piston).
Consider those numbers into your pricing equation. I need to determine how many weekends I can play shade-tree mechanic, to determine whether I let the mechanic re-work it or I rework it myself in the garage. It's just a little bigger than that 9.5hp engine I rebuilt 17 years ago...
BOB KEMMLER JR posted 09-21-2004 11:23 AM ET (US)     Profile for BOB KEMMLER JR
If there was little bits and pieces floating around in that engine at all,i would think an exstensive rebuild would be in order(cylinder over bore,new pistons,check rods,crank,heads etc)and $1000-2000 sounds way too cheap.After my first 15 minute trip in my rage and the powerhead went "pop" and after getting $5000-6000 estimates,i pulled that anchor of a jetdrive out and converted that sucker to a outboard.I have had nothing but problems with the outboard i put on it,but the conversion was the best thing i ever did to that boat.Total cost of conversion less outboard $700 and a months worth of weekends.I see these poor guys dump piles of cash into these OMC jets and don't hear many success stories.Pull that jetdrive out,plug the hole,hang a bracket and O/B on it and be done.IMO
where2 posted 09-21-2004 06:08 PM ET (US)     Profile for where2  Send Email to where2
Bob... I guess you missed my email on how to get the motor out of the boat last week...
The price estimate I got was not at the local OMC dealer, it was an independent mechanic who has done good work for my co-workers and my own outboard. He was very specific to tell me that "you don't know what you've got until you get the head off". He said he'd re-use what was still useable, and replace what was beyond it's service life.
I've seen catastrophic failures due to ring damage before. Ring broke, piston stopped mid-stroke and the crank and the conecting rod kept going... Usually it tosses the rod out the side of the block before everything comes to a complete hault. Those blocks are boat anchors, and only good for recycling. Fortunately in my case, I'm not that far along.
Mr. Johnson may be best served by converting the one he's found to an outboard and following your lead, depending on the severity of the "bad OMC motor". I intend to sink some $$$ into the one I bought and keep the jet running...
