Topic: How Much for Water Pump Installation?
Speedo66 |
posted 09-29-2004 12:55 PM ET (US)
Thought I would get the waterpump in a recently purchased motor changed as preventive maintenance. It's a 1988 Evinrude 88SPL (88HP). Local dealer quoted me $80 for the parts, and 2 hours labor @$75. per hour, total $230 + tax. Does this sound about right?
jflots
posted 09-29-2004 01:04 PM ET (US)
Do you mean the whole water pump or just the impellor? I've done just the impellor on a small Merc and don't remember it taking more than an hour. It may take longer on an older motor for some reason. His labor rate sounds high. Check arround for reference. |
Dick
posted 09-29-2004 07:48 PM ET (US)
The price for the parts seems high, a Sierra pump kit is around $50.00 to $60.00. Labor is another matter rates vary from area to area. Here they are $90.00 to $125.00 per hour. On a J&E I would guess 1.5 + hours with the change and a run up to test it.Dick |
Speedo66
posted 09-29-2004 09:06 PM ET (US)
Is it best to change the entire pump, or is just changing the impellor considered OK? |
Dick
posted 09-29-2004 10:27 PM ET (US)
If the rest of the pump is OK an impeller change is OK, if not go for what is needed.Dick |
andygere
posted 09-30-2004 04:29 PM ET (US)
Keep in mind that parts will also include lower unit gear lube (and installation of it), and new o-rings on the fill and drain plugs. $75/hour is pretty reasonable. If the motor looks salty, he may be adding some extra time for removing the lower unit without breaking any bolts. |
brisboats
posted 09-30-2004 06:58 PM ET (US)
Price sounds right on the money to me. Price for the OMC waterpump kit is $70+. Brian |
Dick
posted 09-30-2004 07:24 PM ET (US)
AndyA gear lube change would not be included in a water pump repair. Dick
WHALER27CC
posted 09-30-2004 07:37 PM ET (US)
The price sounds fair. I would change the the whole water pump kit, rather than just the impeller. The same elements that would help degrade the impeller would affect some of the other parts too. Better safe than sorry, and it really isnt more on labor , just about $40 more in parts they are going to be removing anyways. Peter |
John O
posted 09-30-2004 10:55 PM ET (US)
$75.00/hour seems to be the going rate up here in the Northeast. That is exactly what my marina charges. |
