  Removing bottom paint
Author Topic:   Removing bottom paint
David Pendleton posted 10-05-2004 08:41 AM ET (US)   Profile for David Pendleton   Send Email to David Pendleton
Hello all.
I'm looking at a boat with a painted bottom, and if I were to buy it, I would have the paint removed. How is this accomplished? Is it possible to restore the hull to it's original condition, or will the gelcoat be dulled by the paint and/or removal process?
I would want it to look as if it were never painted.
Thanks.
Dave
jimh posted 10-05-2004 09:19 AM ET (US)     Profile for jimh  Send Email to jimh
The amount of work involved in removing bottom paint depends to a great extent on how it was originally applied. Some hulls are abraded before the bottom paint is applied. Also, some use a primer. If this has been done, it will be harder to remove. If the bottom paint was just applied to the hull, without abrading or priming, it can be removed much more easily.
The number of coats of bottom paint may also affect the work involved in removing it. On my 1987 Whaler that had bottom paint, I found the hull was intact beneath it--not roughed up--and it came off rather easily by mechanical means.
Although I do not recall anyone actually reporting on the results, use of soda blasting has been mentioned as an excellent method for removal. Soda blasting is being used to restore building exteriors, particularly architecturally significant buildings with granite or marble exteriors, and it is considered a safe process.
Plotman posted 10-05-2004 11:49 AM ET (US)     Profile for Plotman  Send Email to Plotman
I talked to a soda blasting contractor, and he indicated that, in his view, the process was much better suited to removing build up of old paint and getting a good surface for new bottom paint than for trying to bring fiberglass back to an original, unpainted condition.
All of the before and after pictures I have seen on the soda-blasting websites show splotch remnants of paint in the "after" shots.
That said I was very happy with the results using micron's CSC in shark white (grey actually) after I sanded the many layers of old paint off of my old 22. This is an ablative paint that is designed to work well on a boat that spends a lot of time out of the water on a trailer or lift.
I can send you a picture of what the boat looks like with this paint.
David
wenchris posted 10-05-2004 12:25 PM ET (US)     Profile for wenchris  Send Email to wenchris
David, could you post the pic's hererso we all can get a look. Thanx Jimmy
Buckda posted 10-05-2004 12:33 PM ET (US)     Profile for Buckda  Send Email to Buckda
David -
Check with Barry - Last summer, he had begun the process of removing the paint from his 22' Outrage WD, and I think he was going to return the boat to a standard gelcoated bottom with no paint.
He might have some additional insight on how difficult this was for him and if he has any recommendations based on his experience.
Dave
wwknapp posted 10-05-2004 03:37 PM ET (US)     Profile for wwknapp  Send Email to wwknapp
I'm using Interlux Interstrip 299E stripper to do this. It's supposed to not attack the gel coat if used properly. I use plastic putty knives to get it off to avoid scratching. Both the stripper and the putty knives came from West.
I've just started the process, at the transom. Many, many layers of pitted and rough bottom paint on the boat. So far I've gotten down to the get coat only in a small area, but it looks and feels like brand new gel coat. Hardest part is the last thin bits of paint. Scraper won't get those, so far I'm using paper towels at the end to wipe the gel coat clean.
I've reserved choice if I'll leave it gel coat until I'm done. See what condition it's in all over. But I know this is going to help boat speed.
If using stripper like this be sure and read and follow the directions. I soak for less than 10 minutes in each removal round. Takes 3-4 passes to get down to gel coat. Someone else posted using a different stripper, leaving it on for 24 hours and having the gel coat come off. The stripper I'm using warns against leaving it on that long for exactly that reason, given enough time it can soften the gel coat.
LHG posted 10-05-2004 03:44 PM ET (US)     Profile for LHG
I have seen photos of boats soda blasted, and the bottom paint is gone. It's a very economical process, and the boating mag article said doing a 35' Sea Ray cost $400 and only took 45 minutes. But one has to search for a yard that does it, and it probably won't be nearby. Search out previous discussion, including information on the manufacturer of the special equipment, on this site. The manufacturer can then direct you to yard which have purchased their equipment, which is quite costly, I understand.
Since most bottom paint is applied to boats sanded with #100 grit paper, expect that the cleaned bottom will need to be wet sanded back to original gloss, and that some gelcoat work may be necessary where too much original gelcoat was sanded off/through.
But soda blasting is the best, and easist way, to get rid of bottom paint
Plotman posted 10-07-2004 08:35 PM ET (US)     Profile for Plotman  Send Email to Plotman
OK, here's a picture of the old boat painted with Micron CSC in Shark White. When I bought it, this boat has 3 or 4 layers of peeling blue paint on it. I spent too many hours on my back sanding them off. That made me realize how many hours it was going to take to wet sand up through the grits to bring the gelcoat back, so I repainted with a good paint that is designed for trailered boats in a color I thought looked good.
http://photobucket.com/albums/v436/Plotman/?action=view¤t=SharkWhite.jpg
David
jimh posted 10-08-2004 12:02 AM ET (US)     Profile for jimh  Send Email to jimh
I see you've been out to Devil's Island in Lake Superior. I was out there in my 15-SPORT. See:
http://continuouswave.com/sail-logs/up2000/
David Pendleton posted 10-09-2004 12:31 AM ET (US)     Profile for David Pendleton  Send Email to David Pendleton
When you say 'designed for trailered boats', does that mean it'll stand up to repeated loading on a bunk trailer?
If I decided to leave the paint on, I don't want two stripes down the hull from the trailer.
Thanks for all the advice.
Dave
saxophonist0 posted 10-09-2004 01:58 AM ET (US)     Profile for saxophonist0  Send Email to saxophonist0
Hello David,
This is not a note on paint removal, but on safety. What ever you do decide to do be careful with the material you are removing. It is deadly. It was designed to kill living organisms, e.g. humans. Take proper precautions.
Ray
Plotman posted 10-09-2004 03:04 PM ET (US)     Profile for Plotman  Send Email to Plotman
By designed to stand up to being trailered, I mean it is doesn't loose its effectiveness from being out of the water for extended periods of time the way many of the standard paints do. So far it seems to hold up to the bunks fairly well, but that boat doesn't get a lot of use.
David
Speedo66 posted 10-10-2004 01:19 AM ET (US)     Profile for Speedo66  Send Email to Speedo66
As far as removing bottom paint, has anybody tried going to a shop that does media blasting? This is the stuff that supposedly can remove paint from an aluminum can without damaging it. It's used by people in auto restoration, so maybe that's another possibility.
Plotman posted 10-11-2004 12:40 PM ET (US)     Profile for Plotman  Send Email to Plotman
Dave-
might be worth calling these folks in St. Cloud and seeing what they have to say. http://www.centrasodablasting.com/
David
David Pendleton posted 10-14-2004 11:23 PM ET (US)     Profile for David Pendleton  Send Email to David Pendleton
Thanks! I'll keep them in mind...
Dave
jeffs22outrage posted 10-15-2004 09:31 AM ET (US)     Profile for jeffs22outrage  Send Email to jeffs22outrage
speedo66 - Though media blasting removes paint with out harming metal (metal does have a much higher surface strenth than fiberglass) it still is a VERY harsh process. It typically uses every thing from sand, plastics, and even crushed walnut shells. Media blasting and sand blasting can creat quite a bit of heat. Soda blasting seems to be the best route I have seen for paint removale on fiberglass. It is also environmentally safe. However the paint it removes is still toxic.
Speedo66 posted 10-15-2004 11:57 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
Not familiar with "soda" blasting. I'm sure it's not high pressure Pepsi, so what is it?
As far as the media blasting, some of it is done with styrafoam pellets, wonder how that would be on fiberglass?
ryanwhaler posted 10-16-2004 12:24 AM ET (US)     Profile for ryanwhaler  Send Email to ryanwhaler
I removed the bottom paint off my Sport-11 with a DA sander, there where about three coats on and the gel coat had been sanded with a fine grit before the paint was applied. It took me a few hours a day for a week to get it all off, the dust (blue in my case) gets everywhere, gotta wear a dust mast and safety glasses, it wasn't a run job, and the boat is only eleven feet long.
I wouldn't do a whole hull manually again.
I second that,
How dose "soda blasting" work?
LHG posted 10-16-2004 03:18 PM ET (US)     Profile for LHG
Soda blasting uses ordinary "Arm and Hammer" baking soda, the stuff you put in the 'fridge to make it smell clean!
They say it does not damage the gelcoat, but I'm guessing some wet sanding and buffing is needed to bring it back to factory new.
This process can remove the bottom paint from a 25 Outrage in about 45 minutes or less.
WSTEFFENS posted 10-16-2004 04:21 PM ET (US)     Profile for WSTEFFENS  Send Email to WSTEFFENS
David:
I go with LHG on this, however, I had my "bottom" painted for about 6 years in the 90's (yea that sounds bad!) the paint was removed simply by washing down with thinner, something on the line of acetone. I think the "anti-foul" was an "Interlux" product.
However I am back to "basic" white.
Just a thought!
WLS
quickfarms posted 11-02-2004 05:15 PM ET (US)     Profile for quickfarms  Send Email to quickfarms
Does anyone know of a company that does this in the Los Angeles area?
LHG posted 11-02-2004 05:49 PM ET (US)     Profile for LHG
The manufacturer of the equipment operates a website, previously listed here. Search it out, and they evidently can refer you to a yard that has their equipment.
Chap posted 11-02-2004 06:12 PM ET (US)     Profile for Chap  Send Email to Chap
Hello,
Soda is the way to go, but you have to catch the paint to keep it green.
www.sodablastboats.com
Thanks
Chap
quickfarms posted 11-03-2004 09:09 PM ET (US)     Profile for quickfarms  Send Email to quickfarms
The reason that I am asking this question is that I did call them and they do not have a listing of any contractors in southern california.
I was wondering if this is a special process or are there other manufactures that offer this type of product?
Cicada posted 11-03-2004 11:18 PM ET (US)     Profile for Cicada  Send Email to Cicada
There are a number of different manufacturers of soda blasting equipment. I talked to a few of them when trying to find someone to soda blast the boat in the Detroit area. Closest I could find that performed the service was in the central Michigan area and they wanted about $500.00 to blast the 18 Outrage. I would imagine that anyone that was serious about providing the service would have to have some means of lifting the boat. I purchased a small unit from a company in the Holland area of Michigan and found that it was more appropriate for cleaning parts. Still required a commercial compressor to operate due to the volume of air needed. Areas that I did clean were left with a matt finish that would require some light sanding and buffing.
I also tried the marine Safety Strip using stripping pads and was unhappy with the length of time required. Found it was possible to achieve a relatively smooth surface that would only need some buffing but wasn't interested in spending the summer working on the boat rather than using it. In areas where the time wasn't invested the bottom would still need sanding and buffing. From what I understand the effectiveness of the remover is a little different for different types of bottom paint.
Also got a lead on a shop that uses some type of jig to flip the boat over then work on the bottom. Sanding and buffing again. Sounds like they know what they're doing but it also sounds like it would be very expensive. Thought I'd follow up on this over the winter.
Most of the shops around here want to sand the old paint off and reapply bottom paint. I want to return the boat to the gelcoat so I'm still looking.
Paul
Whaletosh posted 11-10-2004 04:52 PM ET (US)     Profile for Whaletosh
Paul (Cicada),
Do you know the name and location of the people that do this in central Michigan?
quickfarms posted 11-10-2004 09:10 PM ET (US)     Profile for quickfarms  Send Email to quickfarms
Do you know the names of the other companies that manufacture the equipment?
Speedo66 posted 11-10-2004 09:11 PM ET (US)     Profile for Speedo66  Send Email to Speedo66
I talked to a "soda stripper" out on Long Island, NY and he wanted about $35/foot. Said it made a mess and he would have to "tent" the boat.
Also told me I would have to arrange to get the boat off the trailer and up on blocks for him to work on it. Doesn't sound like I'll be doing that anytime soon.
Cicada posted 11-10-2004 10:04 PM ET (US)     Profile for Cicada  Send Email to Cicada
The cost for the equipment that would really do anything was running around 4 to 7 thousand. I think I have info from 3 different manufacturers. One of them sent a CD .
The company that performed the work was located in either Gaylord or Grayling.
I'll have to dig the information out and post again.
35 per foot sounds better than the 500 for the 18. When I tried the small unit out on the hull I had a cloud of baking soda hanging over the neighborhood. I can see where somebody would either need alot of space, want to tent the boat or have some other means to control the dust. Putting the boat on blocks seems awkward, slings might be better.
Paul
MyOutrage posted 11-11-2004 12:37 PM ET (US)     Profile for MyOutrage  Send Email to MyOutrage
Did I miss something on the math? $35 x 18' = $630
$630 > $500... Sounds like the other guy is the deal
Cicada posted 11-12-2004 10:28 AM ET (US)     Profile for Cicada  Send Email to Cicada
Let me run the cost figures through my head again 35 X 8 =90, 35 X 10 = 300 for a total of 390. Oops. Makes me believe in a calculator.
The equipment used for soda blasting is very similar to what is used for sand blasting. I think the only difference is in the heads. A search on sand blaster manufacturers may provide some leads. Another route that I tried here was locating and calling people in this area that carried the soda. Found a few people that did it for other things but nobody that could or was interested in soda blasting a boat. I haven’t found my info on the company that performs the work in Gaylord and will have to go through the search again. Getting the bottom paint removed is definitely something I would like to get done this winter.
I purchased the small unit from Ace automotive located in Holland, Michigan: http://www.ace-sandblasting.com/soda-blasting.html
Nice people to deal with. At the time I talked to them they hadn’t placed any equipment in Southeast Michigan.
The original manufacturer that I contacted was MMLJ. See the sodablastboats link or go to www.mmlj.com . This came from a site referred to originally by LHG in the thread http://continuouswave.com/ubb/Forum3/HTML/006082.html . They don’t have any equipment placed in Michigan.
You’d think that finding a company to soda blast a boat would be a simple thing.
Paul
