   Should I winterize my Merc's?
Author Topic:   Should I winterize my Merc's?
bear99 posted 12-14-2004 09:06 PM ET (US)   Profile for bear99   Send Email to bear99
Hi All ,
Since I live in Seattle , where the weather is basically mild year round , do I need to do this? I start both of them every other week and let them run for about 10 minutes.
Brad
linust posted 12-15-2004 06:39 PM ET (US)     Profile for linust  Send Email to linust
Don't kid yourself that Seattle is mild enough to not winterize your boat. You don't say what boat you have, but be mindful of water anywhere onboard. Last winter, we had a stretch of a week plus below freezing. Water in the exhaust risers/manifolds of my neighbor's I/O wasn't properly drained...replacing that Chevy big block cost him over $4000.
Do you use your boat all winter long? If so, you're probably OK. Just make sure, if you trailer your boat, to tip the motor down to vertical when parked, so no water collects in the lower exhaust are of the leg (thru hub exhaust). If you don't plan to use the boat till spring, why not winterize it? Also make sure to top off the tank if you have an internal aluminum tank.
Buckda posted 12-15-2004 06:57 PM ET (US)     Profile for Buckda  Send Email to Buckda
Linust really hit it when he asked about how you use your boat.
"Winterization" is really a term used to describe preparing the motor for storage. Boats in the Midwest are "winterized" the same way whether their destined to sit out in the boatyard exposed to the elements and harsh temperatures, or in a heated storage facility.
It's really about the "layup" or inactive time on the motor...the cylinders are fogged with a fogging oil that coats the cylinder walls and sticks there to protect them and other internal components and passages from corrosion.
The lower unit oil lube is changed because it needs to be changed at least once a year (approximately, based on hours of use - could be more, but for most of us Midwestern boaters, once a year works out in hours to be about right). We change it in the fall for two reasons: the risk of any water in there freezing or otherwise allowed to corrode internal components in the inactive period, and because it sucks to have to do it in the spring when you'd rather just be out on the water.
No matter where you live, if your boating activity goes dormant for a period of a month or more, you should consider "winterizing" the motor...and change that lube at least once a year, before the freeze in northern climes.
Peter posted 12-15-2004 07:18 PM ET (US)     Profile for Peter  Send Email to Peter
If you start them every other week then there is no need to fog them. If you are going to let them sit for 30 days or longer, even in the Summer, then it wouldn't be a bad idea to fog them.
Jgstewart8 posted 12-15-2004 07:52 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
IS there an article anywhere on the forum - describing how to properly winterize your whaler?
Buckda posted 12-15-2004 08:02 PM ET (US)     Profile for Buckda  Send Email to Buckda
Short answer: yes.
Do a search.
The first result is a reference article written by JimH.
http://continuouswave.com/maintenance-logs/winterize/
There are many more threads that have discussed other routines and procedures in detail. The Suzuki Website has a step-by-step instruction page on do-it-yourself maintenance, such as changing the lower unit lube, which I printed off and used as a reference the first time I changed my lower unit oil. (After you've done it once, you'll wonder why you ever thought you needed instructions - it's easy...but nice to have them "the first time".)
Dave
Buckda posted 12-15-2004 08:05 PM ET (US)     Profile for Buckda  Send Email to Buckda
I should mention that JimH's article is for a small outboard kicker (presumably used on his sailboat, or dingy)...but the procedure is much the same with a larger outboard, however you'll need more than a paper plate to catch the oil from the lower unit gearcase change...I use "Gladware" disposable containers to capture the lube, and then funnel it into a spare gallon-size TC-W3 oil container for disposal at a local facility.
jimh posted 12-15-2004 08:34 PM ET (US)     Profile for jimh  Send Email to jimh
A search using the argument "winterize" returns about 170 articles. Try this one:
http://continuouswave.com/ubb/Forum3/HTML/001212.html
bear99 posted 12-16-2004 12:07 AM ET (US)     Profile for bear99  Send Email to bear99
Thanks for the input.
The boat is an 85 Revenge W/T with a 94 200 carb and a 20 kicker. It has been about three weeks since I have been out but area 10 is opening for Blackmouth tomorrow so I will probably be going out Friday or Saturday.
I just changed the lower end oil a month or so ago and impeller on the 200 at the same time. They both start right up but each has a problem that I will address on another thread.I try to keep the tank full all the time but it is about 3/4 now. I also change the filter every other month.
By the way this is the boat that I am thinking of taking to the meeting at Hales next month.
Brad
Jgstewart8 posted 12-18-2004 09:20 PM ET (US)     Profile for Jgstewart8  Send Email to Jgstewart8
I am still debating winterizing my single merc...
I may just fog it - but I took the boat out today, and probably will take it out 2-3 times before spring.
I am in South Carolina - and yes, it does get below freezing here.
