Topic: Broken Skeg
Speedo66 |
posted 10-17-2004 09:54 PM ET (US)
When I was launching today, the person on the other side of the ramp at Liberty State Park in NJ pushed his boat off of a full roller trailer. Rolled off very rapidly. We heard a noise and the guy was upset because he had launched with motor down and had broken the skeg right off of the motor. Turned out it was the first time he had used a brand new motor, and needless to say he was VERY upset.So my question is can something like that be repaired? I was trying to console the guy but had no advice for him. I assume it's aluminum and can be welded, but wasn't sure. Made a mental note to myself to never do that, launch with motor down.
jmacd99
posted 10-17-2004 10:10 PM ET (US)
Yes it can be repaired by welding but a simpler and cheaper method is an aftermarket bolt on skeg provided there is something there to bolt too. |
Speedo66
posted 10-17-2004 11:24 PM ET (US)
Thanks for the answer. |
sjohnson
posted 10-18-2004 12:28 AM ET (US)
Or replace the entire lower unit with a new one. Ouch!!!SJ |
LHG
posted 10-18-2004 01:42 PM ET (US)
There are factory replacement skegs from all of the manufacturers. These are welded on as a complete shape, at the bottom of the gearcase bullet. Many propellor shops do this work, with the lower unit first being removed, and oil drained by a dealership, and delivered over to the prop shop for the replacement welding and re-painting. It will look like a new engine when done, cost is about $250 total.I recently had one done on my Merc 200 EFI, looks factory new. (See Cetacea page 87) |
gimcrack225
posted 10-18-2004 04:39 PM ET (US)
I agree with LHG. I hit a rock last year and broke of about 3/4 of the skeg. I had the regional propeller shop (Precision Propeller in Newburgh, NY, rebuild it. As I recall it was a little less than LHG spent. Those "bolt-on" replacement skegs didn't appeal to me. They cost about $129 but require enough of the remaining skeg for to attach to. I had to take off the lower unit, unless you can drive the boat to the shop. If you are familiar with socket wrenches and the like its not difficult. Their driver, who makes a weekly route all over creation, picked up the unit and returned it repainted. While the lower unit is off, its a good time to rebuild the water pump. If you don't happen to be the Mr Goodwrench type perhaps someone at your marina could show you how to take off the lower unit. But thats another post. Karl |
Robob2003
posted 10-18-2004 05:23 PM ET (US)
If there is enough of the old skeg remaining you can bolt on a Skeg Gard which is easily installed and made out of stainless steel so it won't be as inclined to break off.I have even seen some boats with the guard bolted on as insurance BEFORE any damage. That's one of the advantages to running on sand and mud bottom like we do here:-) Bob on Tampa Bay
Ferdinando
posted 10-18-2004 05:38 PM ET (US)
Ditto for that. When I purchased my new Montauk back in 98 with a 90 Johnson I put a Skeg-Guard before it even saw water. (also put on a Keel-Guard)Bobs right, you avoid all the sanding and painting and your skeg always looks new, no regrets on either product. Fred |
